Question about Saws
When cutting softwood/ hardwood should the saw
When cutting softwood/ hardwood with a dw738 should the saw speed be slow or fast
    Scholar:
  • 173 Answers
The blade should only be on a slow speed, for intricate work.
(To make sure that whatever you're cutting, doesn't get too excited.)
Otherwise, it should generally be on the fastest setting.
Thats it, oh except, be carefull and mindfull of what this baby can do;)
Don't forget to rate, thanks
Posted on Aug 01, 2009
  • 142 Answers
I have found i my years of carpentry, you cut as fast as the lumber will allow. This means that, with at sharp blade, the lumber will tell you how fast you should be cutting. Don't force the saw through the wood, just keep and even pressure while pushing through the cut
Slows down and stops when trying to cut hardwood
You just do not have a saw that has enough power, the blade is dull or both. Change your blade and push the wood through slower or get a more powerful saw for the hard woods.
May 11, 2016 | Delta Saws
Cuts are bowed
I heard that the rod that it rides on, may be bent. This is the rod, that you normally adjust, to get your straight cut, parallel to the blade. One mans solution was to turn the rods, so the bend of the rod, was vertical, rather than horizontal. You may want to look into ordering new , hopefully straight rods, from QEP too.
Jul 13, 2013 | Qep Tile Tools 83200 24inch Bridge Saw
The saw is producing blue acrid smoke upon use. I am using a vacuum to evacuate the shavings, but the saw itself does not seem to be cutting the wood. I am using a hardwood and feeding it slowly into the...
check the blade, it sounds like it is burning the wood instead of cutting it. I would recommend using a carbide tipped blade for the hardwood. Let me know if you need more assistnace.
Sep 11, 2011 | Ryobi Saws
Replacement blade
Use a 10" blade. As for the number of teeth...the more teeth the finer the cut will be. The only drawback is a a finer toothed blade will cut slow. For your purposes I'd suggest a fine toothed blade.
Mar 07, 2010 | Craftsman 10" Table Saw
Reduce bandsaw speed to cut metal
My old delta has the transmission on the back for cutting metal, and it is geared way down for power, 1140 would be way to fast, It is more like 40 rpm. I don't know if even a set of step pulleys would slow you down enough. Depends on the metal. I have the step pulleys too, but never bother to change them. The transmission, you just pull out the lock in the center of the pulley and it throws it into back gears. real nice, has an oil filled gear box on the bottom. Everybody wants my band saw!
Feb 23, 2010 | Delta Woodworking Delta Rockwell 14 Inch...
I'm feeding 8/4 alder through the powermatic strait line saw
Sounds like the power feeder is not holding it secure at the end of the pass. Is the outfeed table running level to the saw table?
Just a wild guess, I'm afraid. I haven't used one myself.
The only time I've seen blades wobble like that was when they were light plates, undersized for heavy duty ripping operations. It's truly frightening to watch them overheat and turn to butter like that. I'd recommend getting a heavier plated saw blade if there's any question about yours.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 26, 2009 | Saws
Blade Types
remember to match the blade width to the type of cutting you are doing. Also keep in mind: * Narrow Blades can make much tighter radius cuts, but tend to twist and wander when making long straight cuts. * Wide Blades can't make the tight turns that narrow ones can, but they hold a straighter line than their narrow counterparts. * The tpi determines the speed with which the blade cuts through stock. Blades with high tpi cut slower but leave a very smooth edge. They are best for detail work on thin stock. Blades with low tpi cut quickly and leave a slightly rough edge. They are great for resawing or long rip cuts. * Steel Blades are inexpensive and work well for cutting softwood. Steel blades, however, dull quickly in hardwood. * Bimetal Blades are made of high-speed steel and can cut thin metal or wood. * Carbide Blades are for wood cutting only. They are more expensive than other blades but stay sharper longer than steel or high-speed steel.
Aug 27, 2008 | Dewalt Variable Speed Deep Cut Band Saw...
Blade type
blades are available for different applications. A few common blades include:Steel Blades are inexpensive and work well for cutting softwood. Steel blades dull quickly in hardwood. High-Speed Steel Blades are harder than steel blades and stay sharp longer. Carbide-Tipped Blades are more expensive than other blades, but they stay sharp much longer than steel or high-speed steel.
Aug 27, 2008 | Jet 708100 Jwts 10 1 1/2HP Workshop Table...
Saws Logo
90 people viewed this question
Top Saws Experts
Bill Boyd
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
