Question about Samsung SGH-d807 Cellular Phone
Speaker phone option
Is there a speaker phone function on my SGHD807 and if so how do I use it?
  • Samsung Master
  • 456 Answers
Re: Speaker phone option
Yes dial any number and then press the okm button in the middle
Posted on Nov 30, 2007
0 characters
3 Points
Turn off the phone speaker when ear phones are connected?
that is a function of the ear phone jack some aftermarket buds do not plug far enough in to disconnect sound going to internal speaker tray another set
Jan 02, 2015 | Samsung Galaxy S 4G Cell Phone
How do I turn on the speakerphone
Jul 18, 2011 | Cell Phones
My Samsung Wave 525 speaker is not working.
When phone speakers stop functioning the first thing you want to do is try increasing the volume. After increasing the volume to the highest and still the speaker does not work then you are left with no option than to refer to an expert to help fix the speaker by putting in a replacement speaker.
Although there are usually 2 speakers, the loud speakers and the headset speakers if it is the headset speakers then you dont hear what is being said on a call you can use an earpiece or bluetooth device pending when you can get it fixed.
Hope this solution has been helpful?
Jul 17, 2011 | Samsung Star GT-S5233 Cell Phone
My speaker does not work
Hi, what makes the speaker of your cell phone not working is because the flex of the cell phone is damaged and it controls the function of the Speaker.
The flex look like a thread like object inside the phone. it connects the front sliding board of the phone to the lower sliding board of the phone. It controls the function of the RInger and the speaker of the cell phone.
When the flex gets damaged, it affects the ringer and the speaker of the cell phone.
When you replace the flex of the cell phone, the speaker will function again.
Hope it helped.
Thanks for using fixya.
Feb 11, 2011 | Samsung J700 Cellular Phone
Can't hear call from the ear piece only on speaker
There could be a Three problems. In all cases you have to get it serviced.. Cause no.1_ Your ear speaker has stop functioning. Cause No.2_ There could be a connection loss with ear speaker. Cause No.3_ IC which looks after ear speaker has stop functioning..
Hope this has helped you.. Please rate the answer. Thanks
Jun 23, 2010 | LG CU515 Cellular Phone
I can not find a way to use the speaker phone. for the samsung s5230 tocco lite. When I get a call. It says press the hold key to use in call function. But how do I get to the speaker phone.
There is a 'Lock' (a lock mark on the key) key on the right edge of your phone.
While on call if you press that for 3 seconds you will see the in call functions of the phone, you will also see a 'speaker' icon.
Press the Speaker icon and then Yes on prompt. Your phones speaker function will be on.
Hope it helped.
Jun 17, 2010 | Samsung SGH-S5230 Cell Phone
I would like to know if there is a speaker phone option on the Samsung t301g and if so how do you activate it.
yes, the speaker phone is available in samsung t301g
steps to activate the speaker phone
the speaker phone is activates
  • when phone is ringing
  • it shows 'option' on the lower right or lower left of the screen
  • click on the options then there is speaker option
  • click on it & speaker phone is ON
Thank you for using FixYa!
Do have a nice day and please remember to rate this solution.
Best regards,
Jan 05, 2010 | Cell Phones
How can I use the speakerphone in s5233w?
Hello Sir,
It sounds like you want to use the speaker phone at times of calling. When you receive the call and the other person id on-line, then keep the Keylock hard key found at the left side ( opposite side of the multi-functional jack ). When you see that the back light is on, you will see 6 options. They are "Join", "Headset", "Mute", etc. There will be an option shown " Speaker ". Select it and select " Yes " to confirm. Now the speaker phone will be in work.
Thank you Sir,
Have a nice day.
Dec 14, 2009 | Samsung Star GT-S5233 Cell Phone
Can't find the hands free speaker button
In an increasingly hands-free world, the external speaker feature of cell phones has increased the usability of cell phonesmag-glass_10x10.gif in the car, public transportation and at work. The volume controls on the external speaker controls can be somewhat difficult to find and manipulate.
  1. Step 1 Make sure the speaker setting is actually on. If the speaker is turned to off, the volume you hear will be coming from the earpiece and will be very low indeed. Sometimes there is a button on a cellphone which you can simply press and hold to activate the speaker function. You will notice a difference immediately.
  2. Step 2 Check to see if you have external volume controls. On some models, there is a button or two buttons that adjust the volume of both the handset and the speaker volume. If you have these buttons, use them to adjust these controls while on calls. Remember that adjusting the speaker volume will subsequently adjust the handset volume once you've turned off the speaker mode.
  3. Step 3 Access the sound controls in your phone. If your phone does not have external speaker control, it can be accessed by adjusting the controls saved on your phone. Also, the main settings can be controlled even if you do have external controls. Phones are different, but in your menu of options, choose sound and sound controls. This should give you options for ring volume, alarm volume and handset volume.
  4. Step 4 FInd volume controls for all settings. If you wish yo have multiple settings for each function---alarm, calls and speaker---you should be able to adjust these accordingly. Search through the control options until you've found speaker controls. Choose the setting you desire and save the settings.
  5. Step 5 Using the main volume as a foundation, use the external controls (if applicable) to adjust the levels.
Nov 15, 2009 | Cell Phones
Flip up ear speaker stopped working
Sounds like the ear piece connection between the two halves of the phone has been broken. Your "speaker phone" function should still work because the sound comes from the back of the main body of the phone. To the best of my knowledge, this can't be fixed. You will need a new phone. I hope this helps.
Mar 29, 2008 | Sanyo Katana SCP-6600 Cellular Phone
Samsung SGH-d807 Cellular Phone Logo
22 people viewed this question
Top Samsung Cell Phones Experts
Steven Wander
Steven Wander
Fred Sops
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
