Telsra want me to send the new phone away to get it fixed. It was supposed to be a new phone. I want a new phone & Telsra refuse to give me one... What should I do....?
SOURCE: 2355 at&t phone
you will need to call att or manage your phone online at http://www.att.com/gen/landing-pages?pid=3308
SOURCE: adding new expansion handset
You will need to register it to your base station before it will work. You do so by holding down the registration/page key on the bottom of your base for a couple of seconds, and then grab your SL30 and push Menu, scroll down to the option of Handset settings, press OK, then scroll to "registration" and push OK, select base station 1, press OK, then enter the default pin of 0000 and press ok. Repeat these steps if first not successful. You can download a manual for free on our website at www.cordlessrepair.com
SOURCE: broken handset
The weakness with the handsets was that women using hand lotion or hair gel can get it on the front of the keypad. It then works it's way to the back side of the rubber keypad. The oil gets on the powder carbon on the keypad. The Carbon shorts the copper on the phone to activate the #1 or #2, etc. When the oil mixes with the carbon the key no longer works. I replaced many keypads until Sony Supplies ran out.... A cheap home fix would be to open the handset and clean the #1 key and the circuit board. You can try the keys but if they don't have any carbon on them you can buy liquid carbon at Electronic Stores OR just paper punch a circle of alumimum foil. Glue the foil on the key with thin glue. Works....
AL
SOURCE: i have a telstra nokia E51 phone with a crazy johns sim
sir/ma'am,
-try to correct the message center number in crazy jhons sim,it was found in message settings,
-also these: validity period>maximum
message senr as>text
-call settings>send my caller id>set by network
