Question about Jensen VM9510 Car DVD Player
Jensen uv8 help
Hi, I can't get the dvd to play. I don't know were to connect the pink cable (parking cable) There is also a green and white cable that I have no idea were to connect to. Please Help!!!
  • mmecsey Dec 03, 2008
    everything on my car is hooked up right i have the bypass code on but dvd's will not play it just comes up bad disc but i was using brand new dvd's
  • Anonymous Dec 14, 2008
    los codigos para ver ls pantalla del uv8 jensen gracias
Is there anyway to get my ipod tracks on the screen and scroll thru them without looking at my ipod?
Posted on Nov 24, 2008
The green with white is for the back up camera option, if you dont have a camera dont hook it up. If you use th remote when in the dvd mode press setup on the remote, then enter 5 4 3 2 1 0 (with the numbered keys) then holding 0 for 4 seconds, this will take you into a screen where you can shut off the parking brake overide. Now you dont have to hook up the pink wire.
Posted on Nov 26, 2007
How do i get my phaser linear uv8 to come on.
Check to make sure you are connecting Power (+) to positive (red) and ground (-) negative (black).
Jun 30, 2009 | Jensen VM9510 Car DVD Player
Jensen uv8 bypass code didn't work
no the code should work . unless jensen put a stop to the code in the newer modles.
Jan 19, 2009 | Jensen VM9510 Car DVD Player
Parking Break Override
Simple if you don't know where to ground the wire to, just ground it with the ground wire of the radio. Twist the pink and black wires together, then put them with the black ground comming from the car. Hope this helps.
Jan 12, 2009 | Audiovox Televison & Video
The UV8 needs to use The Pink wiere to play an CD audio?
I got through to tech support. For problem of no audio from DVD or CD (can only hear radio), reverse the Blue wire (power antenna) and the Blue/White wire (external power amplifier). This should solve the problem.
Nov 26, 2008 | Jensen VM9510 Car DVD Player
Product jensen uv8 nov. 2007 model in a trooper 1996 auto
The pink wire in most instances is the DVD's sensor that the vehicle is not in motion and is parked. It then allows the DVD player to display the movie not the warning message nor the blue screen.
Your description " wire on a bolt attached to the body..." indicates that said wire is constantly grounded. The DVD then cannot sense that the vehicle was parked. What this tell us is that the pink wire must first have a +12VDC before it is grounded. This changeover from + to 0 is the trigger. What is required is to have a single pole double throw switch. One end terminal is wired to ACC B+12 while the other to ground with the center terminal to the pink wire. Moving the switch from position OFF to ON (+12 to GND) simulates the parking brakes condition and will enable DVD playback.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 02, 2008 | Jensen VM9510 Car DVD Player
Phase linear uv8 parking brake problem
for the uv8 to bypass the parking brake to watch dvds you have to take the pink wire and put one end to one of the screws on a two screw toggle switch connect the other end of the pink wire to the other screw and connect that to the black ground wire
Mar 12, 2008 | Phase Linear UDV9010 Car DVD Player
How can I watch video in my UV8
no wire it to a switch and you have to flip the switch twice and leave on
Dec 10, 2007 | Jensen VM9510 Car DVD Player
Phase linear uv8
1: Go into AM/FM mode
2: Hit "setup" on the remote control
3: Enter 543210 on the remote, listening for the beep for each number entered
4: A new menu will appear. Touch the button that has the hammer/screwdriver on it in the upper left-hand part of the screen.
5: Select Brake bypass to "ON" and hit the "X" near the bottom of the screen.
Dec 03, 2007 | Jensen VM9510 Car DVD Player
Jensen UV8
get a Y_ adapter cable
Nov 26, 2007 | Jensen VM9510 Car DVD Player
Jensen uv8 no pic and very noisy when loading
i sounds like your Laser is not riding up and down sled freely. Loud noises coming from DVD drive always indicate Sled trouble.
Jensen VM9510 Car DVD Player Logo
256 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
