Question about SanDisk 2GB Secure Digital Memory Card
My memory card not formatted and it is not opened
    Genius:
  • 1,234 Answers
Preformat : By Fix-shad0w
#1
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
With A USB , CELLPHONE , Camera The SameThing
Posted on Aug 27, 2010
Unlock me my memory card.
just put your micro sd memory card in a symbian phone like e5 or n73 like this and open file manager then open the memory card and in memory card options click memory card options then press format memory card then now your memory card will be formatted and security code also deleted
Jun 11, 2011 | Nokia Cell Phones
Memory card problem
Is your memory card newly purchased? if so just format it. You can do it through your phone or you can format it from your PC using card reader. And remember, when you format the card, select the Fat format not the Fat32 file format, you can also quick format it. If you can do it, let me just brief up the steps here. To format from your phone, open the memory card and when your prompt to format it select "yes" or "ok" and it'll format automatically. If you are formatting it from your pc, Right click on the Memory Card drive and select format and follow the instructions by selecting the File format as Fat.
If you have important data, that'll be more complicated. Put your memory card in the phone and see whether it can be opened or not, if so connect the phone with the card to your pc and backup the files. If you can't open it, then you should format, but do it with the Quick Format and restore your data before you make any changes to your memory card. You can download the data recovery software from this link http://smartrecovery.gu.ma/ (Smartrecovery). Good luck
May 17, 2010 | Motorola Mobility ROKR E6 Smartphone
My memory card when opened show three messages one by one -memory card not formatted,operation failed,memory card in use by some other application respectively.plz tell me how i can open it?
you probally will have to format the memory card to your cell phone but keep in mind that if when you format your memory card it will delete EVERYTHING on it
Feb 19, 2010 | Nokia 3110 Cellular Phone
Nokia 5610 how to format the memory card with using the computer and to do it without it i tried the one that said reset factory settings but it didnt work
Hi, I guess you must be using microSD memory card. Just connect the mobile and computer using USB cable, provided alongwith mobile phone. On connecting two windows will open, one for phone memory and one for memory card. Carefully note the memory card drive (e.g. G: or H:)
Open MyComputer and right click on that memory card drive (G: or H:), drop down menu will open and select "format" and click format. In this manner,your would be able to format your memory card.
Sep 16, 2009 | Nokia 5610 Blue Quadband 3.15MP A2DP +...
Cannot find instructions in manual for Nikon Coolpix S210 on how to delete ALL photos from memory disk. It will let me delete one at a time but I want to wipe the memory card clean. Thanks for any and all...
These instructions are from the Instruction Manual of the Coolpix S 210 and need to be carried out within the Set-Up Menu.
Refer Page 19:
Removing Memory Cards
Before removing memory cards, turn the camera off
and confirm that the power-on lamp is off. Open the
battery-chamber/memory card slot cover and press the
card in 1 to partially eject the card 2. The card can
then be removed by hand.
B Formatting Memory Cards
If the message at right is displayed, the memory card must be
formatted before use (A110). Note that formatting permanently
deletes all pictures and other data on the memory card. Be sure
to make copies of any pictures you wish to keep before formatting
the memory card.
Use the multi selector to choose Yes and press k. The
confirmation dialog will be displayed. To start formatting, choose
Format and press k.
Do not turn the camera off or open the battery-chamber/memory card slot cover until
formatting is complete.
• The first time you insert the memory cards used in other devices into the COOLPIX S210, be sure to
format them using this camera (A110).
Refer Pg 110:
 Format Memory/m Format Card
Use this option to format the internal memory or a memory card.
Formatting the Internal Memory
To format the internal memory, remove the memory
card from the camera.
The Format memory option appears in the setup
menu.
Formatting a Memory Card
When the memory card is inserted in the camera, the
Format card option appears in the setup menu.
Hope this helps
Ian
Aug 09, 2009 | Nikon Coolpix S210 Digital Camera
Cell phone how do you format the sd card?
just go memory card in that u find format option
select that & ur memory card will get format or try connectioning ur mobile to pc & format through pc by selecting memory drive right click mouse button select format option in that asked for quick & custom format select one of them & format ur micro sd card
Feb 20, 2009 | Nokia Cell Phones
Problem with memory card
remove your memory card and put on the memory card reader,
insert the usb port of the system.
after open my computer right click the memory card drive select format option, then open the dialog box select fat file system and quick format ok finaly ready your card
Jan 29, 2009 | Nokia N70 Cellular Phone
SanDisk 2GB Secure Digital Memory Card Logo
89 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Carlos Calvo
Level 1 Expert
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
