The pager has a home like icon on the display and on my car with exact alarm which works doesn't? is it a setting on the remote that i have to switch to?
SOURCE: My car alarm is blinking
You need to first look under the drivers side dash area near the hood release/fuse panel area and see if there is a valet switch. The switch will look like a little toggle or a push switch. After you locate it, turn the ignition switch to the on position(dont start it) and flick the valet to the opposite position it is in now. If done correctly in most cases the red system light will stay a constant instead of off or blinking indicating you are in valet mode. Next try to start the engine. If this doesnt work you need to remove the alarm system and repair the ignition switch wiring or replace the electrical portion of the ignition switch. The aftermarket alarm cuts into the ignition switch wires and bypasses the start circuit through the alarm module. When disarmed the alarm completes the circuit and allows the car to start. Good luck hope this helps and please rate this.
SOURCE: problem with my viper alarm system on my 98' odyssey
first, you need to manuslly disarm the alarm. open driver's door, put key in ignition, turn on ignition, an then within 10 seconds push the valet/program button for a couple of seconds. (it is the little spring loaded push button that they installed with your system. probably in the kick panel or under dash
SOURCE: Viper alarm, lights dont flash
Sounds to me like the parking light output wire. They usually have a seperate fuse or the connection is bad. The connection on your vehicle should be behind the pass side kick panel and look for a wire to the white/purple wire and check that with a meter or light to see if it's kick out power. There is a possibility they used the negative trigger through a resister and that would be located behind the headlight switch. That will at least let you know and trace down the problem. Here is a link with that parking light info for yours. Hope this helps and let me know if you have more questions.
http://64.85.6.121/diagrams/printpage.asp?ModelID=17258&MakeID=16
SOURCE: Kill switch is on and I cant deactivate
you to disconect the main harness from the alarm.and take your car to a alarm repair shop.
SOURCE: my viper 2 way pager remote will not arm or disarm
It could be set on car #2. Press function for 8 seconds and a light next to lock should come on. If the light next to unlock and lock (two lights) then it is set to #2 car (you can operate 2 cars with one remote). All you have to do is press function again to toggle between the two cars. You want to end up with only one light showing.
So, hold function for 8 seconds, then after a light shows, release and press function until you only see the one light.
