Our cubase xs program only recognises 2 vst inputs coming from our M-Audio 2626 Profire unit when we need it to recognise 16. Can you help us?
  • 30 Answers
The driver is probably in the wrong mode (asio vs. wdm etc) if your m audio has a driver panel on the computer that you can open and change like bit rate etc it should be in there
Posted on Aug 03, 2009
I have a scarlett 2i2 interface and a bluebird microphone, but the interface will not recognize the microphone. im using windows 7
What software are u using for recording (Cubase, pro-tools, reason etc) and does it recognise the line in socket
Jun 30, 2014 | Focusrite SCARLETT-2i2 2 in / 2 out USB...
Cubase studio 5 has deactivated the VST system links due to too many internal errors
In my experience, reasons for seeing errors in VST System Link (VSL) are usually due to the digital signal path (audio and/or data) not being routed properly within the System Link dialog box. If for example, you're using s/pdif between two ASIO 2 compatible audio cards properly (OUT of card #1, to IN of card #2 - then OUT of card #2 back IN of card #1), you also have to set your s/pdif System Link I/O channels in the dialog box to the 'same' channel...If say your options are s/pdif channels 9 & 10 (or whatever they are), you set the I/O's of both computers VSL dialog boxes to either channel 9, or all to channel 10. You of course need to route your digital audio properly within your audio interface! (see your cards documentation on that).
You can test if it's routed properly by 'listening' to audio from each computer, from the other...meaning listen at computer 2, from computer 2 & visa-versa. If you hear the audio thhen it should be correct. But in order to 'hear' the audio (besides proper settings in the VSL dialog box) you must 'also' set those digital audio s/pdif channels within Cubase's VST Inputs/connections. But in 'this case', you use both channels 9 & 10 for your Inputs/Outputs. They also say it's best to place your VSL digital audio channels at the top of the Inputs/Outputs list.
You do not need to keep the s/pdif channels in the VST Inputs/connections to make System Link work however, that's if you need to 'listen' or if you need to test whether it's routed properly.
Getting VST System Link working can seem complicated at 1st, but once you understand, and have it working, you realize it's actually not that hard at all. I recommend taking notes, and writing down what you did to make it work, as you go along the way. That has come in very handy when I need to use it again. Also READ your PDF manual and follow that to the letter!
Oct 08, 2013 | Lexicon Omega Desktop Computer Recording...
Usb device not recognised when m audio profire is connected to hp 625
W 7 First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically. Click start control panel scroll to folder options view place a tick in show hidden files folders and drives
this may vary depending on your operating system for XP or earlier click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
Hope it helps.
Jan 28, 2013 | HEWLETT-PACKARD 625 Tur II P540 Notebook
Vst system link errors
May 23, 2012 | Lexicon Omega Desktop Computer Recording...
I am having a problem getting sound out of a program called cubase 5
In cubase go to "Devices", there select "Device Setup", in the Device Setup windows go to "VST Audio System", on the top right you will see the "ASIO Driver" drop down menu, click it and select your sound card from the list. Also take a look into VST Connections.
Jan 10, 2012 | HP dc5000 PC Desktop
Hi. I have a M-Audio FW2626 and it was by mistake pluged in a higher V tension, and now it doesn't work anymore. Perhaps I found the problem, but I need its Diagram Block. If you can help, I...
The external power supply is probably damaged and will need to be replaced. It appears to be a 12 volt DC, 3.5 amp, center positive unit. I would replace with a new one from the M-Audio parts supply as the ratings of this are far above standard universal units.
Sep 19, 2011 | M-Audio Maudio Profire 2626 Profire2626 In...
Tascam us-144 mkII now working with cubase le4
better , you can use it by nuendo or cubase sx. over all you try it cubase device setup and click vst system or switch vst audio bay. for more help call me +8801711904316
Apr 05, 2010 | Tascam US-144 Sound Card
Microphone Recording
It all has to do with your VST Connections in Cubase LE (if you are using Cubase LE).
What you have to do is:
1)Go in and label you inputs and outputs in the Device Setup. Select " US 122L-US 144" Here your inputs and outputs should be displayed. You should be able to see which input is "active" and which ones are "inactive".
2) After noting which ones are active label these devices. Click the "Show As" section and label you "active" outputs as speakers or whatever you like. Also label you inputs which should be your mic or MIDIs.
3) After labeling, click " VST System Link" and make sure the correct input and output is selected, Example: (Input: AKG Perception 220, Out-put: Speakers/ Headphones) Hit Ok!
4) Bring up the "VST Connections" menu (F4) or (Device> VST Connections). Clear out all your outputs and inputs!
5) In your outputs click "Add Bus" Select stereo and 1. This should come up as whatever you labeled the outputs ( Speakers/Headphones for me!)
6) In your inputs click " Add Bus" Select Mono and 2. Here is where you should get one input that says the name of your input( AKG Perception 220 in L) The one below it should be ( US-144 Analog R or L) Click this and choose your Microphone! You should have the 2 options with your microphone named.
7) Test it (record something) and see if it works and plays in both ears if you want more clarification feel free to message me!!!!!!!
I HOPE THIS WORKS!!!!!!!!!!!!!!!!!
Jan 01, 2009 | Tascam US-144 Sound Card
0404 installed but cubase vst 5.1 will not load it stalls when loading vb-1. I had the same problem with an auditgy card any ideas on how to fix the problem? Geoff
vb-1 is a cubase virtual instrument this is where cubase was stalling, When i uninstalled cubase i went into the vst plugin folder and saw the folder vb-1 [virtual bass] I read the text file within and it told me to copy the dll files within into the active vst plugin folder. when i re installed cubase all was well. I have been using cubase for years and did not have this problem until i installed the e-mu 0404 pci card, or the audigy card
Aug 05, 2008 | E-Mu 0404 Bundle Sound Card
Lexicon Omega/Cubasele4
I've had this problem and similar ones. Following these steps seems to help:
Starting Cubase before switching on the Omega.
Go to 'Devices' and then 'Device Set-up'. Make sure you're in the 'VST Audio System' part of the menu. Make sure the Omega is selected as the ASIO driver - if not, switch it. Then click on 'Set to Defaults', then 'Apply' and 'OK'.
Or re-setting the Omega sometimes helps too.
It's a pain, though.
Mar 31, 2008 | Lexicon Omega Desktop Recording Studio...
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
