Question about Samsung SCX-4521FG All-In-One Laser Printer
Problem solution I,ve refill a sumsung scx4521f and was'nt the first time . But the only thing i've experiance for first time is that one side dark and the other side was fadding i even change the drum clean the blade but still no improvement . What could be the cause of it?
  • 40 Answers
Do you refill right Samsun ink,if that true,clean ink blake.
Posted on Aug 01, 2009
I lost my sumsung s7 edge and i cant find it when track it says location unavalable, how can i track it.
best thing about this new service is that you are never placed on hold and get to talk to real repairmen in the US http://709giaiphong.khamtaimuihong.org/benh-ve-hong/viem-amidan
Apr 07, 2017 | Cell Phones
How scan legal page in scx4521f
Clean the inner side of the printer and if that does not help, then replace the toner cartridge.
Aug 28, 2012 | Samsung SCX 4521F All-In-One Laser Printer
Why is my designjet 110plus printing too dark
> Check cartridges, any refilled one?> Perform print head alignment> Shoot color wise CMYK print out, check which color in dark > Verify the colors are spreading on media?> Try with another mediaI hope these steps will give you the solution..
Jan 04, 2012 | HP DesignJet 110 Plus InkJet Printer
Refrigerator need to be program after installing CNTRL =ELEC P/N WPL w10310240 model # G15FSAXVYOO S/N KW4406211 I' am losing everything in my (FRIDGE) did'nt find anything with part relative...
The temperatures are set when it leaves the factory (0 Deg F Freezer & 38 Deg F Fridge) and it should be left for 24 hours after installation before putting any food inside to allow it reach these temperatures.
Once the unit has been connected for 24 hours then the temperature can be changed by 1 Deg at a time but should be left again for 24 hours between each change to allow the temperature to stabilize.
The only thing I can sugest you try if you've already got food n it is to activate the Fast Cool which will run for 2 Hours.
Jul 08, 2011 | Whirlpool ED2FHSS Side by Side...
Black line going down side of paper from HP laserjet 1018
Roller Drum Problem in the cartridge.
If you are printing bulky document it may damage the roller drum causing dark line starting for both left and right paper. It will get bigger once it span of time.
Or if you are refilling the toner of the catridge, the waste compartment is full and requires to remove the waste tones inside the cartridge.
Or the worst thing is the the FUSER FILM ROLLER (orange plastic roller inside the printer is torn or burn because of heat or bulky printing.
Dec 08, 2010 | HP Hewlett Packard LaserJet 1018 Printer
Light print problem in sumsung 2010
it is problem your cartridge unite toner powder not support toner supply brush
you change cartridge and buy a new one then solve it
Sep 05, 2009 | Samsung ML 2010 Laser Printer
Excessive Ink & dark band on nozzle check
hi, are you using cis ( continuous ink system ) system or refill?
if cis try place the inks lower than printer if refil try repressure them ( open the plug hole - press the cartridge on the side then close them)
if you are using original ( not likely ) replace them..
Mar 23, 2009 | Epson Stylus Pro 9800 InkJet Printer
HP Laserjet 1022
Have you refilled the toner cartridge or is it refill as when these toner cartridges are refilled they have a tendency to leak. I suggest to remove toner cartridge turn the machine off vacuum out the inside and replace the toner cartridge with a new original. Run 20-30 prints through to get rid of any other loose toner and then should be fine.
If printing doesn't improve then repeat process if still same problem suggest transfer roller to be changed.
Hope this helps
Thanks J
Nov 15, 2007 | HP LaserJet 1022n Printer
Samsung SCX-4521FG All-In-One Laser Printer Logo
83 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
