Question about Hitachi 51F710 Rear Projection Television
Hitachi F57F710A Message in black box in center of screen
Message reads "acquiring data please wait" Checked cable input, it's ok. Re-scanned channels, I cannot changed channel either. Any help would be most grateful.
George T.
  • gft111 Aug 01, 2009
    you mean 57F710A
Unplug tv. Remove cable from tv input. Plug tv back in and turn on THEN reinsert cable to where it was previously. This procedure was given to me by Hitachi csr & it worked.
Posted on Aug 04, 2009
Trinitron tv won't come on. says please wait
There may be a issue with the tuner on the set but there is a way around that.
With a cable box with audio/video out jacks connect to the same kind on the rear of the set---go to that input on the set and should see picture and sound---leave set on that input and change/select channels with the box.
Nov 02, 2012 | Sony FD Trinitron WEGA KV-34HS420 34" TV
H20 gps says waiting for nmea gps serial data
Your GPS is looking for an alternative source of NMEA data and is no longer doing it itself. If it doesn't get that data it will continue to look or wait for it. We can disable this function so the GPS relies solely on the data it is receiving through its own antanae. This function can only be changed while in Advanced mode. If you're not running in advanced mode make sure you switch to advanced mode. Once there, go to your Main Menu (from map screen, hit menu twice). In that menu, go and select SYSTEM SETUP. In your System Setup menu you will see an opition, COM PORT. Select COM PORT and hit Enter. You will see three Check boxes (NMEA INPUT, NMEA GPS INPUT, NMEA OUTPUT). Make sure that none of those are checked. Once you are done, you can EXIT out of the menus. Go out and see if you can acquire a Satellite Fix.
From:http://www.bruntonoutdoor.com/support.php?category=Atlas+MNS
Feb 14, 2012 | Lowrance iFINDER H2O C GPS Receiver
I have Dish 322 receiver. Everything was fine; a week or so ago satellite 119 reception was spotty, now we can't get 119 at all. We get 110 but only about 34%. Sometimes the receiver will power itself off...
hartpark
It looks like you have lost the signal for the 119 satellite from your dish. Are you getting an error message, either 002 or 015, saying the satellite signal has been lost or acquiring satellite signal? First, check the cables on the back of the receiver to make sure they are secure. You can also run a check switch test to see if there is a problem between your dish and receiver.
Press the Menu button on your remote. This will bring up the Main Menu on your TV screen. Input the numbers: 6 (System Setup), 1 (Installation), and 1 (Point Dish). On the right side of the Point Dish screen are 3 buttons. Select the Check Switch button. Within the 2 large boxes are satellite numbers and green or red boxes. Make a note of the satellite numbers (should be 119, 110), the trans, the device, and switch. Super dish and alternate should not be checked. Select the Test button on the bottom of the screen. If a box pops up with a warning about TV 2, select Yes. It will now run the check switch test. Let it complete the test. After completion, the screen will automatically go back to the Installation Summary screen. You may get a message stating that the Check Switch test has found fewer satellites than previously detected. If you get this message cancel out of each screen (do not save the results) till you are back to the TV screen and it is acquiring Satellite signal.
If you don't get that error message, see if the information on the Installation Summary has changed. Then select Done on the next 2 screens and cancel out of the others till you get the message, Acquiring Satellite Signal. After it finishes acquiring satellite signal and downloads the program guide, see if you are getting a picture - try different channels. If you still have problems, please email me at, ray.calo@dishnetwork.com. If you are still experiencing problems, we will need to send a technician to fix the problem.
Ray Calo
DISH Network
Apr 23, 2011 | DISH Network 322 DTV Receiver
MY CABLE WENT LAST NIGHT ABOUT 12 O'CLOCK. A.M . I CALLED A TECH AROUND 7 A.M. I,LL HAVE TO PAY FOR A TECH TO COME OUT. OK, I GOT TV#2 THE ONE WITH THE BOX. T V #1 I CAN,T GET IT TO WORK. THEY ARE ON ONE...
jefferswjj,
What are you getting on your TV 1 screen? Are you getting 015, acquiring satellite signal or weak or no signal, blue/black screen or snowy screen? Each of these problems requires certain troubleshooting steps. For the 015 message, a component from the Dish to the receiver may be bad. It could be weather related. For the other problems, the TV may not be on the correct input setting or channel. If you can provide more information, I would be happy to assist you.
Ray Calo
DISH Network
Aug 02, 2010 | DISH Network ViP722 DTV Receiver /...
Black screen after insalling video card
Hello sir
Try installing a older version of driver..
Or downlaod Driver sweeper through google and clean your ATI drivers and then try again..
Mar 20, 2010 | Computers & Internet
Black screen with message about no input signal
might be something wrong with your monitor's data cable
May 21, 2009 | Sony SDM-HS95P/B 19" LCD Monitor
No channels after scanning analog cable on Hauppauge 1600
I have exactly the same problem with the very same equipment but I may have found a solution. Try scanning for DVB-T channels and you may find some success. I also recommend printing up the WinTV user manual and reading it. I'm not big on reading manuals but this one actually has a lot of useful info. I will try to fix my setup and let you know if it works. Today it is recording all 6 Star War episodes till 2 am plugged in through the set top box (can't interupt)
Feb 05, 2009 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Hitachi Ultrascan HD Black square question?
If that black box is generated by Tv, it should be there all the time, like on cable, av input etc.
as you said its not always, so cable top box is suspected which can generate such box as well.
I would suggest when you see that box in tv reception, simply play dvd player and check is that box still appears on dvd input? I hope black box wont appear in playback of dvd player.
Need further help, please let me know.
Sep 17, 2008 | Hitachi Televison & Video
HITACHI 53" REAR PROJECTION
Good Day;
Some cable techs are good but too many are not.l So, if you have not solved this by now try this:
Unplug TV & box, wait 5 minutes plug both back in (reboot).
Good Luck.
May 30, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Televison & Video Logo
156 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
