Question about D-Link / RangeBooster N 650 / DIR-635 / 300Mbps / 802.11n / 4-Port / Cable/DSL Wireless Router (DIR635)
LOGIN FAIL i have brought a new D-link wireless router! and tried to log in in the site-192.168.0.1 as told.when i m giving username-admin and password-(blank) or admin,then its showing log in failed! plz help me out.
  • 221 Answers
At the back of the router is a tiny hole, so while router is on and working push the paperclip or something inside and hold for at least 10secs. This step will reset the router to factory settings and you'll be able to login again
Posted on Aug 01, 2009
I trying to change the key 1 in wireless (security)+my router is tew-652
You will have to log into your wireless router's admin console to do this.
Open up your web browser and navigate to your router's address. This is usually http://192.168.0.1. If that doesn't work, you'll have to replace that with your router's IP address. (Here's how to get the router IP address - you want the address of the Default Gateway.
You'll see a login page. If you don't know the login, try admin as both username and password.
Click Wireless from the left menu.
Click the Security sub-menu (left menu again)
You should have WPA2 selected. Your wireless password is the Passphrase. Change it to whatever you want and click apply.
To test, disconnect a computer from the wireless and try to reconnect. It should fail since the password has changed.
Jan 07, 2014 | Computers & Internet
Username, password of my model DSL-G604T/TH V.A3
The default login to the router is ADMIN and the password is blank. If yo are looking for the wireless SSID and password, that should be listed (after logging ton the router) under the wireless section.
Jul 21, 2012 | D-Link DSL-G604T Wireless Router
I am trying to login as admin, to be able to change the default password and secure the signal, but the default username does not let me log in. I'm using 192.168.0.1, login-admin, password-(blank). H
Looks like you wil have to do a facotry reset. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can ssets-up form scratch.
Dec 14, 2011 | D-Link DIR-615 Wireless Router
I lost my pin
If it is the pin of your encrypted wireless connection (WEP/WPA etc.) then go to router's login page , usually 192.168.1.1 and then login using your admin username and password. In case you had not setup the router yourself then try the following username password combinations :
Username : admin password : admin OR Username : admin password : password
If you are able to login , then you can simply give a new password to your wireless connection . Exact instructions for doing so vary with the make of the router . In case if this doesn't work then you can try doing a hard reset of your router by pressing the corresponding button . Check in the manual of your router for doing so . In case you don't have the manual , then post the Model Number / make of the router or try searching for the manual on the internet or post back the model number for more detailed instructions.
May 09, 2011 | Computers & Internet
Emachines by acer/ana/unlock passwordto wifi connection,,,i cant connect to the wifi...coz its lock i forgot the password
You can either connect to the router by Ethernet and change the wifi password or You need to reset the router, typically by pressing the small button on the back for 15 seconds.
Feb 28, 2011 | Computers & Internet
I cant login to D-link-i have forgotten my password and i have tried 'admin' as username & 'password, admin' for the password and also tried leaving it blank, as well as the pin on the bottom of the...
The default D-link router login is admin with no password. With that said, you probably cannot login to your router because D-link requires you to change this default login the very first time you login to set it up. If you have a router you setup a long time ago and have forgotten its password and settings, you will likely have to reset D-link router password.
If you look at the back of your D-link router, you will see a pin-hole. Inside that hole is a button that resets the router. To perform the reset, insert the end of a paperclip in the hole and depress the button for about ten seconds. Leave the router on during this time. It will reboot by itself and the WAN light will begin flashing on the front.
When it stops, the router is reset and you can login to it using your web browser. Just type http://192.168.0.1 and click enter. You should see the D-link login window. Type admin without a password and you will be presented with the default d-link settings again. Configure a new password and wireless settings and your router will now be accessible again
Jan 27, 2011 | D-Link Xtreme N DIR-655 Wireless Router
I cant access my router
192.168.1.1 is the router's Ip address which will take to you to its ADMIN console. Defualt username is: admin and password is: password or admin. Try these. Once logged in you can then configure the router as required. Dont forget to set the WEP key to make your wireless network secure. WRT54G2 is the name of your router which is sending you the request to fill in the login details.
Please rate if helpful.
Thanks
Apr 12, 2010 | Linksys WRT54G2 Wireless Router
Login to router
ok
try
username as "admin" and password as "admin" or blank or "password"
Jun 23, 2009 | D-Link 802.11g Wireless Router WBR-1310...
ISP name and password
By default the username is admin, and the password is admin, if didn't work try resetting the router by pressing the reset button for 10 seconds so it will be back to its default settings with the default user and password as admin.
Hope that helps..........
Sep 01, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Computers & Internet Logo
1,047 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
