Question about Sharp AL 1631 Copier
Scanner not wanting to move
Scanner moving 1/2 inch and then returns home
  • geniosity Nov 25, 2007
    paper mis feed symbol is flashing but can't find anything either
  • geniosity Nov 26, 2007
    not paper misfeed symbol, its the power saving feature symbol sorry, still won't work,,,,,,help!!!!
  • 54 Answers
Scanner lock is enabled. Scanner lock is located below scanner where pages come out after printing near the left side. turn it a quarter turn and turn copier off and on again. Should solve problem. If not, then scanner could be dragging on a loose mylar under the glass that guides the ribbon cable. To fix this, you would have to remove the glass.
Posted on Dec 03, 2007
When plugged in via usb, the LIDE 600F scanner makes a high pitched buzzing noise and will not start up.
The scanner is not able to find the home position to start.
Hence open the scanner and check to make sure the scanner assy. is moving to the end and when it senses the home position it will try to move a little away from it and then return back. But if the sensor is dirty or broken it will make a loud noise like belt slipping.
Try to find the sensor on back of the Tube assy. and try to fix it.
Jul 23, 2011 | Canon CanoScan LiDE 600F Flatbed Scanner
My scanner screen says that the scanner bulb is warming up,but nothing happens. Also my cancel light continually flashes. What could be the cause of this?
Scanner Bulb Error Message
A Scanner Bulb Error message is received as a result of the HP LaserJet 3300mfp series product scanner's inability to find the home reference point.
Perform the following steps to walk the scan assembly from the home base and resolve the issue.
Remove and replace the power cord from the unit.
Wait approximately 35 seconds for the scanning assembly to "walk out" and then quickly remove the plug again.
Repeat steps 1 and 2, three to four times until the head moves approximately 1 inch away from its normal resting place.
Replace the plug and let the product fully finish the boot cycle.
If this does not resolve the issue or the issue returns, upgrading the product firmware may help. The firmware upgrade can be found at the HP Web site Downloads, Drivers, and Notifications page .
Hope I help you a bit.
You can also send me questions on my
personal email - christian4122@yahoo
Your's Truly,
Christian from HP
Mar 27, 2011 | HP LaserJet 3330 All-In-One Printer
Is there a way to clean a Sharp fax machine? Unsure of model # as i am at home and it is at work. Persons receiving faxes have a dark, 1 1/2 inch wide line along left side of fax so unreadable.
Sep 13, 2010 | Sharp Office Equipment & Supplies
When try to scan, lamp warms up then message received is scanner could not scan. 22 is NOT blinking. The scanning mechanism begins move across the page but only moves about half inch.
The scanner may have one of two problems:
1. Scanner lamp has failed or does not come up to full color temp
2. Scanner attempts to initialize, which means it must move a bit to what is the "home" position where the scanner actually reads a very small coded imprint on the underside of the glass. If this area is too dusty or dirty, that will cause this problem, but also if the scanner motor and worm drive are binding for any reason, such as the scan rails internally being too dry this will also happen.
Locate a service manual and remove the copy glass by removing the lock guide on one side, the glass should lift partially, allowing some gentle cleaning with soft cloth and glass cleaner. Do not attempt to force the scanner to move inside, as it is worm gear driven and such an attempt will strip the nylon gears or worse.
Follow the manual instructions if you need to fully remove the top
cover, glass and platen assembly for cleaning. It is very simple once you are in the interior...but gentleness and care are necessary.
Sadly, parts are difficult to find for all scanners now, and it is often far more economical to replace with a new, low cost and higher performing, higher rez unit for $ 120 or less. Often a lot less.
Good Luck!
Aug 03, 2010 | HP ScanJet 4500C Flatbed Scanner
Fujitsu scanner light bar will not return to
When you face such errors, please check if the Scanner panel displays-"E-0" and TWAIN displays- “The running system is abnormal. Please confirm the carrier lock has come off.”
The error is Carrier unit drive alarm. After power-on, carrier unit (FB) moves to home position, that is where the carrier unit locates when home position sensor is turned ON. If the home position sensor is not turned ON after the carrier unit has moved pre-defined steps, this error occurs.
Probable causes:
Defective sensor, motor, or carrier belt.
Also, please check the following:
1. Is there is any abnormal noise from FB motor when this error occurs?
2. Does any foreign object get inside drive unit or carrier unit?
3. Is CR belt tension loose? Loose belt should be tightened.
Hope the above information will be helpful.
Please revert if you have further queries.
Thanks & regards,
Mar 26, 2010 | Fujitsu fi-6130 Flatbed Scanner
HP laserjet 3330 keeps flashing scanner error power off. I unplug and start again. It will print and then goes back to this same thing.
Wait approximately for 35 seconds for the scanning assembly to "walk out"(move to ready position)and then quickly remove the plug again.
Repeat step 1 and 2,three or four times until the head (scanner lamps)moves approximately 1 inch away from its normal resting place.
If it does not resolve the issue or the issue returns,upgrade the product firmware may help.Visit this url
and then upgrade the firmware.
Feb 10, 2010 | HP LaserJet 3330 All-In-One Printer
Sharo al 1631 makes clicing noise and does not
Sounds like your scanner is jammed or the scanner motor has failed.
If you are so inclined, turn the power off, you can remove the glass and try to move the scanner by hand, if you can't move it then it is jammed, if you can move it to the middle and turn the machine back on, does it return it to its home position? if so, the motor may be OK, but the control board may have a problem, if not, the motor have likely failed.
Hope this is of some help.
Apr 30, 2009 | Sharp AL-1655CS Copier
HP LaserJet 2840 Scanner Error
when poering on this HP 2840 it says" Scanner Error 5"
what does it mean? How to get a solution?
Apr 16, 2008 | HP LaserJet 2840 All-In-One Printer
Visioneer scanner light barely moves HELP!
first u need to install proper drivers for ur . If installed then this may cause due to scanner hardware problem. This can be repaired . Go to ur scanner Provider for reparing. Thank you.
Aug 14, 2007 | Visioneer OneTouch 7100 Flatbed Scanner
Will not scan
With the power off & the machine unplugged, remove the scan glass & move the scanner a few inches from "home" position. Plug in & turn on machine. Does the scanner return to home position? If not, you either have a bad scanner motor or scanner cable. I'll look for you to post the results of the scanner drive test.
Jun 19, 2007 | Canon PC-1080F Copier
Sharp AL 1631 Copier Logo
80 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
