Question about Microsoft Xbox 360 Console
Pice of ****
My xbox is fuuuuucccccccckkkkkkkkkkeeeeeeeeeeddddddd
  • Paul911 May 11, 2010
    What is the problem?
  • 90 Answers
Don't worry there is hope. Tell me what is wrong with your console, And I will help you. My e-mail is console.mods@yahoo.com
Posted on Aug 04, 2009
Singer 345 parts
Why do you need only one pice?
May 13, 2014 | Computers & Internet
Tip
How so you remove to gray pice on the hardrive side???? Their r only 2 spots...
1. Insert your index and middle finger into the memory slot holes, place your thumbs on the bottom of the Xbox (for leverage), and pull the face plate off with a steady force. It should come right off. 2. Break the Microsoft seal off. (Note that this will void your warranty.) 3. Now, flip the Xbox on its side and take a close look at the holes located on the top and bottom of each side. If you look closely, you can see that some of the holes are filled in. This is because the filled-in holes are keeping the grey plastic pieces on the top and bottom of the Xbox in place. 4. To remove the top and bottom grey pieces, use a small pointed object. Locate a grey plastic tab by peering into the holes, then use your pointed object to carefully push down and lever out the grey top/bottom cover. Both pieces have three tabs/clips per side, with a total of six per piece. To remove the top grey piece, you will have to remove the rubber pad. This is the only rubber pad you will have to remove. 5. With the grey pieces removed, take a close look at the back side of the Xbox. On the right and left side there are small notches that will require closer inspection. You again will need a small screw driver or narrow probe. 6. Using the probe, start on the left side (near power plug socket) and push the catch a bit into the Xbox until it clicks, then use a screw driver to keep the two sides apart. Once the left side is done, start on the right side and do the same thing to the rest of the catches. 7. Once they are all separated, the bottom of the Xbox will lift away. At this point slide it around to the front side and undo the four catches, keeping the case together. 8. Now grab your Torx driver set. You can use a T10 and T8 to do the job. You do not need a T12. 9. Unscrew the six T10 black screws, then use the T10 to unscrew all the silver screws. Finally, unscrew the black screws with your T8 driver . 10. Carefully flip the Xbox back over and remove the DVD button arm assembly to keep it out of your way. You just need to pry it off the black plastic guide. 11. Next, remove the top cover. Watch the DVD button latch. 12. Disconnect the SATA connector and power connector from the DVD drive and lift it out of the case. 13. To remove the white plastic air guide, locate the notch on the top outward side, insert your probe/small screw driver, and leverage the air guide out. It should lift straight out very smoothly. 14. Disconnect the power for the cooling fans. Now, use your probe/screw driver to pry the fan catches out from the metal guard. This will allow you to remove the fan device from the Xbox case. 15. Look at the front of the Xbox on the RF module, and remove the white plastic power button. It is held in place by a clip on the top and bottom. 16. Remove the three screws from the front circuit board (RF module). 17. Once the screws are removed, you will be able to slide the front circuit board off the Xbox with a slight pull. Notice that it is connected on the lower left side. You should now be able to pull the entire circuit board right out of the case with relative ease. Be careful not to touch any exposed circuits. 18. The next step is to carefully lift the motherboard out of the Xbox case. With the motherboard removed, flip it over and locate the two X connectors on the bottom. These are what hold the heat sinks on the processor. You can remove this; just be careful. It takes a little bit of force, which could destroy your Xbox if not applied properly.
on Jun 27, 2008 | Microsoft Xbox 360 Console
How do i fix my xbox game
a little more info, makes troubleshooting alot easyier.
anyway ill give it a go.
scratched c-d? in which case, you to a garage or anywhere that sells
t-cut put some on a soft cloth and gently rub into surface removing
scratches, with another pice of cloth (clean) remove the t-cut.
otherwise your laser might be faulty
or lense is dirty
Mar 22, 2011 | Activision Video Game Consoles & Games
I have Phone I9 When I call the person can't hear me. When I have handsfree, I hear my voice on mobile
Hi
If people cannot hear you, then it means the mouth pice of the phone is bad. The mouth piece makes people hear you when you talk to them on phone.
To replace the mouth pice, get a screw driver and unscrew the screw at the back. The mouth pice is located at the bottom of the phone. when you see it you will easily identify it.
Replace the bad mouth pice and couple the phone and the problem is solve.
Thanks
Aug 01, 2010 | Cell Phones
My nokia 6681 pice runing slowly and hang any
format your mobile or don't put big amount of memory.
Mar 31, 2010 | Nokia 6681 Cellular Phone
Is it ok to cut off a pice of plastic thats by the
just take it right off ,or tie it up till you get a better look
Mar 25, 2010 | 1989 Nissan Maxima
Focus knob problem
have repaired a few of these ...some whells have tiny set screws to tighten, some are a two piece wheel that loosens up sometimes, if not that then it is broken. if i can be of further help...15088331232
Apr 26, 2009 | Optics
I never Used A Fax Machine. I was Given A ''Brother IntelliFaxMC''
if you look at the area where you put your paper to seend ( that is the document feeder ) there should be a diagram of a pice of paper with a corner turned over, if lines are on the top part put paper in dac feeder face up. if lines are on the little corner pice put the paper face down,
if not sher put one pice of paper with lettering in doc feeder press copie of it comes out you got it right. hope this helps
C.W.H. ( typboy)
Jan 23, 2009 | Office Equipment & Supplies
Bad Xbox 360s
the new cpu die on the 360's help it run a lot cooler but the real problem is the gpu die which is not scheduled to change until next year. You could try adding a shim and screw replace the xbraces/stand-offs.
Aug 16, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
