Question about Panasonic PV-GS83 Camcorder
Bad picture and background noise when connecting camcorder to tv
I have a rather old digital camcorder which uses mini-8 video tapes.
I have recorded a video which plays perfectly in playback on the Sony Camcorder and plays perfectly when downloaded to my computer...
BUT... when connected to a TV using a video/audio out plug with the red/white/yellow plugs on the other end going into the TV... it suddenly has a loud distortion sound (similar to the feedback from a microphone that's used too close to the speakers) and the image is fairly visible but shaky, flickery and distorted... ie... CRAPPY
I have looked through all the menu functions and adjusted to PAL (I'm in Australia and use PAL) and tried various other settings to no avail ! I have tried this on two different TVs with the same results both time. The common denominator is the cable (brand new) and the camcorder (about 8 years old...)
I NEED THIS FIXED BY TOMORROW but at least hope to get an answer for the next time I need to play a Video directly to the tv !!!
Thanks for any ideas !
    Problem Solver:
  • 14 Answers
I'm guessing it's the cable.
Posted on Aug 01, 2009
Camcorder picture has no colour and very dark
Playback a recorded tape on another monitor such as the computer's or a TV. If the recorded program is ok, then your camcorder screen is bad. If the recording is bad, then you may have a CCD or lens problem.
Feb 01, 2011 | Canon MVX100i Mini DV Digital Camcorder
I have a Sony Handycam DCR-TRV720 Digital-8 Digital Camcorder. How can I transfer the video from these tapes to DVD? The cabling seems too old school to link up to my computer in order to burn a DVD.
This model has iLink: IEEE 1394 firewire port. If you don't have a firewire card, you can probably find one pretty cheap on the internet (try ebay).
Windows has movie maker, which when the camera is connected, will allow you to capture the video from the camera on the comptuer, although there is no DVD burner software at least on the XP version (not sure about Vista). I use Nero for the whole process: capture, edit, burn to DVD.
Sep 08, 2009 | Sony Handycam DCR-TRV720 Digital Camcorder
My camcorder can play old tapes but won't record
Your camcorder Sony DCR-HC20E has bad ccd imager problem and that part will be replaced to have live view to record on tape.
I can provide you ccd imager part number info if you want to repair it by yourself.
CCD Imager replacement in this camcorder requires expertise and fair skills of soldering parts in PCB.
Jul 11, 2009 | Sony Handycam DCR-HC20 Mini DV Digital...
Video transfer not working
  1. connect VCR(recorder) to TV, select TV proper channel to get signal from VCR
  2. connect Mini DV to VCR, for example, you are using AV1 input on your VCR
  3. on you VCR, select channel(or input) to AV1, insert a blank tape
  4. turn your Mini DV to play mode and play, press REC on your VCR
you should get picture now.
May 08, 2009 | Panasonic NV-DS60 Mini DV Digital...
Camcorder recording troubles
Dear elfox33
Your camcorder has dirty/clogged video head problem. Please use Video Head Cleaning Cassette Video-8 type to clean it. Hope problem will be solved.
Mar 18, 2008 | Sony Handycam DCR-TRV250E Digital...
Canon zr100 digital video camcorder won't record or show picture on screen
PLEASE USE MINI DV HEAD CLEANING CASSETTE & TRY , MAY SOLVE YOUR PROBLEM
Oct 20, 2007 | Canon ZR100 Mini DV Digital Camcorder
How to Record From a TV Using PV-GS13?
connect a lead via your tv video out audio out jacks. Select tha appropriate channel (You may have to go through the av channel on you tv and tune in the channel you want to record) or, video or dvd player audio out video out jacks. connect other end to your camcorder. Select on the camcorder menu video in audio in. Turn on tv. If connected to video or dvd player, press play. Press record on your camera. When finished recording press stop. Presuming the camcorder is tape, you can buy a tape adaptor to play or record your mini tapes in a standard video recorder, then take them out of the adaptor and play them back on your camcorder. You can also do all this via a computer. Also if the camcorder is disk or hard drive it can be used the same way as a regular dvd recorder to record tv programmes once connected to you t.v. Let me know how you go 26 red
May 08, 2007 | Panasonic PV-GS31 Mini DV Digital...
How do I transfer my camcorders recordings from HI8 tape to a computer or DVD?
Do you have another video camera that will hook up to your computer? In the past, I've connected my old Hi-8 to my Mini DV, recorded the footage from the Hi-8 to the Mini DV and then digitized on the computer from the Mini DV. You will however need some video software like iMovie for this solution.
You can also, hook the Hi-8 camera up to a VCR or TV using the appropriate cable and view it that way.
Feb 09, 2007 | Samsung VP-L800U Camcorder
Recording From An External Device
The following Models can be used as a recorder to record from a VCR, TV or another Camcorder. 2004 - SC-D107 2003 - SC-D5000, SC-D27 2002 - SC-D180 Recording In Player Mode 1. Connect the camcorder to the VCR or TV with the AUDIO/VIDEO cable (provided) (to the A/V Outputs on External Device) 2. Set the power switch of the camcorder to PLAYER mode. 3. Turn on the VCR or TV. 4. Insert the blank tape with protection tab closed into the camcorder. If you want to record from a connected VCR, insert a recorded VHS tape into the VCR. 5. Press the MENU button, turn the MENU DIAL to highlight A/V and press the ENTER button. 6. Turn the MENU DIAL to highlight AV IN/OUT and press the ENTER button to select AV IN. "AV IN" and picture appears on the LCD monitor. OUT : Releases the INPUT mode. 7. Press the START/STOP button to set the camcorder to REC PAUSE mode. "PAUSE" appears on the LCD monitor. 8. Select the TV program or playback the VHS tape. 9. Press START/STOP button to start recording. If you want to pause recording for a while, press the START/STOP button again. 10. To stop recording, press the (STOP) button. Notes: * Recording from an analog VCR to the camcorder is only possible when the VCR is playing back at normal speed. * If you want to see the camcorder picture with a TV, set AV IN/OUT in the menu to OUT.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Jvc 200u problem recording to vhs video tape, from camcorder
Yes, if the camera is a US camera then it is NTSC. That would be your problem, you are trying to record an NTSC signal to a PAL video. THe frame rates and resolutions are all wrong. I am even surprised that it is playing back on your TV okay...
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
Panasonic PV-GS83 Camcorder Logo
101 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
