Question about Refrigerators
My fridge leaks water every three days. - Refrigerators
  • Brett Duxbury
    Brett Duxbury Apr 28, 2018
    Hi Joan Lloyd, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
    Fridge will have a pipe that water drains from freezer to some sort of evaporator tray at bottom of fridge. If it is blocked the defrost cycle is melting frost that does not drain away and then the fridge will leak every defrost cycle.
    Look for a drain pipe
    or help us to help you by providing make and model number of fridge and maybe one of us can find more information on where this drain pipe might exist in your fridge .
  • Refrigerators Master
  • 1,250 Answers
Mine had an issue with the drain from the freezer section. When it went into a defrost, the condensate water would miss the drain and fill the frig then onto the floor. The other issue can be the condensate pan that collects the water may be overflowing for some reason. Look for that as that could be the simplest fix to start with.
Posted on Apr 29, 2018
4 Suggested Answers
CaptainHawk1
  • 345 Answers
SOURCE: water leaking under fridge
Check your hose for your water/ice dispenser.
Posted on Nov 07, 2009
SOURCE: Why is or fridge leaking
I've seen this occur when the refrigerator door is getting closed fully Either a food item is preventing complete closure, (though it may look closed) or a seal is failing. Check the seals by pulling a dollar bill out from in between the seals. If it doesn't catch make sure the seals around the doors are ingood shape and clean.You can also use a heat gun to warm -up the seal and get to expand so you get a good suction
Posted on Oct 15, 2010
  • 35 Answers
SOURCE: my fridge freezer leaks water every two to three days any ideas why?
Actually, on most Frost Free refrigerators (which are most refrigerators manufactured in the last 25 years) there should be a small "pan" underneath that "collects" condensate. This is a normal process as, every so many hours, a small heater comes on inside the freezer to "melt away" any of the accumulated frost. This frost melts and runs down a tube and then is collected underneath the refrigerator. The external fan underneath the refrigerator causes the condensate to eventually evaporate into the room air. You might be, either in a very humid environment and it can't evaporate fast enough, or more likely that you have a missing pan to collect the condensate. If it is missing, you might get lucky with finding a small "cookie sheet" that might fit underneath. Be careful though. You don't want to touch, AT ALL, any of the coils (looks like radiator screens) underneath, or the fan blades. Best bet if you are missing the condensate pan is probably to get your model number and search for parts at a local appliance parts store or online.
Posted on Dec 15, 2011
Why does my samsung fridge leak water under the fridge when I use my water dispensor?
hi Todd.
Problem: It's leaking water. ... Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leakingout of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself - CNET
https://www.cnet.com/.../three-common-refrigerator-problems-you-can-easily-fix-yourse...
Why is my refrigerator leaking water from the bottom?If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.17 May 2013SOLVED: Water leak in refrigerator? - Refrigerator - iFixithttps://www.ifixit.com/Answers/View/128713/Water+leak+in+refrigeratorSearch for: Why is my refrigerator leaking water from the bottom?
Why does samsung fridge leak water under the fridge Google Search
Nov 27, 2017 | Samsung Refrigerators
I have a water leak inside of my maytag fridge and it leaks out onto the floor from the inside. What is the couse of this problem?
Have you checked to see if your condensation tray is too full? The tray will be located at the bottom of the fridge and should slide out easily.
Feb 19, 2012 | Maytag Refrigerators
How to resolve our "lack of water" issue..within the last few weeks, the water dispenser's water flow lessen with each day-now it does not just doesn't work
there may be a problem with the water lines or bottles in the fridge compartment is frozen raise the temp in the fridges to about 38 for a couple of days and this should unthaw the lines
Apr 13, 2010 | LG LFX25971ST Bottom Freezer French Door...
Water leaking under fridge
Nov 07, 2009 | Maytag MZD2766GES Side by Side...
Water leak in back of fridge for 2 days. All else works fine
It sounds like the fridge water supply line is leaking. Pull the fridge out and have a look. May just need tightening.
May 28, 2009 | LG Refrigerators
Leak under frigerator
leaking inside of fridge? your defrost drain is plugged and running from freezer into fridge around once a day....
May 24, 2009 | Frigidaire FRS26R4A Side by Side...
Samsung Fridge Freezer leaking water
hi August.
Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
How to Fix Water Leaking From the Bottom of Freezer
Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
SOLVED Water leak in refrigerator Refrigerator
Dec 03, 2017 | Samsung CoolTech Plus / Basic Bottom Mount...
Neff K3990 Fridge Freezer ice maker not working and water leaking out
Sounds like the water hose to the ice maker has come loose. Is it in warranty?
Jul 23, 2008 | Refrigerators
Refrigerators Logo
196 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
