Question about Frigidaire FRS23H5AS Side by Side Refrigerator
Water leaking frigidaire frs23h5as
My frigidaire leaks water all over the floor. I think it is coming from inside, because water freezes at the bottom of the freezer under the basket. It builds up pretty good and freezes the basket as well. In the very back of the freezer there is a hump and a small metal pan that sits there and a drain hole. I think that is where the water is coming from. The drip pan underneath is bone dry and looks like the hose is there in place. Any comments?
  • 447 Answers
Yes remove the rear panel in the freezer where you see the drain hole. Clear the ice from the drain hole. It will take a while for the water to start to drain because the ice is deep in the insulation. A small tube is helpful to draw some hot water in and stick in in the drain hole and squirt the hot water down in the hole.
Posted on Nov 25, 2007
Sometimes I see water under it. And the pan is always dry. Is there a clog somewhere in the line?
The water is from the melted frost of the defrost cycle. The drain at the bottom of the back wall of the freezer is blocked so instead of the water draining into the pan where it will evaperate,it's pooling on the freezer floor and freezing, in many case when the floor indent is full the water will leak onto the floor.By pulling the refrigerator out from the wall,there will be a tube behind the service panel on the right side when looking at it from the rear,that tube can be removed and cleared,then clear the nozzle it connects to inside the freezer.
I hope this helps you to stop the leak,
Aug 18, 2011 | Frigidaire FRS6HR45KS (26 cu ft) Side by...
Frigidaire Fridge Freezer forms huge iceblock inside fridge back wall. It freezes up whatever is stored in fridge i.e. vegtables, cheese. Water leaks onto the floor from under the vegetable containers. ...
the defrost drain pan is plugged up,you need to defrost it and run a wire down the drain tray hole so it can drain to the bottom as it defrosts otherwise it defrosts and runs everywhere else and re freezes
Jun 05, 2011 | Frigidaire GLRT86TES Top Freezer...
Water is leaking in the bottom of the freezer, also coils are freezing up with ice, this problem is causing water to leak onto the floor from the freezer
when the cold coil is freezing up this is caused by a failed defrost system ( a bad heater or terminator . or the aditive defrost control . it also will freez the drain in the back of the freezer and this will cause the water to end up on the floor . . i would defrost the frig and repl the terminator . the heate is usualy good . and if problem comes back then replace the a d c . // the a d c pt # 241508001 and the terminator 5303918214 . this is a very common problem .. mm hope this helped and thanks for using fix ya ..
Oct 31, 2010 | Frigidaire FRS3R5EMB Side by Side...
Water setteling on bottom of freezer side and freezing also leaking. 2 fridges both doing the same thing . leaking on the inside and freezing and underneath water is leaking.
Clean out the defrost drain. There is a drain in the freezer that lets all the defrost water run under the fridge. If that gets clogged then all the water runs into the freezer and can even leak onto the floor
Sep 13, 2009 | Refrigerators
Water leaking onto floor when defrosting automatically
There are many reasons for this happening for example water leaking from a water supply line for the dispenser or ice maker, a crack in the defrost pan, water leaking inside and draining through the refrigerator cabinet, but most are cased by a defrost drain line blockage. Below is a link that may be helpful so try to take it all in and use the parts that most refer to your specific problem, Thanks Sea Breeze HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
Sep 04, 2009 | Frigidaire FRS26R4A Side by Side...
Water collecting and freezing in bottom of freezer
Hi, Remove the rear inside panel of the freezer and locate the drain hole under the evaporator coil. Remove the ice and flush the drain hole with hot water to make sure it is free. You can try running a soft wire through the drain also.
I hope this helps you. Please let me know if I can assist you further.
Jul 04, 2009 | Frigidaire FRS26R4A Side by Side...
if the washer is still leaking, take the outlet pipe and place it in a dish on the floor , the water is greater and should come out of the pipe, keep watching until empty . remember there can be a lot of water in a washing machine
May 12, 2009 | Frigidaire ATF6000ES Front Load Washer
Water building up on the bottom inside the freezer side
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freezer.
Apr 19, 2009 | Frigidaire Gallery Series GLRT83TEK 30"...
Water leak
What's happening is when the fridge goes into defrost water goes thru the drain and is seeping into the crack by the damper which will run into the fridge section.  Why?  The drain doesn't come down far enough for all the water to go down the drain tube.  Frigidaire has a new drain that is longer and will prevent this problem.
Oct 22, 2007 | Refrigerators
Frigidaire FRS23H5AS Side by Side Refrigerator Logo
537 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
