Question about Refrigerators
2012 open range refrigerator is closed but won’t stop beeping. It is acting like it’s open. Please help. Thanks.
  • Anwar Alajmi
    Anwar Alajmi May 17, 2018
  • Refrigerators Master
  • 1,274 Answers
I would look for some sort of door switch that is not engaging. There has to be something that tells the unit if the door is open or closed. This is the simplest and cheapest place to start.
Posted on Apr 29, 2018
Open range refrigerator is closed but won't stop beeping
Posted on May 17, 2018
fridgetech
  • 473 Answers
SOURCE: Whirlpool Model RF376LXBN Range
What fault code is it giving you?
Posted on Nov 12, 2007
  • 5 Answers
SOURCE: My 2001 Range Rover started beeping non-stop while I am driving.
What does the dash warning say?
Posted on Jul 25, 2009
  • 254 Answers
SOURCE: My kenmore range. I set it to self clean and when
The F9 code is an indication of "Door Latch Motor Assembly". It's usually one of a couple of things that cause this:
First, UNPLUG the range and remove the back access panel. The assembly is located in the very back of the range. You'll see the wiring going to it. Check to make sure none of the wiring is shorting to ground. Sometimes it can get so hot on those wires that have been heat-cycled so many times that they can melt and short out, usually to the metal shell. Also take a look at the actuator rod. Those will sometimes freeze or jam up as well.
I hope this helps! :)
Posted on Sep 22, 2009
Macmarkus
  • 2605 Answers
SOURCE: continual beeping
Hi, welcome to Fixya A very common problem with those fridges actually. Check to make sure the door sensor`s are secure and contacting each other when the door is closed. You can do this by accessing one or both sides of the door sensors at the hinge assembly cover at the cabinet top. There should be sensor`s on either side which sense when the door is closed by "making" with magnets on the doors. They sometimes become loose from where they are held in place and therefore do not indicate the door is actually closed. That is the most likely cause. If this does indeed help you solve your issue please take a moment and rate it accordingly. If it doesn't solve the problem let me know and I'll try and assist you further. Thanks for visiting "fixya" today. good luck. macmarkus :)
Posted on May 16, 2010
Sea Breeze
  • 4655 Answers
SOURCE: damper won't close
Depending on the correct model number found inside the fresh food section will help diagnose but it sounds like either a defective temperature sensor or the damper itself is the cause. If your model number is a USA model number I can look up what part number and tell you better by looking at parts manual. Let me know the model number and I will try to help you find the correct parts, Thanks Sea Breeze
Posted on Sep 16, 2012
Frigidaire FFHS2612LS4 wont stop beeping
Hey Brandon, this is JK. Thank you for your post. I understand that your refrigerator is beeping none stop. When the door(s) have been opened for longer than 10 minutes, an audio alarm sounds and the interior lights shut off. This protects the liner from melting due to the heat produced by the light bulbs. The alarm will sound every two minutes until the doors are closed. Once the doors are closed, the alarm will reset. The refrigerator will also beep on some models to inform the user that the door has been left open and the cool air is escaping. Check to make certain that the gaskets on both doors have no gaps and that the appliance is maintaining the desired temperature. If all of these suggestions pan out and the problem still persist, think about what may have happened prior to this occurrence. For instance, did you notice any error codes, odors, or other strange functions prior to this issue? If you are still having these issues and can think of anything in particular, please feel free to reconnect.
Hope this helps!
Mar 10, 2014 | Frigidaire FRS3R5EMB Side by Side...
Sunroof on 1998 chevy cavalier z24 won't close all the way
It can be faulty motor or loose wiring issue or faulty /weak sunroof controlling switch or there is some blockage for sunroof to come down to close or sunroof out of its track the headliner is out of its way.There re many possibilities.All this basics needs to be checked.For further troubleshooting,go through this help link:----
Click the link mentioned below:------
How to Manually Close the Sunroof ? http://howtobyme.blogspot.in/2012/05/how-to-manually-close-sunroof-on-2001.html
Sunroof Stuck open? http://howtobyme.blogspot.in/2012/05/2001-lexus-is300-sunroof-stuck-open.html
How to manually close Sunroof on Navigator? http://technoanswers.blogspot.com/2012/01/how-to-manually-close-sunroof-on-2000.html
This will help.
Thanks.
Jun 05, 2012 | Chevrolet Cavalier Cars & Trucks
I have a 6 y.o. whirlpool fridge wbm 46 model that's started to make a loud buzzing/whirring noise every 15 minutes or so ( only lasts a few seconds each time). It's started doing that noise in the last...
Hi
The sound from your refrigerator can be caused due to various reasons,please check this link bellow to troubleshoot your problem:-
http://www.repairclinic.com/Refrigerator-Troubleshooting?red=Refrigerator-Repair-Help#itsnoisy
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Apr 02, 2011 | Whirlpool Refrigerators
Whenever I open the door the beeper starts beeping and continues for 19 beeps regardless of whether I leave the door open or close it again. The beeps are at approx 1 second intervels
Whenever the fridge is open it gives 19 beeps actually.In your case even when it is closed it is giving 19 beeps.This is the problem with control board.The control receives the signal when closing the door and stops the sound.Check the wiring connection to and fro the control board to the door.Control board costs high.This is small problem you can just unplug the wiring connection to the door to the board instead of spending more.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Feb 01, 2011 | Refrigerators
The alarm beep which tells you to close refrigerator or freezer door now beeps even after either door has been closed. It beeps three times at approx twenty second intervals, then beeps continuously for...
Sounds like you have a bad door switch. Depending on the age of the fridge, it might still be under warranty. If it's not, then you might be able to access the door switch yourself and pull it out & replace it.
Good luck......
Aug 15, 2010 | Fisher and Paykel Active Smart® E522BR...
Not maintaining set temps but holds steady at 31 and 61
Could you double check your model number the number above your post is nothing like the refrigerator2.gif you are describing, Thanks, Sea Breeze
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
appliancepartsse@yahoo.com
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
Aug 10, 2009 | GE PDS22LBN Bottom Freezer French Door...
Frigidaire refrigerator making beeping sound
Unplug your refrigerator from the ac outlet, and 0open theref door for approx. 5 minutes. Then plug it again, after you hear the beeping close the door. wallah it's fixed.
Dec 21, 2008 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
296 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
