Question about Fuji FP-988D 19" Flat Panel LCD Monitor
Monitor suddenly died..replug it and it has power for a couple of seconds but then no power..is the ac adapter the problem and needs replacing? or is the monitor history?
  • 55 Answers
No no the monitor is not history yet :)... it's your adapter maybe. try holding the adapter tightly when you insert it. check the monitor while holding the adaptor.. that should help you find out
Posted on Aug 01, 2009
Fuji fp-988 19 in flat panel turns on then goes blank [power supply ok] turn off then back on does the same thing
Posted on Nov 05, 2009
How to power on asus laptop
First, make sure to disconnect all the cables and drivers connected to the laptop.
- Start by doing a hard reboot, unplug the AC adapter then press and hold the power button for 20 seconds then try booting it up again.
- Next is to try a different AC adapter that has the same voltage and see if it will boot up or not.
- Proceed with reseating the RAM's if trying a different AC adapter will not work, remove them all for couple of seconds then put them back in making sure everything is seated properly.
- If it will still not work, connect an external monitor and see if you'll get any display from it. If there's a display on the external monitor that could mean that the problem is the built in display.
- But if there's still no display on the external monitor that means the problem lies in the motherboard.
- If the laptop is still under the factory warranty, do contact ASUS for a repair.
Mar 09, 2018 | ASUS Computers & Internet
14z wont urn on
Please use an external monitor if necessary, and please do these:
1. Unplug the AC adapter,
2. Remove the battery,
3. Remove the hard drive,
4. Press the power button and hold it for 15 seconds,
5. Plug in the AC adapter,
Restart the laptop.
If the problem persist,
Note: Do not insert the battery, and do not install the hard drive.
2. Reseat the memory (remove it and reinstall it),
3. Plug in the AC adapter,
Restart the laptop.
If those actions do not solve the problem, then your motherboard is dying.
Mar 10, 2014 | Dell Computers & Internet
Will not turn on,
Try these.
- Remove battery, press power button for at least 20 seconds. Power on the system using the AC adapter (charger).
- Use another working AC adapter if still no power.
- Make sure that the DC input jack where the AC adapter is inserted to the laptop is not broken, otherwise, replace motherboard.
- If you get power but blank screen, connect an external monitor. If you get display on the external monitor, the LCD needs to be replaced.
- If you get no display on the external monitor, reinsert the memory module/s (RAM), otherwise, the motherboard needs to be replaced.
Hope this helps.
Jul 17, 2011 | Toshiba Satellite L455DS5976 Notebook
Laptop died suddenly and is not charging
Take the battery out and discharge the capacitors by holding down the power button for 15 seconds. plug in the charger without the battery in to see if you get a charge light. If you do, replace battery and plug in charger and power on laptop. If this does not work, you may have to pull the cmos battery for 15 minutes and try it again.
Oct 03, 2009 | Computers & Internet
LCD monitor back light won't stay on
Running any device 33% higher voltage for any length of time will likely harm it. However, knowing that that worked you have two possibilities.
1. The 12V AC adapter is dying and simply needs replacement.
2. The FLR inverter(backlight) is dying and giving it some extra juice forced a little more life out of it.
Do your best to track down a propper adapter(with 5%, 11.4V-12.6V), if this works that should be your solution, if not then the FLV is dying and you may need a pro to replace it. Generally about $100 at a shop.
Hope this helps FixYa,
Chris
May 14, 2009 | Toshiba Equium 7100S PC Desktop
BenQ FP91G+ Problem
Hi...there,
Dies on 1 seconds usually caused by busted backlight inverter or AC Adapter if you got one on your monitor.
Nov 21, 2008 | BenQ FP91G+ 19" LCD Monitor
Battery won't charge
If the battery is not charging, then the charging circuit of the motherboard is bad.
Page 3-22 lists the spare part number for the motherboard. (4 versions depending on options)
Chapter 5 covers disassembly and reassembly
http://www.hp.com/ctg/Manual/c00212209.pdf
May 21, 2008 | Compaq Presario R3000 Notebook
Wii / No Power
or you can remove all of the plugs from the console: AC, remote sensor, AV. This is important: You must also unplug the AC from the electrical outlet. Then wait 45 seconds, then plug the AC adapter back into the wall and your console. Power On.
Dec 25, 2007 | Nintendo Wii Console
Samsung SyncMaster 240 T Monitors
I ordered this: http://cgi.ebay.com/14V-AC-power-adapter-for-Samsung-SyncMaster-240T-LCD_W0QQitemZ260130887919QQihZ016QQcategoryZ86707QQrdZ1QQssPageNameZWD1VQQcmdZViewItem on eBay when my power adapter died, and it worked like a charm.
Oct 06, 2006 | Samsung SyncMaster 240 T (Silver) 24" LCD...
Fuji FP-988D 19" Flat Panel LCD Monitor Logo
476 people viewed this question
Top Fuji Computers & Internet Experts
Computer Links
Victorman
Victorman
robert
Are you a Fuji Computer and Internet Expert? Answer questions, earn points and help others
