Question about RTO PasLode 900420 Impulse Framing Nailer
Similar problem.. Whats the best way to test the battery charger?
  • 2,176 Answers
With a volt OHMS meter on DC current you should read about 9.6 volts.
Posted on Aug 07, 2009
6530 aspire laptop charger gets really hot and doesn't stay charged for long
sounds like the battery is going bad on you . chargers will get hot when they have to work too hard as when the battery is not taking the juice .
Aug 03, 2015 | Aspire Computers & Internet
My victory 4 mobilty wont charge the green light is very faint/the charger was tested working.so why wont my scooter charge
make sure battery cables are secure at battery terminals and clean.how old are the batteries.If the batteries run down fast they are no good.a good way to test them is put scooter against some thing solid and go forward.If the battery indicator drops to o the batteries are no good.It takes about 10 hours to charge the batteries
Mar 15, 2013 | Pride New Mobility Victory XL 4 Wheel...
My batteries (enregizer nimh rechargable) will not charge and the red light shuts off quickly.
It sounds like your batteries are defective. If possible get some more same or similar batteries to repeat the test on the charger.
Dec 19, 2010 | Energizer Rechargable Battery with Charger
My LG-VX9200 wont turn on and the battery wont charge. I assume is the battery, its a practically new phone. It hasnt get wet either. What can it be? Thanks in advance
Before you conclude that the battery is the problem, i suggest, you get a similar charger to charge your phone first, if the similar charger charges the phone, then, ii means you are having charger problem, but if it does not charge the phone, you should be considering the idea of getting another battery to see if it will charge on your phone.
The problem can also be that, the charging port of your phone is bad, you can use your charger to charge a similar phone and see if it charges, if it does, then, the problem is either th battery or the charging port.
Check the following one after the other to detect what the problem is,
1. Try use a similar charger to charge your phone to see if it will charge.
2 Get a battery from someone that as a similar phone to test your phone to see if it will power up.
If it works with your phone, get a new battery for your phone, the one you have on it is dead and will need to be replace.
Take care.
Jul 18, 2010 | LG enV3 VX9200 Cell Phone
Message says charging stopped as phone too hot or cold. does it just need a new battery or is it something worse?
Hi, it is the battery cell that causes it to show charging stop or the charger.
So first change the battery and see how it works before changing the charger..
Take care.
May 27, 2010 | Samsung U900 Soul Cellular Phone
When i but the battery in the charger the orange and the green light comes on and i left it in for a long time and the battery was only charged a little bit whats wrong
This has happened to me. The transformer in the charger is dead.
you can test the charger by plugging it in and using a multimeter to test for current.
if you get nothing, it is dead.
You will need to get a new charger pack.
Apr 24, 2010 | Water Heaters
Can't take my phone off charger
It means the charging port is bad.
I suggest you remove your battery from your phone and test with a similar phone to see if it will hold charges. If it does, it means your new battery is ok. All you need to do is to change the charging port of your phone.
Wish you best of luck.
Apr 03, 2010 | Nokia Classic 2330 Cell Phone
My phone will not hold a charge at all. I've taken the battery out, let it set, put it back in for a few minutes and still no charge. The longest the phone lasts without dying is 10 minutes
Hello
Remove the battery and test it with a similar phone to ee if it will hold charges, if it does, it means the battery is good, but if otherwise change the battery.
Next place to look at is the charging port, check with a similar battery and charger to see if it will charge, if it doesnt, change the charging port.
Also test your charger with another similar phone to see if it will charge, if it does, it means the charger is good.
Best regards.
Feb 07, 2010 | Samsung Exclaim M550 Cell Phone
I plug the charger in but there is no response of the battery being charged. Can anyone help?
I suggest you test your charger with another similar phone like yours, if it charges with another phone, it means the charging port of your phone is bad and need to be replaced.
But if it did not charge the similar phone like yours, it means the charger is bad and need to be replaced.
I wish you best of luck.
Feb 06, 2010 | Samsung SGH-X820 Phone
Phone will not charge
I suggest you test the charger with another similar phone, it the charger charges the phone, it means the charger is ok.
Since the charger is ok, it means the problem could be from the charging port, so i suggest you change the charging port.
Best regards.
Feb 06, 2010 | Nokia 3220
RTO PasLode 900420 Impulse Framing Nailer  Logo
91 people viewed this question
Top RTO Air Tools & Compressors Experts
yoopertech
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a RTO Air Tool and Compressor Expert? Answer questions, earn points and help others
