Question about Intel SS4000-E (SS4000ENA)
Disk Change notification after reboot
Got the same problem.
Any solution or suggestion ?
My pone was fine the night before but when i woke up this morning my notification bar was gone i can't see my battery life or the time on the top of the screen and the scrolling menu from the top
May be you can try doing hard reset to your phone.If the problem perisit then you need to upgrade software by visiting ZTE official website.
Mar 09, 2013 | ZTE Warp
Toshiba X505-0885 screen keeps going blank and I have to reboot, anyone know what is wrong
In the Tray Notification Area right click the Power/battery Icon, Open Power Options, Change to High Preformance, click on Change Plan settings, Plugged in , mark, Never, Never. click on Change Advanced settings, Change setting to your preference. If you haven't cleaned your fan and vent, take a look, also make sure there is sufficent air flow, unblocked, from bottom of laptop to side vents. A loptop cooler is a option.
Dec 13, 2012 | Toshiba Qosmio X505-Q894 18.4" Notebook PC...
M50vc recover wireless
If the problem is with the computer, in the Tray Notification Area, right click on wireless icon and open Network Sharing Center, click on Change Adapter Settings, Is the wireless adapter enabled? In Device Manager, Network Adapters, Is the wireless enabled? Reboot the computer and the wireless access point by removing power and battery and plug in wireless, let it run the selftest, plug in computer and boot normally. You can always Reset the wireless access point to default settings
Nov 30, 2012 | ASUS M50VC-AP012C Notebook
My laptop has crashed with vista installed, I can't find my reboot disk.. could I reboot with windows 7 software. And start from scratch?
Yes you can. But before you do this make sure you have back ups of your important data.
Just inser the windows 7 disk and windows should detect the cd and ask you to press any key to boot from cd. Press any key to continue with the installation.
If ever the machine doens't load the disk first, go into bios (usually by pressing Del) and change the boot sequence there, making sure it starts with the dvd/cd first.
Once this is done, just follow the onscreen instruction to install windows 7. I suggest you choose a fresh install rather than upgrade.
hope this helps.
May 04, 2011 | Computers & Internet
My usb Drive Can't showing capacity
Unplug your USB Drive then plug it again. There should be a notification saying "New Hardware Found" on your taskbar. Check that notification if your drive is working properly.
If not, go to Start>Right Click on My Computer>
Click Manage>...Then Choose DIsk Management>
Look for your removable storage device>
Check the capacity and the drive letter if there was no conflict with other drives of your partition>
If There's a conflict, Right Click and choose "Change drive letter and paths..."> Then change the drive letter of your USB drive.
Mar 21, 2011 | Computers & Internet
TV will not communicate with DirecTV receiver. Tried rebooting, switching cables. Notification on TV reads that it cannot receive signal.
Ur Direct tv box have problems,call Direct tv customer service for sevice.U reboot the box,signal cables change right,same problems.The box is a rental,u have right to exchange for another one.
May 15, 2010 | InFocus ScreenPlay 61" Rear Projection...
How do i change my htc text tones (alert) to mp3
To add other sounds to your notifications list, you will need to get to your SD card.
On your SD card, you will need to create a directory titled media. Within the media directory, create a folder titled audio. Within the audio directory, create a folder titled notifications.
Place any .mp3s or other sounds into this notifications folder. Unmount the SD card. Reboot your phone. When you go to Settings > Sound & display > Notification sound, you should see all the newly copied files on your notification list.
Good luck.
Mar 19, 2010 | HTC Hero Smartphone
Windows validitation notifications
All the information and programs you need to get rid of this can be found at:
http://www.wikihow.com/Remove-Windows-Genuine-Advantage-Notifications
Just copy and paste the above link in your internet address bar.
Sep 15, 2009 | Microsoft Windows XP Professional
Reboot
To Reboot a computer is to turn it off, wait at least 20 seconds, then turn it back on.
A.If you're thinking of Reboot, as to reinstall the Operating System, you use a Restoration Disk, (sometimes listed as Recovery Disk), insert it in your CD/DVD drive, and restart your computer.
(Just press the CTRL, ALT and Delete keys AT THE SAME TIME.
Not shouting. Windows XP and Windows Vista are examples of an Operating System)
B.If you're trying to install an Operating System, from a CD disk that you bought, I suggest you go into BIOS Setup, and in Boot Order, change the first boot device to CDROM. Insert the CD disk in your CD/DVD drive, and restart the computer.
If you buy a Full Installation CD disk, as listed above, you have to change the Boot Order.
For example:
1.You have Windows XP on your computer now. It has problems, and doesn't work correctly. Instead of getting the Restoration Disk from your computer manufacturer, you decided to just buy a genuine copy of Windows XP, and install it. (This is a Full Installation Disk)
The Windows XP you have installed now, will not let the one you bought install over it, by just putting the disk in the drive. Change the first boot device, in Boot Order to CDROM, and it will. The Windows XP you have now, will 'see' the Windows XP you're trying to install, as just the same version. You have to install a better version of Windows, in order for it to write over what is installed.
Such as Windows Vista.
2.You have Windows Vista on your computer, and are not happy with it. You would like to put Windows XP on instead. Windows XP is considered a lesser version, and Vista won't let it write over it.
Go to BIOS Setup, change the first boot device in Boot Order, to CDROM, and it will.
May 10, 2009 | Compaq Presario R3000 Notebook
Open Questions:
Greetings, I've been using the Intel Entry Storage System SS4000-E as a simple backup network drive for the last few years. It showed up as Drive Z: on all of my Windows machines and I just copied other drives/folders onto it as needed. It's far from the full capability of this device but it's suited my purposes. Recently, I decided to upgrade the drives and increase the total storage space from 2 TB (4 500 GB drives, Raid 0) to 6 TB (4 1.5 TB drives). The software doesn't allow me to make one 6 TB drive, so I made three (X:, Y:, and Z:), with sizes ranging from 1.49 TB to 1.99 TB, accessible as \storage\public3, \storage\public2, and \storage\public1 respectively. I also created the required shared folders using the minimum (200 MB) for both so I could have as much room as possible for large shared partitions. I also took the opportunity to upgrade the firmware to version 1.4, build 709, since I was installing new drives. I backed up some data to the Z: drive (\storage\public1) and filled about 1.5 TB. Then I started copying folders from another system to Y: drive (around 900 GB in all). Everything seemed to be going well until I looked in on the copy after around 800 GB had transferred. Files were being copied *extremely* slowly, like 100 MB in 10 minutes! I aborted the transfer and ran a test to eliminate network issues as the problem. I tried copying a 100 MB file from Y: drive to Y: drive. It took around 10 minutes, as above. I tried the same thing on Z: drive and it was almost instant. Something was somehow causing that part of the network drive to move at a snail's pace. I then accessed the management screen via a browser and got a message saying that one or more drives had either failed or been changed (Disk Change Notification - raid_disks_changedF.cgi). Two tables that show all four disks - serial numbers and capacities - are shown, one table being previous configuration and the second being current configuration. Both tables are completely identical. Clicking on "Scan" or "Continue" resulted in the same message, so I clicked on "shut down" and tried to access the network drive after it rebooted. I had no problem getting into the Z: drive part of it but both X: and Y: weren't being seen at all anymore. I'm aware of the fragility of a Raid 0 and wonder if it could be so easily disrupted during a large transfer such that I face the possibility of initializing all four drives and starting over. I'm at a loss as to what could be going wrong here or how to fix it. I really just want a simple means of copying lots of data over from various networked machines without any additional software. This system worked fine before. What could have happened? Thanks for any help. Bob
Apr 13, 2011 | Intel SS4000-E (SS4000ENA)
See all Intel SS4000-E (SS4000ENA) Questions
Intel SS4000-E (SS4000ENA) Logo
433 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
