SOURCE: hoover F7431-900 steam vac brushes wont work
the brushes are activated by suction, my berings and gears froze up, i took it apart, kinda hard to figure out, but not as bad as it looks. i lubed the berings and the gears, then i took an air compressor to the activation fins and let it spin, lubed again then hit it with air again, now works better then new.....GL
SOURCE: Hoover Steam Vac - Brushes not turned, no suction power
The Brushes not spinning is most likely is caused by seized bearings in the turbine, requiring shop service (easy fix). The suction issue can be caused by the standpipe seal missing or lower recovery tank not on properly, on some models missing front panel. I would need more exact model info to assist further.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
SOURCE: brushes don't work on my hoover steam vac v2
The bearing on the inside of the turbine is rusted. You will have to take the hood of the unit and unscrew the black piece that has to rub hoses going to it. Then take apart the black turbine. Inside you will find 2 white gears and a small 1/2inch bearing. Use wd40 to uncease the bearing. After this put the take pliers and make sure the metal post will turn. Spray wd40 on everything you see including Hoover for making such ****. After this put put everything back together. Now the best thing to do is get some automotive bearing grease and put a large amount on bearing and and other metal parts. Put everthing back together. Clean any hair off the brushes and you are ready. Now the bad news if your gears are worn you will have to replace the turbine. Go to an internet website and the part number will be 91001019. I know all this because I spent 6 years working for Hoover and they found it cheaper to send our jobs overseas.
SOURCE: hoover s3765 windtunnel power head does not run
I have the exact same problem as you have. Have you found a solution since you posted on Mar. 18, 2009? Thank you.
SOURCE: power switch does not work
Greetings,
Most likely your switch has gone bad, and you'll need to replace the on/off switch on your Dyson DC07. If you have to hold down the switch in order to keep the vacuum on, this is indicative of needing a new switch. Unfortunately this is very common problem on the Dyson vacuums. The switch that Dyson uses for their vacuums is one of the cheapest quality switches on any vacuum on the market today. The good news though is that this is not a extremely difficult repair to fix.
I took pictures of replacing the switch assembly on one of our customers repairs they brought in. It was having the same exact problem that yours is, it just wouldn't stay on. Here's how you can fix the switch on your Dyson:
- T15 Torx Bit Screw Driver
- Genuine Dyson DC07 & DC14 Replacement On/Off Switch Part 901181
- Needle Nose Plyers
- Patience (haha)
The switch above is actually a link back to our site if you have yet to purchase the switch yet. We carry most every Dyson part.
IMPORTANT: MAKE SURE YOUR VACUUM CLEANER IS UNPLUGGED BEFORE DOING ANYTHING ELSE!
Step 1. First thing you'll want to do is to unwrap the cord from the machine, and remove the handle from the upright part, then slide the hose all the way down the wand, and remove the hose from the handle assembly completely and set it aside. Also remove the dust bin assembly completely from the machine as well.
Step 2. Once you've remove the handle from the machine I find it easier to work on if you lay vacuum on it's back, with the switch button facing upwards. Now remove the T15 Torx bit screw that is directly below the switch actuator. I have circled the location of this screw in the picture below:
Step 3: After you have taken off the screw, you're doing to need to remove the switch box housing from the vacuum that the screw was securing. Simply use your flat head screw driver, and pry the two small arms upwards. Be careful when prying, the plastic components on Dyson vacuums are really cheap quality plastic, and I can't tell you how many times I have seen these plastic parts break when customers bring in repairs to us here at govacuum headquarters. Here's a picture of the location of where you should pry the switching off:
Here's what the vacuum should look like after the switch housing has been removed:
Step 4. Use your needle nose plyers to remove the terminals from both of the switch poles.
Step 5. Take out the new switch assembly. I find it the easiest to use my needle nose plyers to reattach the wires to the new switch, but it also can be done with just your hands. Connect both wires to your switch. If the cords have come loose while you have been working on the vacuum, you'll need to put the wires back into their proper places as well. This is how the switch and the wires should look like when you're done:
Step 6. Once the switch and cords are back to their normal places, simply put the switch housing cover back on, and screw in the one screw.
I hope that this repair was helpful to you, if you have any questions or have any problems, please feel free to use the clarification request form here on Fixya. If this repair was helpful to you, please be sure to rate the repair helpful by clicking the thumbs up icon in the top right hand coner. This is a nice gesture that will ensure that professionals will continue to post free repair solutions here on Fixya.
If you ever need any supplies for your Dyson, we do carry most parts and accessories on our site under our Dyson Parts Section .
Thanks again,
Chris J.
GoVacuum
