Question about Canon Office Equipment & Supplies
E002 and e004 are the errors
We can send the process, how slove the errors
  • Canon Master
  • 1,297 Answers
E 002 & E 004 is malfuntion the fuser unit.
E 002 : check TH1 termistor,H1 & H2 heater lamp and the thermofuse termostat.
E004 : SSR malfunction.
Posted on Aug 01, 2009
    New Friend:
  • 4 Answers
Ok let me help u on fixing your problem.
mostly this error is in fusing unit and may be due to power disturbance.
first press * (star) then 2 & 8 together again *(star) if succesfully u presed 2&8 together and then *(star) the number 1 (one) will appear in the box [ 1 ] then press 4 then A (automatic exposure) then 412 and finally finnish by pressing the start button/print button the machine will go OFF turn it ON it is now ok. if not start again follow the sequency untill to the step of pressing the start button insted of it press A.
try your best, waiting for your vote.
Posted on Apr 25, 2013
Tip
How to resolve Cannon ir400 Error e004
<span>Hi,<br /><br />For error code E004-001 or E004-002<br /><br />Cause:<br />The SSR has a short circuit.<br />&bull; The SSR has an error.<br />&bull; The DC controller PCB has a fault.<br />The heater relay has an error.<br />&bull; The heater relay has an error.<br />&bull; The DC controller PCB has a fault.<br /><br />Description:<br />&bull; The fixing heater remains<br />on.<br />&bull; The fixing temperature has<br />increased abnormally.<br />The heater relay remains on.<br /><br />FIRST TRY TO CLEAR ERROR:<br />Resetting Errors<br />1. The following error codes cannot be reset by merely turning off and then on the main power.<br />They require resetting in service mode:<br />E000, E001, E002, E003, E004, E032, E717<br />1) Start service mode, and select COPIER&gt;FUNCTION&gt;CLEAR&gt;ERR.<br />2) Press the OK key.<br />3) Turn off and then on the main power.<br />2. Error codes other than the above may be reset by turning off and then on the main power.<br />n Detail Code<br />Some error codes offer detail codes, which may be checked in service mode:<br />COPIER&gt;DISPLAY&gt;ERR (3rd block from the right)<br /><br />SERVICE MODE: <br />1) Press the asterisk key ' * ' on the control panel.<br />2) Press '2' and '8' on the keypad at the same time.<br />3) Press the asterisk key ' * ' on the control panel.<br /><br /><br />If these doesnt helps, you need to call service to locate the fault, which is probably bad thermistor.<br /><br />Hope that helps!<br /></span>
on Feb 06, 2011 | Cannon i70 Printer
How to remove error code (E000004-0010)from canon
Use this mode to clear an error code: E000, E001, E002, E003, E004,
E032, E717.
Using the Mode
1) Select <ERR> to highlight, and press the OK key.
2) Turn off and then on the main power switch.
Jan 05, 2013 | Canon imageRUNNER 5570 Copier
Set duplexingunit canon NP 6035
codes e002 et e004 canon copier np6035
Jul 24, 2012 | Canon NP 6035 Copier
Error code appear my Canon Xerox 405 e.i. e002. Please reply me how to solve the problem step by step. Please reply as early as possible. Thanks, Rajes Acharya
1) Start service mode, and select COPIER>FUNCTION>CLEAR>ERR.
n Detail Code
COPIER>DISPLAY>ERR (3rd block from the right
To enter the service mode:
1) Press the asterisk key ' ' on the control panel.
3) Press the asterisk key ' ' on the control panel
Hope that helps!
PS If not you have problem in fixing unit, probably the fixing thermistor and need to be replaced.
Jun 24, 2011 | Canon imageRUNNER 400S Copier
E004 error Canon 7301 Mfc
Here's a link to your support site.
Error E004 is:
Faulty fuser, replace Fixing Assembly(RG5-5559-000)
Hope this info helps.
Feb 11, 2010 | Canon 730i Laser Printer
This err number whit ist
hello there here is some information that may help you solve this problem ok?
best regards michael
  1. Printer Repair And Service Tools: Ir3200 error code e000677-0004 Canon Multi-Pass Fax C855 waste tank reset code ... Canon Error Code, E000, E001,E002,E003,E004,E005. Ir3200 error code e000677-0004 ...indoresetter.blogspot.com/2009/02/ir3200-error-code-e000677-0004.html - 82k - Cached
  2. C3200 Problem Solving at FixYa how do I reset this code? canon ir 3300. 1 Solution. after pressing *28 it come download mode ... e005 an error canon 6330. the quality of four colour is very ...www.fixya.com/tags/c3200 - 89k - Cached
  3. E004 Problem Solving at FixYa along with e001 and e005... HP Pavilion dv2000t PC... Problem Event Name: APPCRASH ... codes with this model np 7161 e004 iwant to know how to get in reset program...www.fixya.com/tags/e004 - 92k - Cached
  4. The Copier Network - Canon 6085 E5 ... what this code means or how to reset it any suggestions? ... E005 is fuser web out. clear web counter. techla. I replaced the web just coundn't reset the code. ...www.thecopiernetwork.com/printthread.cfm?Forum=87&Topic=18014 - Cached
Sep 14, 2009 | Office Equipment & Supplies
Codes e004
The E002 & E004 fuser unit malfunction code.Please check and clean the heater lamps,fuser thermistors & thermofuses.Check or change the SSR.
Jul 15, 2009 | Canon NP 6551 Black and White Copier
Canon copier error message "error001"
"E000" Low fuser temp. (Heat lamp, thermoswitch, thermistor, SSR) "E001" High fuser temp. (Thermistor) "E002" Fuser temp. too low "E003" Fuser temp. too low "E004" SSR, Fuser temp too highchange thermistor in fuser
Aug 27, 2008 | Office Equipment & Supplies
181 people viewed this question
old marine
old marine
