Question about Henri Studios Henri Studio Summer Showers Fountain 4 Piece
Hi i have a h2o ice shower but i dont have the instructions can any one tell me hot water goes and cold water goes
  • 574 Answers
Hot water on the left cold on the right
Posted on Sep 07, 2009
My PTG-42PVN h20 heater is allowing h2o temp to fluctuate from one extreme to another.
Does same thing happen at all faucets?
Are you getting error code?
You might have crossover problem with defective faucet cartridge.
Copy following links for troubleshoot resources:
http://waterheatertimer.org/pdf/No-Error-Code.pdf
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Aug 08, 2012 | Rheem Water Heaters
Push Pull Shower Valve also off in middle position
If you turn it to left or right (hot or cold) and get water out of the shower head,we'll elimate cloged shower head.If it just doesnt work in the middle ,probily a washer is stuck in your diverter,or to better understand>a part inside your shower knob assembly is clogging the water that goes up to your shower head. If you get water out of the shower head in the just cold possition or just hot position,then you will have to dissasemble the unit to repair. If you get no water in the cold or hot position could just be a clogged shower head.If you dont know how to disasemble a Shower diverter ,I wouldn't recommend taking it apart. Hope this helped!
Feb 09, 2012 | Moen Home
I have been strugling with water flow after replacing a single handle tub and shower cartridge. I have no flo. They have pex plumbing. the shower has not been used for a while and at the time they were...
look inside the valve with a flashlight and make sure a rubber peice of the cartridge did not plug the cold side this cartridge needs hot and cold water to function it has a built in balancer that prevents scalding also make sure its not shut down at a manabloc system in the mechanical room if this helped you please feedback vote thanks
Aug 27, 2011 | Moen & Posi-Temp Single Handle Shower Or...
Rinnai infinity standing in the shower and it suddenly goes cold for a few seconds no other water been run in the house or it goes cold and goes to a trickle then comes on again. Could the heat ex changer...
We are a bit confused by the device that you are using to heat the Hot water with- Is it an instantaneous HW heater?--
They are pressure sensitive-- Could it be, that your water pressure drops momentarily, (which causes the instantaneous heater to shut down its flame-- and you get a pulse of Cold water.)
If your hot water is a tank-- It is possible that something is cycling your hot water away-- like rinse pulses on the Washing machine)-- or your dishwasher?
Tell us more about the Rinnal Air Conditioners and what they have to do with Hot water and your SHower?
Tell us more-
Mack B
Jan 23, 2011 | Rinnai Heating & Cooling
My Bristan Meridian Show start ok with hot water then after a few minutes the water runs cold. Even if you try and increase the temp it still remains cold. You can switch of the shower and start again...
It sounds like 1 of 2 things to me. I will start wit hot water heater. The first test for the water heater is to have someone run the hot water while you hold the hot and cold pipes and see if the water is coming out of the water heater cold when the shower goes cold. Of the water heater is cold coming out then the problem is in the heater. ether a lower element is bad or the dip tube is broken at the top of the tank. if the hot water heater continues to put out hot water when the shower goes cold then it has to be the mixing valve for the hot and cold mix at the shower and that valve will have to be repaired or replaced. hope this gives you a good start. let me know if I can help further.
Dec 24, 2010 | Home
Hot water trickles in swhower--works fine on other faucets--cold h2o flow fine
Clogged galvanized pipes. Replace with Pex or Copper lines. Or bad Moen cartridge- see department store for replacement or call Moen direct. You can get the # from gethuman.com
Nov 11, 2010 | Moen Posi-Temp Single HandleTub And Shower...
Electric shower hot and cold
it sounds like the flow is too low and causing the heat chamber to overheat ( or the heat sensor is faulty and thinks it is too hot) is the water too hot before it goes cold?
Mar 18, 2010 | Home
Showerlux bodyzone envy shower system instructions
you probably need a better water faucet that controls the hot and cold mixture.
and this is not a tv problem
Oct 07, 2008 | RCA TruFlat 27F520T 27" TV
Henri Studios Henri Studio Summer Showers Fountain 4 Piece Logo
64 people viewed this question
Top Henri Studios Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Henri Studios Garden Expert? Answer questions, earn points and help others
