Toshiba A135-S4527 will not boot
Its 2 yr old lappy. When I press power the blue light on power button comes on alongwith the small power LED in the front. The fan spins for a while and goes dead. No activity on HDD or DVD. Dark black screen. Any clue what could be wrong? I used it previous night and turned off in normal way. Next evening when tried to switch on the problem was noticed. Already tried removing memory and HDD, putting on AC power only, removing battery and AC power and keepning aside for few hours. Nothing helped. Thanks in advance for any suggestion.
  • 27 Answers
Could be power supply (ac block and power cord) is dying or died. Laptops are notorious for this.
Posted on Aug 01, 2009
Toshiba A135-S4527 starts to power up then shuts down.
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Mar 08, 2012 | Toshiba Satellite A135-S4527 Notebook
My Satellite A135-S4527 will not power up. I press the power botton it lights up in color blue (as normal) and the power on LED indicater lights up. This will stay on for appox 10 sec and goes off. No HDD...
check your power fan of your processor underneath on the laptop, possible cause is overheat, bring it to the shop for whole diagnosed.. if you continously used on that situation it might cause some problems to other parts due to overheating..
Aug 27, 2011 | Toshiba Satellite A135-S4527 Notebook
What do the various led light colors mean? I have
The LEDs each indicate something is conected or normal. There is one for hard drive activity, power, battery, and wireless. Blue is good. Orange is bad. First take the charger to a shop to have it checked. If bad replace it. If good the the problem is either battery or the connector on laptop. Since the battery is new it sounds like the connector to me.
May 01, 2010 | Toshiba Satellite A135-S4527 Notebook
Problem with toshiba A135-S4527 ,MOTHERBOARD NOT INITIALIZING
Have you left a cd in drive? It could be trying to read a disk to boot from if thats how your boot order is set up. This is the first simplest thing to check.
Char S
May 24, 2009 | Toshiba Satellite A135-S4527 Notebook
Toshiba laptop satellite A135 S4527 power
take it with you when you go and try the new cord before you buy it , Toshiba's are Notorious for the charger cords to be crappy and also the port for the laptop itself to break and need repairing , witch you have to send it to toshiba to get done if that is the case
Apr 12, 2009 | Toshiba Satellite A135-S4527 Notebook
Try this:
I left mine on, in its coma cond overnight. The next am I touched the enter key and it booted up! 5 days later it went back into is coma.
Yeah, Toshiba Laptops ****! My A135 S2246 is doing the same thing. You and I aren't alone either. Search for: "toshiba sucks" and you'll see how many there are, lots of them. 1 week after warranty expires it started doing exactly what yours is doing. I swapped out ram with known good ones, HDD also, I connected external monitor, keyboard, nothing changed. I re-seated the CPU, temp disconn cmos batt -no help.
Cleaned all the connectors & grounds, no help.
Observations:
Fan runs on & off, I feel heat being pushed out.
Can hear Hdd spinning, indicator led briefly flashes when I first turn on.
Fn indicator led will illuminate, sometimes.
caps lock led -not at all.
numeric keypad led, no.
the only key that seems to do anything is Fn.
Toshiba wanted $35. just to discuss it over the phone. -WRONG!
Its now two years old and about as useful as a milk bucket under a bull!
Jan 13, 2009 | Toshiba Satellite A135-S4527 Notebook
Toshiba's A135-S4527 Battery isn't working anymore
Have the battery checked or better yet, replaced. Prolonged use might damage the charging circuitry of your machine.
Jan 11, 2009 | Toshiba Satellite A135-S4527 Notebook
Laptop doesnt display anything
if there is no display whn u press the start button then your motherboard is screwed. i had this problem with mine too. I got it replaced fro free as it had a warranty... anthing more contact babu_aero@yahoo.com
Jul 20, 2008 | Toshiba Satellite A135-S4527 Notebook
Start up
yr problem should be from the screen to really confirm if yr laptop is truly on cos u dont just gudge by seing the power led on. to check if yr system is on press the caps lock key or press the fn+num lock key if the indicator led comes on then yr system os on now troubleshoot yr screen by checking the module,connector n fuses. if the caps lock led doesnt come on then yr system just powered on because it saw a power source in that case try to replace the memory(ram) next the processor.
guess this helps
thanks for using fixya
May 26, 2008 | Toshiba Satellite A135-S4427 Notebook
Laptop stuck in sleep / hibernate mode??
Try holding the power button down for at least 10 seconds, that should turn off the laptop completely. Then press the power button again to turn it on. Hopefully it will boot up.
May 14, 2008 | Toshiba Satellite A135-S4527 Notebook
Computers & Internet Logo
159 people viewed this question
David Payne
David Payne
