Question about Samsung LA26R71BD 26 in. HD-Ready LCD TV
I get a 'weak or no signal' message and can't get an AV2 choice at all , just 'free to air' tv channels
  • 585 Answers
Reception issues require a better signal source, attic or roof antenna should solve your dilema
Samsung should stop at AV2 when something is plugged in the correct socket, if it doesn't check for a bad cable.
E
Posted on Aug 01, 2009
The picture looks like it's moving in slow motion...
Ur tv incomming broadcasting tv channels signals are pick up and using are Free over the AIR broadcasting tv channels pick up are by a Antena signal wright?Not signals by a pay cables or satalites tvs incomming broadcasting input signals?Yes?This tv causes are low and weak ranges of a tv Antena incomming recieving broadcasting tv channels signal.Buy a better design Antena like a Digital Antena and used it will solved this problems.Plug it in ur Digital Antena and rescan ur Free over the AIR broadcasting tv channels again.
Aug 15, 2011 | TruTech PVS31170S1W 17 in. LCD Television
There is a message on the screen that says "Weak or no signal".
Tv it is not getting the tv stations broadcasting incomming signals.Make sure the ur pay CABLE or free AIR incomming broadcasting tv stations signal sources are good and than go in ur tv menu go into SETUP pick AIR or CABLE and rescan channels again.U should have no more weak or no signal message anymore.
Jul 31, 2011 | Samsung HL-67A510 67" DLP HDTV
How do i get the TV to play satellite? it just says weak signal when I turn the tv on. JVC RM-C18G
It has to be on the right channel. If you are supposed to be on channel 3, 61, 73, 113 (ask the satellite company which one you should be on) then you'll have to change the channel. If you are not supposed to be on a channel you have to find out which input you're supposed to be on (video 1, video 2, video 3, av 1, av 2, av 3, hdmi 1, hdmi 2, input 1, input 2, input 3 for example).
Jul 19, 2011 | Televison & Video
I purchased the PT902/37B and charged it of course. Turned it on for the first time and the instructions say I have a no/weak signal, I reconnected the antenna and still nothing. Can you help? Thank you,...
U follow the tv owner manual instuctions for scanning for the DTV free over the air broadcasting by the tv stations signal yet.Do that first,still have a message weak or no signals.Buy a newly design Digital antenna or have a roof antenna already hook it up to the tv,follow the owner manual rescan it again will have all DTV free over the air broadcasting tv channels.
Jun 13, 2011 | Philips Televison & Video
My jvc lcd does not work with my local air tv, i get weak signals
Ur tv is getting a free air DTV right?Not Cable tv,Satalite or Telicom compannies services?Yes,than.Get a better antana like a roof antana or Digital inside antana to get better stronger and longer ranges to recieve the signal.Go to ur tv Menu.Goto setup Ch. Pick AIR rescan all the free DTV signal again,u should get all channel and a strong signal.
Jul 29, 2010 | JVC LT-32E478 TV
Can't record from TV to VCR
Most TV's send a signal out using Scart 2(AV2 on remote). So connect a scart to AV2 and to the AVin on the recorder, set the timer or manually record using the AVin as the channel. Unfortunatly you cannot use video plus as this would set to record from a normal channel. As I am not familier with the make of your tv, it's not a guaranteed solution, but I am 80% sure there is a way of sending the DTV signal out through one of the scart sockets.
Jul 28, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
Digital - Weak or no signal digital coax when hdmi dvd player on
if u have placed your DVD next to your tv ... just maintain distance between then and check out
Apr 01, 2009 | Samsung LE40R74BDX 40 in. LCD Television
Only get 2 channels plus a blank av1 and av2
u can up grade ur ariel,use manal instal, or get freeview,freesat or sky
Jan 25, 2009 | Philips TP3284C 32" TV
Turn tv on and get no program or weak signal message.
You should be watching tv in no time. Email me and let me know how it went I would like to know if I was able to help. surfpro@yopmail.com
1-You didn't say what model tv you have. Is it a HDTV?
2-Are you using an over the air (roof) or set top antenna connected to the tv?
3-Are you getting the no program or weak signal message on all channels?
4-Have you tried first cycling through the source or input button to make sure you are on TV and not on an input. Sometimes if you are on an input and for example the device connected to that input is off you wil get a no signal until you turn the device first but you probably already know that.
5-When you were in the process of scanning for channels assuming you had an over the air antenna connected did you make sure and select the ota option and not cable? if you have an ota antenna and not cable you need to select ota before scanning for channels.
Now assuming you have an ota antenna and you chose ota before scanning or doing a re scan and after the scan you still get the no program or weak signal message that means there is no signal and you may be using the wrong antenna or try moving the antenna in the direction of the television tower if you know where that is or turn in another direction but unless you are using the wrong antena you should get something.
Assuming you received some channels or even if you did not, try to and add channels by hand. Heres how: first you need to know the RF frequency channel or digital channel its transmitting on you just cant input the number of the display channel you want like on a tube at least not initially but you can after you first input the rf or digital channel number first and saving it on your tv then you can just input the display channel number you are used to. Heres how to manually force the tv to enter a channel without a scan or re scan and possibly loosing other channels with a rescan.
Go here http://www.rabbitears.info/search.php and go to state search choose your state from drop down list and click search now do you see the list of stations? on the left you have the display channel (thats the number you usually entered on a regular tv) and next to that is the digital channel (thats the number you need to enter on an hdtv or dtv initially to force the tv to accept the channel because if you just enter the number your used to initially the tv wont find it) the tv should now automatically redirect you to the channel you are normally used to and any digital equivalent and any sub channels for that channel. Now save it into memory in your tv menu channel list. do this for every channel for your area if you were unable to pick up any stations during a scan.
Jan 06, 2009 | JVC AV27F476 27" TV
Weak or no signal message
  1. Since my problem (Samsung/Comcast) began with a channel selection button pushed on the TV remote when it should have been pushed on the cable remote, I figured the problem lay with the TV.  Although I was getting the "weak or no signal" msg., the actual signal strength bar graphic showed it to be strong. Disconnecting did no good. I surmised that the TV was simply not recognizing the box.
  2. I looked at the manual for my Samsung 750 model.
  3. Page 20 discussed "Selecting the source". I accessed the TV menu and selected "Input", then chose the "HD..." item from the highlighted list. Voila! My tv works again.
Jun 08, 2008 | Samsung LN-S4092D 40 in. LCD HDTV
Samsung LA26R71BD 26 in. HD-Ready LCD TV Logo
236 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
