Question about Refrigerators
Water coming out from under the refrigerator - Refrigerators
  • 294 Answers
Leaking under a refrigerator may be caused by a condensation tube that doesn't drain into a pan or by a clogged freezer drain.. please do check it.. cheers!!
Posted on Aug 01, 2009
Water is collecting under the deli draw of my french door samsung refrdgerator
Is this the Samsung 4-door fridge/freezer with a round water-filter between the two drawers in the Refrigerator? a) Is your water-filter correctly installed in it's place? b) check where the water-drops are coming from: it could be the ice-maker - need to call Samsung service.
Sep 28, 2014 | Samsung Refrigerators
Refrigerator leaking water
You gave no manufacturer name or model number so this is only a guess: If you refrigerator is a self defrosting one, it will periodically, allow ice building up in it to turn to water which naturally drips to the lowest point. Most refrigerators have a drain below the vegetable bins on the bottom. That is probably where the water is coming from. Solutions include putting a shallow baking pan under the bins or under the refrigerator to catch the water, then empty it periodically.
Jan 21, 2013 | Refrigerators
Water is pooling under vegetable bin at bottom of refrigeraqtor. Seems water is coming from insude refrigerator under freezer shoot. Placer plastic cup under it and it has collected water that froze....
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Aug 19, 2010 | Whirlpool Refrigerators
Water at bottome of refrigerator
Under the draws in the back, there should be a drain hole that drains water down to the drain pan under the unit. Check to make sure it's not blocked with food or frozen water.
Jul 16, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Frigidaire refrigerator has water coming out underneath, there's no water under the refrigerator, the freezer was left open and was iced over. Now the freezer is not iced over and the water is gone.
You should have an evaporator tray under the refrigerator. A certain amount of condensate is to be expected during the cooling cycle and it drips into a collector tray under the refrigerator. Heat from the compressor causes this condensate (water) to evaporate. If the tray has come out of place, or is missing or damaged, the water will not collect in one spot to evaporate and will run out under the refrigerator. Also, if the automatic defrost cycle for the freezer is not set correctly or is malfunctioning, that may also cause an overabundance of condensate to be produced and it can overflow the condensate tray. If this has been helpful, please rate me accordingly. Thanks and good luck.
Jul 10, 2009 | Refrigerators
Sound of Water coming from internal backside of freeze
Your unit was in defrost mode (happens once a day) and ice that built up over the previous 24 hours was melting and draining down a drain line to a pan under the unit so it will evaporate. This is how freezers stay " Frost free ". The water in the pan under the unit will evaporate by itself. Have a great day!
barneyluc
Oct 10, 2008 | Whirlpool ARG930 Compact Refrigerator
Side by side refrigerator has puddle under freezer
Check and clean door seal, chech defrost drain tube ad a cup of water and clorine into tube, Check drin pan and clean under refer.
Sep 08, 2008 | Sub-Zero 690 Side by Side Refrigerator
Water coming from under door
  The water line enters door thru lower hinge.  Check the connection by door hinge.  Remove toeplate to access this.
Oct 25, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
367 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
