My outlook is not working on my IBM Linovo thinkpad. Continoursly trying to repair itself with the message: datafile private maps was not correctly closed.
4 Suggested Answers
benwabnick
  • 2404 Answers
SOURCE: my ibm thinkpad t43 displayed a message "hard error d0014"
This could be a problem, not sure if its a software related or if the hard drive is bad. If you can find a windows xp cd. Try and wipe out the hard drive and install windows xp on it. If it goes thru then you'll just need the drivers. If it errors out on you then you know its a problem with the hard drive and you'll need to replace it. If you get windows xp installed on it, let me know and I'll help you with the drivers.
Posted on Jun 04, 2009
bobfreengel
  • 37 Answers
SOURCE: IBM THINKPAD T43. I can find the switch for my ibm thinkpad T43
Are you sure you have a wire card installed? If so, then try this:
  1. Right-click the My Computer icon and select Properties.
  2. Click the Hardware tab and press the Device Manager button. The network card should appear under Network Adapters.
    Note: If the card has a exclamation mark over a yellow background, then this is an indication that the card is experiencing a problem. Go to Driver download step 5.
  1. Verify that the radio is enabled.
    It is possible to disable the transmitter of the wireless card without Device Manager showing any problems.
    Note: Follow the instructions provided to enable wireless card.
    • Most wireless cards will put an icon in the system tray (the line of icons in the lower right corner of your screen). Right click this icon and it may have a menu option to enable/turn on the wireless radio.
    • Some systems come with a Wireless Radio switch to disable the wireless radios. The wireless radio switch is usually located on the front side of the machine. If you are having difficulties with wireless connections, make sure the Wireless Radio switch is set in the On position.
  2. Check for association to an Access Point.
    If you double-click the previously mentioned system tray icon, the configuration utility of the wireless card will appear. This utility will be able to show the status of the wireless card, showing what channel the card is using and what signal strength is being received. It may be difficult to maintain a connection if signal strength is low due to either interference or distance. For example, interference can be caused by 2.4GHz cordless phones, other Access Points in the area, and physical structures such as load bearing walls or metal partitions.
    Note:
    The utility can be used to configure the wireless card settings, but if using Windows XP Zero Configuration or Access Connections, you will need to use those programs to actually configure the wireless card as they will overwrite the setting of the utility.
Posted on Oct 12, 2009
rinkunitesh
SOURCE: repair for power supply section for IBM Laptop R51
ibm thinkpad r50 power section
Posted on Oct 15, 2012
IBM thinkpad, will not switch on, no charge light when plugged in?? no lights at all?
1. Make sure your wall outlook is good. Try a different outlet.
2. Test the AC adapter if you can with a multimeter.
3. Remove battery and AC adapter then hold the power for 40-50secs. Reconnect AC and try power on.
Hope this help.
Jan 04, 2011 | IBM ThinkPad A31 Notebook
Computer turns on and off all by itself.
check out wall power
change the smps
may be software problen unintall and reinstall operating system
Aug 05, 2009 | IBM Thinkpad T40 Thinkpad T41 Thinkpad T42...
MS Outlook pst file overwritten.
Open the pst file in Outlook & see if the conents are still existing.
File -> Open -> Outlook datafile
Aug 03, 2009 | Microsoft Office Outlook 2007 for PC
IBM ThinkPad iSeries 1400 LCD not functioning
I am afraid you are correct, your laptop screen is not usable and unless you’re a trained professional I do not recommend trying to repair the monitor itself. In fact, to do so would be rather dangerous to your own well being, but you do not have to throw your ThinkPad away. You could continue to use it with the external monitor or you could send it into Dell and pay them for a replacement. Look around though, there are probably other people who could provide this service for less, beause large corporations usually charge you more than necessary.
Jan 03, 2009 | IBM ThinkPad i Series 1400 Notebook
Think pad fails to "start"
Do you have any Operating System on it at all , if you have then lets know what OS it is and the penyium of your system
ok
Oct 02, 2008 | IBM ThinkPad T43 Notebook
My nextar W3G-01 won't load the map screen any more. One time as I was trying to make it work by flicking back and forth a message stating invalid or missing data file linkinfo.bin came up, but nothing...
I HAVE A SIMILAR PROBLEM WITH MY W3G-01. THE ERROR MESSAGE READS; CANNOT FIND MAP DATAFILES. PLEASE MAKE SURE THE STORAGE CARD IS PROPERLY INSERTED. I HAVE REMOVED CARD AND REINSURTED IT AND THE MESSAGE REAPPEARS.
Jul 19, 2008 | GPS
Ibm thinkpad t40
http://en.wikipedia.org/wiki/Blue_Screen_of_Death
http://support.microsoft.com/kb/174630
THe most popular windows issue in all the land.
Oct 24, 2007 | IBM ThinkPad T40 2373 Notebook
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
