Even if the motor is ok iit won't work unless the circuitry switches on the power to it.
Even if the circuitry is ok there are typically at least a couple of safety devices that have to be satisfied before things can get going.
I suggest the motor is tested by providing an independent current to it and then it might be a good idea to read the manual and study the circuit diagram - or cal in a repairer.
Testimonial: "Thank you for your assistance and I am trying to do things myself before having to call a repairman."
Yes you should try replacing the run capacitor.
SOURCE: air and heat not blowing air through vents
Either Your fan switch is burned out or you blower motor is no good, your blower motor is on the passenger side under the dash. Before you replace any parts you need to check your fuses and relays under your hood and in the car. Usually if your fan switch goes bad you will still get some air blowing thru the vents, so my guess would be blower motor, If its not a blown fuse or relay.
