Question about Philips Audio Players & Recorders
Hi, I have a philips RC 624, i need to find out which wires do what as i dont have the labels. here are the following wires i need to know; RED ORANGE BROWN BROWN RED/YELLOW BLUE (yes two brown ones look exactly the same) thanks in advance
  • 7 Answers
SOURCE: changing thermostat matching wires trouble
Brown my friend is for the 4 way valve solenoid, that is if you have a heat pump, ( it uses freon for heating instead of natural gas) perhaps you got the wrong thermostat, if you have a brown you need a thermostat for a heat pump, a regular thermostat is not going to have a brown connection.
Posted on May 08, 2008
micromaster
  • 3614 Answers
SOURCE: I have a 83 Honda
may i know the exact model pf the cd player, i will find a wiring giagram for that
Posted on Sep 02, 2008
SOURCE: need wiring schematic for Kenwwod KRC-2000 cassette receiver
Yellow : Battery - should have a 1A inline fuse - (memory)
Red : Ignition - should have a 5A inline fuse - (power)
Black : Ground (chassis)
Light Blue : Power antenna
Green : Left Front Speaker
Orange : Right Front Speaker
Blue : Left Rear Speaker
Red : Right Rear Speaker
Gray : Common ground for all speakers
Hope this helps.
Posted on Dec 13, 2008
BLITZ147
  • 4 Answers
SOURCE: I have an Orion 225 HCCA Digital Reference. I need
I've link that can solve your problems
http://www.orioncaraudio.com/Support/Manuals/Amplifiers/HCCA%20Series/Orion%20225HCCA%20Owners%20Manual.pdf
Posted on Sep 08, 2009
liteswink
  • 99 Answers
SOURCE: I have a tempstar with 6 wires. Green, Blue, Red,
You need to verify the function of each wire with Tempstar then cross it with the WR stat. Call the techline if you need further assistance 18002842925.
Posted on Apr 07, 2010
HOW CAN I TELL WHICH RED WIRE IS RC AND WHICH IS RH? THE WIRES COMING FROM MY WALL ARE NOT LABELED AND ARE THE COLORS 2 WHITES 2 REDS AND 1BLUE
This is a fairly hard question to answer. Evidently someone has run two sets of wires to your thermostat. One set has three wires in it: red, blue and white. The other set has two wires in it: red and white. One or maybe both red wires is the rc and rh wire. RC and RH actually wire together with a jumper wire. The RC and RH wire is usually the red wire that goes to the "R" on you furnace circuit board. If you can find out which red wire goes to "R" on your furnace circuit board you will solve the problem.
May 10, 2011 | Heating & Cooling
Removed my non programable Honeywell RT 5220D replaced it with a Honeywell RTH6350D to run my Goodman Heat Pump. First I labeled the wires then connected wires as follows: AUX, G, C, O/B (orange wire)...
Leave the factory jumper between R & RC. Connect the wires to the new stat just as you have them labeled. Use a piece of thermostat wire to make a jumper from AUX to E terminals. Your new thermostat should give you instructions on how to access the installer set up. You are going to set it up as heat pump with aux. I see this is 2 days old but if you need any help let me know.
Feb 13, 2011 | Honeywell Programmable Thermostat Heater
Need help wiring this theromostat. I ahve the following color wires.....Green Red Black Blue White Yellow and Orange. Need to match them to the following connections: G RC RH Y/O W/B Y1
G= Green Wire (Fan) RC= Red Wire (Power Cooling) Y1= Yellow Wire (Cooling Contactor) RH= Black Wire (Power Heating) WB= White Wire (Heating Control) YO= Orange Wire (Damper Control)
Blue Wire is usually to C= Common
Nov 28, 2010 | Heating & Cooling
New thermostat not cooling. Blowing heat instead.
Hello You have only 5 wires? multi stage if so ,is run by something else.Check that RH/RC is jumped out on new stat.Also check that O is not on the B terminal.If there is an A/B select switch set it to O.Emergency heat button dont matter as there is no wire to run it with only 5 wires.
Apr 17, 2010 | Honeywell Programmable Thermostat Heater
York Furnace and Honeywell Thermostat Problems...
run the red wire to rc and run a jumper between rc and rh tape off the brown
Feb 10, 2010 | Honeywell Programmable Thermostat Heater
I am changing from a Seco control thermostat model # tb1540e-g to
Rc/Rh should be from the transformer if a single transformer system. If its'a dual transformer system, then there should be a red wire to each from it's respective unit (furnace=Rh, condensor=Rc.).
W should be heat.
Y Should be cooling.
G should be fan.
I am not certain what E is, unless the stat can be used on a heat pump with backup electric heat, in which case it's for the electric heat.
The reason I say should be, is because if you are looking at wire colors, and not terminal designations, there is no guarantee the control wiring was connected following normal convention.
Reply back of any further questions.
Feb 03, 2009 | Honeywell Programmable Thermostat Heater
Hunter 44155c wiring from manual thermostat
I have a manual thermostat with the following wire connections (Y, G, R, O, C, & E) with the respective wires attached (yellow, green, red, orange, blue, white). My 44260 has available G, Rc, Rh, Y/O, W/B, Y1. Which wires should I connect to which terminals on the 44160. Thanks.
Jun 19, 2008 | Hunter Fan Company 5/1/1 Programmable...
498 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
