Question about LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard Drive
My Quadra will not format
After a long wait fomating the quadra everything seems to run smoothly until it reaches 99% formated, then I get a could not be failed formating box flash up.?
please help as its driving me insane
  • 3,153 Answers
I devised these simple steps that tend to remedy quite a few issues with most portable / external hard drives (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply
Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again.
If you checked and fixed anything there and still have issues carry on reading.
Go to your control panel and then administrative tools, select Computer Management.
Now select Disk Management and expand the window.
Your drive should be listed here, if not then you need to check your computer hardware has not got any issues before proceeding.
If your drive is listed and says healthy then right click on it an select Properties, click Tools and then Error Checking, Check now, tick the two boxes and then Start.
This will attempt to fix most minor / common errors on the drive. It may also ask you to restart which is fine. Allow it to finish its work or you could corrupt the drive. If all went well you should be able to use it normally again.
If you drive was listed but did NOT say healthy then right click and select Format. Choose NTFS as the file system and do not tick any boxes you do NOT want quick format. Again start and let it do its thing. When it is done restart your computer and you should be good to go.
If you still have problems with the drive you might want to look at other areas.
Posted on Aug 23, 2009
I am trying to set up the LaCie d2 quadra. I follow the steps in the manual but nothing is loading to My Computer.
you will need to go in Disk Management and format the drive first then it will be available in My Computer.
Regards,
Dec 30, 2010 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
I am trying to format my lacie 4big quadra raid drive for FAT 32 so that I can use with Mac and Windows. My windows machine won't recognize it so I am not able to format and use with both Mac and Windows....
You cannot format a 4GB drive ALL under FAT32, it is NOT mathematically possible IT will be possible to Break Up the drive into Partitions, and then Format them FAT32. You need to keep each partition under 1GB.
Mar 13, 2010 | LaCie 4big Quadra 4000 GB
4 big quadra 6 TB, win7.0 pro,i can see the unit, format it,etc. but always in raid 0, the unit doesn´t change when i tried to reconfigure it to raid 5, and i have followed the lacie instructions
The hard disk might originally came from a computer with raid 0 configuration that is why no matter what you do to reformat, it will always give you the same drive space as your Raid 0. The solution to your problem is actually deleting the partition first from another computer before formatting.
You will be needing a windows installation disk and you can plugin the big quadra thru the usb cable in another computer. Run the windows installation disk (this could be xp or vista) and when it prompted you to choose a task, just press enter to start windows installation (DO NOT press R to go to recovery console). Next, the system will search of every available partition and will show you the drive partition for your Big Quadra. Select for it and delete the partition from there. After it has been deleted, you can cancel that installation process from that computer and try re-formatting your drive into Raid 5 again as you have been doing before.
Should you have any question, please feel free to ask. Good luck!
Feb 24, 2010 | LaCie Computers & Internet
I have the same issue
Win XP will not be able to recognize whole 3TB storage drive. You need to use some kind of 3rd party utility and then partition it and format as well.. AS a note win xp size is limited up to 80-100 GB.
Sep 22, 2009 | LaCie 3 TB Biggest Quadra External Quad...
I'm running Windows XP professional. Have plugged in my Lacie d2 Quadra (500 GB). Device manager shows that it is working properly, but it is not initialized and it doesn't show up on my windows...
1.
log onto d computer as administrator
2.
start->my computer->manag
3.under storage->disk management
4.ef intialize ndcovert disk wizard appers click next ef not skip to step 8
5.on d selct to disk intialize page click next
6.on d select to disk covert page click next
7.on completing dhese two click finish
8.right click u r external drive nd click format
9.in d format dialog box type d name for u r external hard drive nd then click ok
10.click ok again
Sep 14, 2009 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
WIndowx XP can't see my LaCie Big Disk 3TB
did you checked disk management? is it formated to basic or dynamic?
Jul 10, 2009 | LaCie 3 TB Biggest Quadra External Quad...
I need to be able to use this hard drive on my pc
DataViz makes a product called MacDrive7 that can be installed on a Windows PC that will enable it to use pretty much any kind of device that has been formatted for a Mac. The other option would be to format the drive for a PC since a Mac can utilize PC formatted disks, but you will lose options like forks, etc that are Mac-specific.
Jun 01, 2009 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Disk manager only sees 25% of it
your partition size is incorrect not disk manager
Apr 27, 2009 | Computers & Internet
How to format the LaCie 500GB d2 Quadra for Windows XP??
This way it should work...
Connect your drive to the computer...
Go to: Start > Control Panel > Administrative Tools > Computer management.
A new window will appear...
Select Storage > Disk management on the left of the window.
Now you will see the different drives that are connected or part of your system.
One of the drives listed there is your LaCie, i think you'll recognize it by name...
Right-click on it, and select 'format'
In the new window, select the new volume label (as you like it), the file system (use NTFS), and set allocation unit size to default.
Make sure 'Perform a quick format' is not checked...
Then click OK. Your drive will be formatted now... Don't interrupt the process
Mar 31, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
LaCie d2 Quadra drive... not showing up on PC after working on a MAC
You need to make sure the drive is formatted for the PC. The Mac will read and write to a FAT32 partition, but the PC cannot see a Mac formatted drive as you have seen.
The only problem is that there is a 32Gb limit per partition for FAT32 drives.
It's not ideal but it's the best you can do easily.
Jan 13, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard Drive Logo
90 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
