(I took too long to change the cartridge so it slid back to home position, I didn't think to just start over and moved it by hand).
Not sure if this will work for you. I started my cartridge up till it got to the centre and pulled the electrical plug out of the wall Took the old one out and installed the new one then re plugged the printer back in. Every thing started right up and stopped where it is supposed to be. Works like new now.
SOURCE: The print cartridge cradle cannot move.
"The print cartridge cradle cannot move."
I fixed this problem by disconnecting the power cord from the power-strip and connecting it directly into the wall. My printer was not getting enough voltage from the power-strip. I hope this helps.
Fiend your solution direct from hp. Here is your solution...
http://www.hp.com/printer/prob676ijt65/solution
749
SOURCE: Printer keeps saying Press Enter to align cartridges
Well you have landed at the right place.All you have to do is:
This should bypass the print alignment function and allow you to print.
If it still dosn't fix then :
Then follow the steps on this link :
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&lang=en&cc=us&product=79499&dlc=en&docname=c00042820
Thanks.
Fame !
SOURCE: brother laser printer printout
The link has been removed by Brother. It must have been really working....
Could you post the instructions directly. TY
