Question about Car Audio & Video
How to gain access to front door speakers in volvo v50 2005?
  • 2 more comments
  • closeprotect Aug 01, 2009
    How to gain access to front door speakers in volvo v50 2005 ?
    How to gain access to the speakers in a front door of a VOLVO V50 produced in 2005 ?
    Hi There !
    Thanks , but I need specific info how to take off grills or the whole door panel to get to speakers . The become loose and rattle a bit. I need to get to its mounting , but how to take off the panel : exactly? step by step , screws? pins ? clipses ? where , what how?
    thank you
    chris
  • closeprotect Aug 03, 2009
    Brilliant ! Exactly what I wanted !!!!!
  • 2,200 Answers
Hi
There is a complete walkthrough with loads of guidance and pictures on how to do this at this link
http://forums.swedespeed.com/zerothread?id=96923
The first half of the guide is the part relevant to your question and shows the speakers in situ and how to remove the door trim to get at them.
Hope this helps. Please remember to rate my answer. Many Thanks.
Posted on Aug 01, 2009
  • Radio Code Pro
    Radio Code Pro Aug 01, 2009
    Please do let me know if this resolves the issue and rate my answer accordingly. Thanks.
    President:
  • 2,923 Answers
What do you mean by gain access to front door speakers in Volvo V50? Are you trying to remove or replace the front door speakers? If yes, you have to remove the grills first.
Removing the grills, push in the panel and then melt the backside to keep it in there.
OR:
Remove the door panel, which is not too difficult on the 440, and cut the trapezium shaped recess to allow the grille to sit inside. Fix the grille and infill with MDF.
Hope this helps, but if you're referring to another meaning of gain access, please let me know.
  • 19,396 Answers
  • Ginko
    Ginko Aug 01, 2009
    I have sent you a movie showing the step by step procedure.
    If you have to replace the whole wiring , or to adapt an aftermarket speaker , you may have to remove the door panel, that is held by few screws mounted behind the handles and a series of clips placed near the edge of the panel.
    Here is the V50 door :
    If you do not have to replace wiring, and you are installing a standard factory speakers, all you will need to do is removing the small panel on top of the speakers, and replace the speakers.
    If all you need is installing a standard size speaker you can follow the instructions on the movie displayed on the page below, they apply to your Volvo, and the movie had not been selected randomly.
    Click on this page.
    Select How to Install Car Speakers -Play Flash Video from the bar on the left and follow instructions.
    Regards.
  • 13,433 Answers
You will most likely have to open up the door, I would recommend buying a repair manual.
REPAIR MANUALS FOR VOLVO
Manual free
Get some wd-40 and try to get the hinges and latch of the fuel door.
Sep 14, 2013 | 1999 Volvo S80
Cant find fuses
On these Volvo models, the common fuse compartment is located on the very edge of the dashboard - you will need to open the door wide open to gain access to the fuse cover. The other main fuse box, is situated next to the engine bay firewall, on the driver's side (refer to diagrams below).
Nov 01, 2011 | 1995 Volvo 960
@How do I gain access to the rear speakers on 97 Mercury Villager
You typically have to remove the entire door panel to gain access.
Aug 25, 2011 | 1997 Mercury Villager
Radio wire colors
1994 Volvo 940 Car Audio Wire Diagram
Car Radio Battery Constant 12v+ Wire: Yellow
Car Radio Accessory Switched 12v+ Wire: Red
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Light Orange
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 5 1/4′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Blue/Yellow
Left Front Speaker Negative Wire (-): White
Right Front Speaker Positive Wire (+): Gray/White
Right Front Speaker Negative Wire (-): Gray
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Yellow/Brown
Left Rear Speaker Negative Wire (-): Yellow/Green
Right Rear Speaker Positive Wire (+): Green/Brown
Right Rear Speaker Negative Wire (-): Green
Hope helps (remember rated this) TY for use Fixya.
Jun 03, 2010 | 1994 Volvo 940
How do I gain access to the passenger side speaker in an Chevrolet Impala '06?
you have to remove the door entire door panel to gain access
Mar 14, 2010 | 2006 Chevrolet Impala
HOw do I replace front speakers on 1991 brougham?
you'll need to remove the door Panel to access the door speakers,the door panel will be held in with several screws.
I believe the Front Door Speakers in a brougham of that year are 4x6".
Mar 04, 2010 | 1991 Cadillac Brougham
Remove passenger door pannel
remove screws (several... front, bottom.. door handle pocket (covered by round plastic button), door handle (behind. remove tweeter speaker assy (upper front corner). Interior panel pops out to gain access to whatever is behind it. That's it. Anything else?
Jun 11, 2009 | 2006 Hyundai Sonata
Front speakers work intermittently. Rear speakers work fine.
You have a short in the speeker wire probably in the door.
May 07, 2009 | 1993 Volvo 850
Front doors pre wired for speakers?
on most models, Yes. pull off the grills and check for wires , be careful though , they break easy
Dec 06, 2008 | 1991 Volvo 740
Unlock passenger door
I don't envy you; I don't see you curing this without disassembling the door panel. Linkage has broken or separated and there is no way to cure the problem without gaining access to the linkage.
Sep 07, 2008 | 2007 Volvo S40 2.4i Sedan
Car Audio & Video Logo
378 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
