Question about Sony Cyber-Shot DSC-T1 Digital Camera
All functions display on the screen, but no picture.
When you lower the lens cover thet logo appears and you can go through the menus (to triple check the settings) and see all of that just fine. But there is no image when you are ready to shoot and no picture to review, I even downloaded the images I had taken to see if I could view them that way, but it was still a solid black image.
It went from working fine last weend to this.
It sounds a lot like the problem others are asking about. Is it?
Thanks.
  • 10,594 Answers
Yea, its known problem of ccd imager in Sony DSC-T1 camera and Sony will repair it free of cost.
Click Sony CCD Imager Support for details.
Thanks.
Posted on Aug 01, 2009
Screen goes black just after windows logo on a E-SYSTEM sorrento 1.
Your monitor display settings are no longer set (synced) with the upgrade. Boot into Safe Mode by pressing F8 during boot and lower the screen resolution.
You will have to check Display drivers in Device Manager, and make sure they are loaded.
Sep 25, 2012 | Computers & Internet
I have error code e106 on my 733 hp camera,whatis that?
CausesThese errors display because the lens will not move. There are several reasons why the camera lens might not move:
  • something is blocking the lens
  • the firmware version is old
  • the camera has been abused
  • foreign material is inside the lensor
  • the lens is loose or completely off the track
SolutionFollow all of the steps listed below.
  1. Perform a power reset on the camera.
    1. Turn off the camera and remove any optional memory card.
    2. Hold the ON/OFF switch in the ON position until the HP logo displays and then disappears.
    3. The camera is now reset. When the camera is turned back on it should prompt for the date and time.
  2. If the camera does not display an error after the reset and appears to be functioning properly, it is imperative to check and update the firmware. The firmware update corrects the lens positioning issue that can cause E104, E105, and E106 errors with the camera.Determine if an update is needed by following the steps below to check the current version of the firmware on the camera:
    1. Before turning the camera on, press and hold the Flash button.
    2. While the Flash button is depressed, turn on the camera. A Service Screen displays.
    3. Located at the bottom of the screen is an entry, F/W.
    4. If the version of the firmware is lower than 1.12, then the firmware update is required and should be performed immediately.
Nov 21, 2011 | HP Cameras
How do I print pictures from my camera on the computer(pictbridge)?
The camera compares its PictBridge functions to the functions of the printer. The camera then displays the supported functions on menus on the LCD screen or in the viewfinder.
PictBridge print options
Once a PictBridge digital camera is connected to a compliant printer, print options appear on the camera LCD. The camera menu system is used to make settings such as print size, layout, media type and date.
You can print a single image displayed on the camera, print two or more images or print all images on the memory card. You can print part of an image by first cropping it within the camera and even create index prints, also known as contact sheets.
Print sizes and PictBridge
Not all PictBridge digital cameras let you select all available prints sizes, such as 13×19? if you have a wide format printer. If the printer has a memory card slot, use it and larger size prints should be available.
Is your device PictBridge compatible?
To find out if a camera or printer is PictBridge compatible, look for the PictBridge logo on the packaging or check the manual for specifications. If still unsure, call the manufacturer!
Jan 13, 2011 | Cameras
Unit functions but no display
Try this - if it doesn't work you have to send it to Garmin for screen repair.
Now when the screen goes to this - push YES -
May 07, 2010 | Magellan Maestro 4250 GPS
JVC GR-X5e camcorder, lens cap message. Does not show a picture.
It shows all menus, numbers and graphics on LCD, but seems like there's no picture coming through the lens. In both modes, video and still. It seems like it can not see anything as if the lens cap was on all the time.
Could this be a problem with sensor.. CCDs? Lens? Something else?
Feb 19, 2009 | JVC GR-X5 Mini DV Digital Camcorder
CD won't play
Your lens might be dirty.Open the cover of player and identify the lens.Its a little glass eye.Get a clean cotton cloth dipped in methylated spirits gently rub surface of lens. Give some time to dry and replace cover.You should be ok.
Jul 19, 2008 | Cyberhome CH-DVD 300 DVD Player
Hp 735 camera error e106 then it turns off
When the camera is turned on, the lens is stuck either in or out and the camera gives the error E104 , E105 , or E106 . The camera then turns itself off. Causes These errors display because the lens will not move. There are several reasons why the camera lens might not move:
  • foreign material is inside the lens or
Solution Follow all of the steps listed below.
  2. If the camera does not display an error after the reset and appears to be functioning properly, it is imperative to check and update the firmware. The firmware update corrects the lens positioning issue that can cause E104, E105, and E106 errors with the camera. Determine if an update is needed by following the steps below to check the current version of the firmware on the camera:
    4. If the version of the firmware is lower than 1.12, then the firmware update is required and should be performed immediately. See the HP document Recommended Firmware Updates for Photosmart 733 and 735 Digital Cameras .
Jun 23, 2008 | Cameras
Sony Cyber-Shot DSC-T1 Digital Camera Logo
135 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
