Question about Yamaha 12V Air Pump
1994 Yamaha Waverunner 3 will idle but wont take throttle
Hello, My 1994 Yamaha Waverunner 3 will idle but wont take throttle. It overheated when I pulled sand into exhoust. I cleaned exhaust out and took it out and it ran fine for 2 hours, now it will not take throttle. I have changed fuel lines,filter, rebuilt carb, rechecked rebuild, and still no change. Question: can the thermo switch have gone bad from overheat and be sending bad reading causing limiter to kick in. If so how can I check thermo unit to see if that is problem, It is an expensive part to change without being sure. Thanks, Don
Switch to reserve tanke to check to see if there is a clog at the fuel pickup in the tank.
My friend had the same issue with his waverunner 3.
Posted on Aug 31, 2009
1994 700 cc waverunner when it has run for 15 min engine bucks at full throttle at 3/4 ok i have changer plugs antreated fuel
Posted on Aug 17, 2009
Yamaha waverunner 1200RECENtly purchased wave runner took out for 4 mile trip ran great took in for evening done inspection and realized it didnt have oil pump only a plate were it should be. so i put some...
The first thing to check would be the compression. As long as both cylinders are with in 10 psi of each other you should be okay. Both cylinders need to be at least 100 psi. That would be the minimum for a motor to start and run. It should read aprox- 150 -- 165 psi. Also i would check for a possible exhaust leak, that would cause the motor to bog down because the carb is breathing in the exhaust fumes. Try running the motor with the hood up to see if you have a leak.
Mar 11, 2017 | Water Sport
Yamaha xl1200 waverunner losses power after it is warmed up.
Hi, most likely cause and the easiest to check is exhaust leaking in the engine compartment. Run it without the seat fitted for the same time frame and if it fixes your problem you are looking for an exhaust leak. Regards Phil.
Aug 23, 2012 | Yamaha Boating
1995 Yamaha Waverunner III dies won't run
Check cylinder compressions, this ski will overheat if one side is low. Thus is step one, if ok and within 10% of each other, verify the exhaust isn't clogged with sand from "beaching" third verify the crank seals are not leaning the Mix causing an overheat. Obviously check the impeller housing to exhaust line isnt clogged, disconnecting the thermal sensor is asking for a top end rebuild which is about 500.00 they are designed to reduce revs and alternate spark to the cylinders once 200 degrees is reached.
Jul 31, 2012 | Water Sport
Do they have a thermostat on a 1994 yamaha waverunner 3
No thermostat just a thermo coupler to protect against overheating.
Apr 30, 2012 | Water Sport
Need Help On A 1994 Yamaha Waverunner 3
Check your pump and impeller, then trace water inlet hose from back to front, possibly have a flush kit thats missing the cap?
I bought a 97 gp 1200 waverunner and the first few times i took it out it ran great, i changed the spark plugs because it wasn't opening completly up at wide open throttle. I put it the water and it...
THE BEST WAY TO CLEAN OUT YOUR INGINE AND HOSES IS TO HOOK UP THE FLUSH HOSE TO THE SIDE OF THE WATERCRAFT ,,,,IF YOU DONT HAVE THE ADAPTER CONECTION HOSE YOU WILL NEED TO GET ONE ITS A VERRY IMPORTENT PART OF MANTENACE ,,,,YOU NEED TO FLUSH IT OUT EVERY TIME YOU TAKE IT OUT OF THE WATER TO KEEP ALL THE SAND FROM BUILDING UP IN YOUR COOLING SYSTEM,, AND TO GET ALL SALTWATER OUT THE SALTWATER WILL EAT AWAY THE HEAD LITTLE BY LITTLE,,PLEASE NOTE SOME MODELS HAVE A HOOKUP IN THE VERRY BACK WHERE YOU CAN HOOK A REGALAR WATER HOSE TO,,,HOPE THIS HELPS.
Jul 19, 2011 | Yamaha Alp 40 Motorcycles
I have a 2008 Yamaha vx110 deluxe waverunner that idles high.
I dont know the answer but my vx deluxe is doing the same thing. Not as bad as yours but 4k rpm idle.....ANyone?
Jul 13, 2009 | 1997 Acura CL
1995 yamaha waverunner 3 exhaust leak
pull battery tray and find the broken hoses
Jun 23, 2009 | Yamaha FZ 600 Motorcycles
I have a 2002 Yamaha FX140 Waverunner.Fuel problem or electronic?
you have fouled spark plugs change them all fixed all the newq yamaha sare doing it it is the in thing to do
Jun 12, 2009 | Yamaha 12V Air Pump
2006 yamaha waverunner wont idle
what is it idle at? how much? remove your seat check air filter if is black oily remove it and see if that fixes your problem you may want to change your spark plugs as well # one cylinder may be starting to foul the new yamahas are the worst for fouling plugs use a cr8eb instead of the cr9eb the 8s are hotter and work better try those and let me know thank you
May 15, 2009 | Yamaha 12V Air Pump
Yamaha 12V Air Pump Logo
2,278 people viewed this question
Top Yamaha Water Sport Experts
Colin Stickland
Colin Stickland
Craig Butler
Craig Butler
Are you a Yamaha Water Sport Expert? Answer questions, earn points and help others
