Question about Electrolux Heating & Cooling
My caravan electrolux blizzard 1500 air conditioning system trips the ELCB/RCD in the house when we switch it to warm. Where can I get a manual, or is this a known problem?
My caravan Electrolux Blizzard SA101 split air conditioner cools via compressor and heats via 1.5KW metal sheathed electric element. The element is similar to the coil on electric stove. It had 43mA leakage to earth enough to trip my RCD/safety switch. I pull the orange wire connector off the front panel heat switch and now the RCD does not trip out. If I am cold I will use a fan heater, it works better being at floor level and is quiieter.
Posted on Nov 22, 2013
I have a unit for sale
Posted on Aug 29, 2009
When i turn on the tub it trips the breaker why
Depends which breaker - if the rcd or elcb trips there is a power leakage to ground because of a fault. If it is the mcb there is a different sort of fault causing the appliance to attempt to consume too much current, a short circuit...
Jan 01, 2017 | Pool & Spa
My domena steam press keeps tripping switch
It has a serious fault, the trip tripping is saving you from a electric shock.
By the way if your ELCB is a oblong brown or black box with a yellow or orange test button its way outdated I recommend you get it changed for a modern RCD (much safer)
Oct 17, 2014 | Vacuums
Split ac of "LG " will run in normal condition for 3 to 4 hours but when the i switch off the unit ELCB will suddenly tripped, i have checked the pressure and current drawn by the unit it found normal,...
hi there this problem is normally caused bye a bad or should i say dry joint in your DB board check that especially your neutral wire isnt loose
Mar 05, 2014 | Haier Heating & Cooling
We have just bought a very old house that has a Vulcan Oil heater installed in the fire place. We have tried to light it (but all houses are now by law have installed RCD switches at the meter box,) How...
Is the RCD sensing a leak to earth?
As a test, you could drop the earth wire off the unit and see if the ignitor then works. If it did, then you would need to figure out if there was somewhere else you could earth the unit. This would potentially leave the ignitor without an earth and you need to decide what to do about that.
I hope you can see that I'm absolutely avoiding advice that you remove the earth from your unit in order to make it function. What you should do is get a professional in to correct the fault. What you actually do is a matter for you.
Jul 07, 2011 | Heating & Cooling
Oue RCD trips randomly when my wife is ironing. No particlar socket involved.May do it once and then it may be weeks before it happens again. No problems on switching RCD back on. A number of steam irons...
Not an Impedance this is a lower load trip switch on your power plug line.
All waht can be done is to keep a higher amp ELCB/MCB into this circuit and the fault will be over.
If ELCB then check if the iron is having any leak of the coils as a small leak can trigger a cut off.
Check your grounding
Sep 06, 2010 | Electrical Supplies
Oven not heating, and tripping .Aeg Electrolux
check your heating ellement
Mar 24, 2009 | Ovens
Dometic Blizzard 1300 roof top unit blowing fuses
YES< this is a "direct ground and either the motor or compresso is grounded--(DEAD)!and needs to be replaced.
Sep 09, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
1,064 people viewed this question
Top Electrolux Heating & Cooling Experts
christian nielsen
ivan georgiev
ivan georgiev
Are you an Electrolux Heating and Cooling Expert? Answer questions, earn points and help others
