Question about Kitchen Appliances - Others
When money is put in, pop from #3 slot always comes out without touching any button. had to empty #3 in order to choose the pop you wanted
    President:
  • 1,723 Answers
The selector button for the # 3 slot is stuck on, change it, or free it up with a 'love tap'.
Posted on Aug 01, 2009
Which online slot offers the highest prizes?
There are several slots that are available online for playing. As you are looking for the slot in which you can get lots of exciting prizes then I would suggest you to play 40 Super Hot Slot. I suggest you this slot machine because I also play this slot and it's really better than other slot machines. On the above-mentioned link, you can also read the tips and tricks to play the slot machine.
Sep 13, 2014 | Video Game Consoles & Games
How do I install memory that's under keyboard on d830 latitude
Lift up 1 side of the keyboard cover with a small flat screwdriver.
Remove keyboard cover.
Remve three screws securing the keyboard.
Lift up the keyboard and placed it on the display panel or palm rest, so you can accss the memory slot A. The keyboard is attached to the mboard via a flat ribbon cable.
The memory slot A is located just abve the touch pad buttons.
In order to remove the existing memory module carefully spread latches on both sies of the memory slot.
The memory module will pop up at a 30 degree angle.
Pull the memory module from the slot A by the edges.
Install new ram and put everything back together.
Done!
Sep 10, 2010 | Dell Latitude D830 Laptop Computer PC...
How to install PNY OPTIMA 2GB DDR2 667 MHz memory card in lap top
Turn the computer off.
Remove the battery.
Unplug the AC adapter.
Turn the computer bottom-up.
Look for a few screws that secure a small panel.
Unscrew those screws, and remove the panel.
If you've selected the right panel, you should see your current RAM.
On the LEFT and RIGHT edges, there are small "fingers" that are holding the RAM.
Gently pull those fingers away from the RAM, and it should pop-up slightly, and you should be able to remove the RAM.
Notice that the "notch" in the middle of the RAM is slightly off-centre.
Insert the new RAM into the socket, and gently press down, until those two fingers "click" to grab the new RAM.
Depending on your "old" RAM, you may have:
* one "occupied" RAM slot (1GB), and one "empty" RAM slot;
* two "occupied" RAM slots (512MB/stick).
So, you may have to remove one RAM stick, to expose an "empty" RAM-slot "hidden" under the RAM.
Or, the "empty" RAM-slot may be visible without removing the RAM.
Or, you may have to remove one of the 512MB RAM-sticks, in order to free-up a slot for the "new" RAM.
Replace the cover-panel, and screw it in.
Reconnect the battery.
Reconnect the power-supply.
Start the computer.
Click Start
Point at My Computer
Right-mouse click on My Computer
Choose Properties
It should display your CPU-speed and the "new" amount of installed RAM.
Dec 10, 2009 | PNY Computers & Internet
HOW CAN I upload music on the LG KF 310
using data cables,blue tooth,for best music download see on www.mobile9.com
Jul 06, 2009 | LG KF310 Cellular Phone
Memory replacement v5535
Most of the laptops come with 2 memory slots . Hopefully one is left empty . It is situated at the back of your laptop the cover of which will be having the sign of a memory module. A single or 2 screws will be holding the cover in place. The memory usually is held in place with 2 clamps. Just slightly push claps in outward direction and it should pop up the module. Just clamp it back in place.
Jan 26, 2009 | Computers & Internet
Cannot download music from my computer to the touch screen i9
i had the same problem, here is what i did.
1. when you download the song, click the documents icon from ur main screen.
2.click memory card
3.scroll down and find the file
4.click it, and from the menu hit "copy"
5. choose the folder you want and click it, it should pop up "empty"
6. go to options at the bottom and click it.
7. you shoud see a menu that says "done" "open" "new folder"
click done. it should pop up "copying" then "done" and ur all set
hope this helps
Dec 29, 2008 | Dual Electronics CECT P168 Cellular Phone
FITTING EXTRA RAM INTO MOTHERBOARD
What you can physically fit and the space available is not the same thing, Crucial is an excellent site but it might say that you have the capacity to fit x megs but whether you have the empty slots is different (see the last paragraph), and you will not really know untill you open the case and look.
The actual fitting is simple enough if you can reach the slots without dismantling the whole machine!
Supposing you can clearly see and reach the slots, with the machine off, and the power cord removed - yes removed! Gently press on the white clips at either end of the fitted memory it will pop up, lift it out without touching the gold terminals, notice the slot in the bottom edge.
Now, and without altering the orientation, place it back in the slot lining up the slot to the peg in the receiver. Now with a little pressure you can clip the memory module back in the slot and the tags will pop back into the locked position.
Okay you have done it, its as easy as that. So when the new stuff arrives you will know how to fit the new modules.
Your new modules could have twice the value of the old ones, so if your board can handle say 1 GIG of memory in two slots, thats a max of 512 megs in each, you might have 2 x 256 megs fitted and there are no empty slots, so pop out the 2 x 256 and drop in the 2 x 512 making an upgrade of ½ a Gig (in each slot) giving a total of 1 Gig.
The probability is that there are four slots, two of which might be empty, its the combination making up the total that determines how much extra you can fit....
I hope thats clear??
BluRay
Nov 22, 2008 | Asrock K7VT4A+ Motherboard
Laptop Turning On But Nothing Happens - Replaced Memory
This does sound like a memory problem, and it more likely that a memory chip is bad versus the memory slot. The slots will be numbered 1&2, the memory will generally work in either, but the 1 slot is preferred. Try starting with just one chip in, try both slots, then try the other chip. It may just be one chip that is bad. If it is the slot, it shouldn't hurt the chip, but the motherboard will need replaced in order to fix it.
Jul 30, 2008 | IBM ThinkPad T40 2373 Notebook
Kitchen Appliances - Others Logo
32 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
