Question about Garden
How many turns on the pulley cord before installing back in its position for a hayter harrier 48 pro lawn mower.
  • 1 more comment
  • Anonymous Mar 16, 2014
    fitting drive belt
  • Anonymous Mar 19, 2014
    hayter harrier pro
  • Anonymous Mar 28, 2014
    front of mower is too high have to lift back to keep low
  • 154 Answers
I would go 4 turns to allow enough for pulling arms length
Posted on Aug 07, 2009
Where is the oil drain on hayter harrier 41
quite likely it is under the desk where the blade is .
Jul 12, 2015 | Garden
Which way does the bolt turn to remove the blade from a hayter harrier 41 mower
You can figure this out by checking the direction that the blade turns when it is operating and the bolt will tighten the opposite way because if it turned the same way it would loosen off when the motor was turning the blade, so almost univerdsally it will loosen clockwise and tighten counterclockwise.
Sep 19, 2014 | Garden
Hayter harrier lawn mower why slow going up a slight incline but runs away going down
Indicates lack of power, but that is normal to a degree. Are you saying it's worsened? Start by cleaning thoroughly then drain all fuel and put freshly bought fuel in. Then you can start to fault find if it's still bad.
Jul 15, 2014 | Garden
How do you replace a broken cord in a hayter lawn mower
hi there i got a hayter lawnmower i want to know how to change a self propelled cable
Apr 06, 2012 | Garden
My Hayter Harrier 41 lawnmower starts but keeps cutting out? what could the problem be?
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
May 25, 2010 | Garden
Starting my petrol mower
depending on age of machine set the throttle to maximum revs,and pull the starter cord but newer models have a primer button located on carburettor which is locked just under air filter (black or red colour) push it three times( you should hear it inject fuel) and then pull starter cord,some of these engines have a pre-set throttle ,main concern is that if it has not been used for some time you will need to clean carburettor out,replace diaphragm and remember to use fresh fuel(not older than 90 days) this should cure your problem
Mar 22, 2009 | Garden
Garden Logo
334 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
