Question about Brother Multi-Function Center MFC-665CW All-In-One InkJet Printer
Paper Jam I have a brother mfc 665cw and the paper jam error comes up. I have cleared the paper jams several times. I thought there may be paper still jammed somewhere where I couldn't see it. What I do to clear it is raise the scanner bed and then close it. The paper feed then ejects the paper on it's own. Which makes me think it is an ink problem. I have had a problem with black ink leaking everywhere and it left big blot marks on my printouts. I have cleaned up the excess ink spills as best I could but the jam error still persists. Any ideas?
  • hwmatt Aug 02, 2009
    I had cleaned the printer head carriageway so I thought the problem had been fixed. But it didn't. I moved the printer head to the middle of the carriageway and ran blotting paper across the underside. I also cleaned the spot where the printer head returns to. There must be some sort of sensor which detects when the paper edge aligns with the print head so the print cycle can start. Ink must have been covering this sensor.
    This fixed the paper jam problem but then no ink came out so I ran through a few cleaning cycles and now everything is up and running hunky dory.
    I think there still will be some leakage so I'll have to replace the printer head sometime in the future.
    I hope this helps someone else who is having similar problems
Beni S-P
  • 1006 Answers
SOURCE: Brother Intellifax 2820 repair + automatic document feeder + sensor
Brother Error Codes
RAM clear (most models)
Quickly press function * 2 8 6 4
Display should read maintenance
Press 0 1 for a full ram clear, or 9 1 to retain user data
Display should read reinit for a few moments then redisplay maintenance
Press 9 9 to exit the maintenance mode
Other maintenance mode switches:
01 ram clear (see 91 below)
02 scanner initialize (feed a white sheet, then a black sheet)
05 white level
09 print test
10 modify soft switches
11 print configuration list
16 panel test
19 CML test
20 signal test
21 tonal test
23 filter RX
54 scan edge
55 scanner area
66 test print memo
75 display drum life (if enabled on laser models)
76 reset drum life counter (laser models)
91 parameter initialize (user programming remains intact)
95 protection
B2 error = scanner or power supply error
Brother 950/980: On copy or transmit they may produce black pages. Prone to bad scanner (CCD). Brother may provide a replacement CCD at no charge to the original owner. Sometimes leaving the unit unplugged for a few hours will solve the problem temporarily.
Brother HL600 series laser printer toner will work in the laser fax & multifunction machines (part number TN100HL = TN100PPF). Drum units may be interchangeable as well (?).
Brother 1350/1550/1950: Problem: Record paper jams. Solution: Replace upper shoot. P/N UF6058001. Although there seems to be nothing causing the jam, the upper shoot gets stress marks on the ends. Replace even though it is not broken.
Thermal Transfer Machines: Only one side of the page is printing. Caused by the printhead latch being cracked. The latch is blue in color there is one on each side of the printhead, replace both latches
Posted on Nov 07, 2007
SOURCE: Brother MFC 7420 Paper Jam
After changing the drum, toner and running around town for days trying to find a reliable place to get this printer repaired, I realized I was spending a lot more money than what the printer actually costs. the drum was over $100, toner was $80, and the printer is $250. I bought a new one, and I can now use the old one for parts.
Posted on Jan 16, 2008
SOURCE: Document Jam
I finally found a black lever that retracts when the paper placed in the ADF moves over it was stuck in the 'down' position. I took tweezers to pull it back up and unstick it. To find the lever open the ADF look above paper feed roller just to the right of the first metal bar with the spring on it.
Posted on Mar 01, 2008
SOURCE: Document Jam Error Message on Brother MFC-8660DN
I had the same problem with a Brother MFC-8460 and called Brother's support line. The solution that worked for me was to lift the top cover where the sheets of paper go through when you fax. On the right of the black rectangluar piece with grey roller there is a slot in the tray with a black lever inside. The black piece was stuck down inside the slot and had to be popped back out. Once it was out I hit the stop button and it was fixed!!
Posted on Apr 24, 2008
  • 22 Answers
SOURCE: My Brother MFC 9440cn keeps giving a paper jam
try seting the paper to A4 not leter
Posted on Jan 04, 2010
How can we fix when a mesage says unable to print 50?
paper jam or some sensor problem, clear the paper jam, or clean the sensor under the pump.
Jul 30, 2014 | Brother MFC-665CW All-In-One InkJet...
Paper jam on screen will not reset
To clear the error message Paper Jam after you removed the jammed paper, open and close the scanner cover.
If you still receive the error message, a small piece of paper may be stuck inside your Brother machine.
Refer the below link for the steps to remove any ripped paper remaining inside your Brother machine:
still receive the error message Paper Jam after removed the jammed paper...
Apr 22, 2014 | Brother International Brother MFC-J4510DW
Im getting unable to print 50 error on my brother mfc 665cw
The paper jam you had probably lifted the long, thin, plastic encoder strip out of its slot. It is making the printer think paper is still jammed. Try gently pushing the strip back into the slot. You might have to use a screwdriver or other thin instrument to get to the strip.
Be sure printer is off when you do this.
Sep 18, 2011 | Brother MFC-665CW All-In-One InkJet...
Have an Error 51 on Brother MFC-210C all in one printer?
I can help you with your Brother MFC-210C error 51 problem.
Error 51 refers to a paper jam error.
Clear the paper jam to clear the error code.
If the error code will not clear after clearing the jam, resetting and powering off, the printer may require service.
I hope that helps.
Aug 30, 2010 | Brother MFC 210C All-In-One InkJet Printer
I'm getting an error saying Unable to print 30
  1. Clean all feed wheels and guides with methylated spirits.
  2. Look for any switch or guide that may be bent or out of place. This could have been damaged when a jam was removed.
  3. Look for any small piece of paper or staple that may have lodged in the paper path somewhere.
  4. Ensure the paper is dry. Not stored in a cupboard in the kitchen or the printer is not setup infront of an air vent.
Nov 17, 2009 | Brother MFC-665CW All-In-One InkJet...
MFC-665CW "unable to print" 50 error
Did you have a paper jam before this happened? If yes then the paper must have pushed the encoder strip out of alignment. You will need to turn off the printer and then push it back into slot to fix it. Let me know if you need more help. Sai.
Jun 11, 2009 | Brother MultiFunction Center MFC-440CN...
I have a brother mfc 665cw printer, had a printer jam, cleared the jam and now recieve unable to print 50 error, unable to copy or print. Have found some information about the encoder strip but I have no...
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 05, 2009 | Brother Multi-Function Center MFC-665CW...
Paper jam
give this a shot
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jul 08, 2008 | Brother Multi-Function Center MFC-665CW...
Brother Multi-Function Center  MFC-665CW All-In-One InkJet Printer Logo
70 people viewed this question
James Cagle
James Cagle
Jim Keysor
