Question about Canon SELPHY CP710 Thermal Photo Printer
Atasco de papel en la impresora selphy cp710 - Canon SELPHY CP710 Thermal Photo Printer
SOURCE: DRIVERS OF PRINTER CANON BJC-250 FOR WINDOW VITA
[English Below]
No lo encontrarás.
Utiliza el mismo para Windows XP, cuando lo instales presiona "Continue Anyway" (o su equivalente en Español). Esto debe funcionar, hasta la fecha Vista aún no tiene soporte para tu modelo de Canon.
Suerte!
)O(
The question is: "I cannot find the controller for a Canon BJC-250 Printer for Windows Vista"
CoolDragon's Answer:
You won't find it.
Use the same one for Windows XP, when you install it press "continue anyway" until today, Vista has no support for that model of Canon printer.
Posted on Jan 24, 2008
ginko
  • 19396 Answers
SOURCE: como instalar la cannon ip1500 sin el cd instalador
Tiene que descargar las controladoras aqui: iP1500
Posted on Oct 26, 2008
pineworks
  • 4041 Answers
SOURCE: error 5B00 de la canon mx300, como lo soluciono?
Hi you can try
Solution:
  1. Turn on the machine
  2. Press MENU
  3. Press SCAN COPY SCAN to enter service mode
  4. USE > to got to NVRAM ACCESS
  5. Set ABS-M LEVEL to 0
  6. Set ABS-P LEVEL to 0
  7. Press STOP to EXIT
All The Best: Pineworks
Posted on Jan 25, 2010
pineworks
  • 4041 Answers
SOURCE: error 5600 Canon ip1700
Hi there
You can try this it some times works.
Super Canon User's method of resetting IP1600
1.Press Resume button hold for 1 - 2 minutes (count to 1 to 15-16)
2.Open the cover right away
3.Release Both cartridges out and then put cartridges them back again
4.Close The Cover
5.Turn Off Then Turn On again.
You can download the Resetter tools program from my website.
Click Link = http://www.4all2sell.com/reset-tools/ip1600st-RESETTER-TOOLS.zip
1. Download software for Canon iP1200, iP1600, 2200 Printers.
2. Unzip downloaded file by etc
3. Run GeneralTool.exe
4. Select the connected USB port number from USB PORT
5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION
6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selected waste ink counter will be reset. MAIN resets the main waste ink counter, PLATEN resets the platen waste ink counter.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters.
Free WinZip http://www.winzip.com/downwz.htm
Please call back to vote
All the best: Pineworks
Posted on Feb 27, 2010
mariolands
  • 2296 Answers
SOURCE: en la pantalla de mi
If you encounter "Error Code 5B00" it means that the Printer Counter Protection is Full and it required a reset and Ink absorber replacement, if you want your printer to work again. There are two ways to reset the Canon MP printer, One is by using a Software tool and the other is manually resetting the EEPROM of the printer. Below is the step by step procedure on how to reset your Canon printer.
1. Using MPtool Software to reset Canon MP Printer
Turn of printer then run mptool software this software automatically detect the printer.
Click reset main and reset platen button in the waste ink counter section.
If you want to reset the cartridge ink level, click reset black and reset color in the ink counter section.
2. Manual Reset of the printer
Turn off the Printers.
Press and Hold the button Resume/Cancel then press POWER button.
Release the Resume/Cancel button while keeping POWER button on press.
Press Resume/Cancel 2 times and then release all the buttons.
When the indicator recorded GREEN - click Resume/Cancel 4 times!
Turn off and On the Canon Pixma MP Printers. And your done.
Posted on Feb 07, 2011
Tengo un multifuncional x2600 y me marca error atasco de papel, ojala me puedan ayudar...ya cambie los cartuchos ya trate de sacar una impresion y no me permite hacer nada..
Quite las hojas de papel desde el alimentador. Trate de abrir la tapa de la impresora y retire ambos cartuchos. Mientras que la cubierta está abierta, compruebe si hay obstrucciones en la ruta del carro del cartucho. Compruebe si hay conexiones sueltas. Si todo está bien en el área del cartucho, cierre la tapa. Desenchufe y vuelva a conectar la impresora a la fuente de energía para restablecerla. Cuando la impresora se enciende, vuelva a insertar un cartucho en primer lugar. Cierre la tapa y comprobar que no existen errores. Si no, abra la tapa de la impresora de nuevo y vuelva a insertar el cartucho de otros. Vuelva a colocar el cartucho lo que está causando el error que aparezca. Usted también puede tratar de insertar un cartucho de diferentes conocidos trabajando para determinar si el otro es culpable.
Nota: Esto se traduce con translate.google.com.
May 20, 2011 | Lexmark X2600 InkJet Printer
Hola buenas noches tengo una impresora con este error c00e0402, le revise la tapas , atasco de papel y por ese lado esta bien, que mas puede ser, que le hago (ayuda)
buenas tardes,
Prueba estas soluciones de la p?gina Web de HP y de otros usuarios como t?:
http://forums11.itrc.hp.com/service/forums/questionanswer.do?admit=109447626+1299025019879+28353475&threadId=215818
http://www.fixyourownprinter.com/forums/inkjet/32918
Espero que esto sea ?til
¡Buena suerte!
Un cordial saludo,
Enolram
Mar 02, 2011 | Computers & Internet
No imprime y aparece error, atasco del soporte movil del cabezal de impresión. Habra la cubierta de la impresora, despeje cualquier obstrucción. Verifique la instalacion del cabezal de...
Qu? fabricante de impresora y modelo
Does not print and error appears, misfeed of the printhead's mobile media. There will be the printer cover, clear any obstruction. Check the printhead and ink cartridges installation. Close the cover by pressing OK to continue. Already has been realized in countless occasions and returns appear the same thing. The newly installed printer was tested with a photograph and when I wanted to reprint, the phrase appeared. It has no paper or anything stuck, it is already turned off and then reconnected but it does not work. What I do?
Apr 22, 2017 | Computers & Internet
Mi impresora kodak esp5 marca atasco de papel y no tiene nada atascado ya lo cheque de antemano gracias
hola necesito k me ayude mi impresora kodak 3250 trabaja bien per de repente estab imprimiendo y se quedo atasco de papel la cheque y se lo saque apegue la compu y nada sol ome falta deschufar impresora el cable de alimentacion ke va laimpresora ala compu sera ke podra ayudarme eso o volves a instalar el disco del drive ayundeme por favor eske tengo un ciber y la ocupo. por favor
atte. Marylen se los agradeceria mucho. gracias
Nov 19, 2010 | Kodak ESP 5 Printer
Tengo una hp photosmart c6280 y tiene un problema con un error 0xc18a0001 compre los cartuchos nuevos y sigue reflejando el mismo error, compre un sistema continuo y sigue dando el mismo error,quiero saber...
if you speak english and can read english go here and scroll down to Re: hp photosmart 8250 by Anonymous (7/26/08 2:04 PM) reply There is also help from HP support online chat
http://www.fixyourownprinter.com/forums/printer/51559
si usted no habla Ingl?s o leer aqu? es la conversaci?n que le dir? c?mo resolver el problema paso a paso de este error. si esto no ayuda usted puede ir a CV y obtener ayuda en l?nea o hablar con un t?cnico por tel?fono.
Aceptar que ten?a el c?digo de error CV 0xc18a0001 problema y aqu? est? la conversaci?n que tuve con el ..... James Cowan tecnolog?a: el c?digo de error CV 0xc18a0001 llamarse Ernesto: Voy a ayudarle en este sentido James Cowan: gran llamarse Ernesto: Yo entiendo que una c?digo de error con 0xc18a0001 con "Error de sistema de tinta" se muestra en el panel frontal del dispositivo Todo en Uno de la impresora. En lo correcto? Soy James Cowan: correcta Ernesto: Gracias por la confirmaci?n de llamarse Ernesto: ¿Me puede dar el n?mero del modelo del dispositivo Todo en Uno que est? utilizando: James Cowan c6250 llamarse Ernesto: Gracias por la informaci?n. Gracias Ernesto: James, por favor h?gamelo conocer la temperatura ambiente en el que la impresora se sustituye James Cowan: 67 grados F llamarse Ernesto: Muy bien llamarse Ernesto: Por favor, realice los pasos siguientes en el panel frontal de la impresora para resolver el problema de James Cowan: puede llamarse Ernesto: Pulse la tecla "flecha izquierda" . Presione la tecla "Setup" clave y suelte ambas teclas, la pantalla debe decir "Introduzca Especial Combinaci?n de teclas" Pulse y suelte el bot?n "Aceptar". llamarse Ernesto Por favor, ignore los pasos anteriores, James James Cowan: ok si nada parec?a hacer nada Ernesto: Por favor, realice los pasos siguientes en el panel frontal de la impresora Earnest el: Pulse y mantenga oprimido el "Imprimir fotograf?as" y "ojos rojos" botones. Suelte ambos botones. La pantalla debe decir "Introduzca Especial Combinaci?n de teclas" Pulse y suelte en la secuencia de "ojos rojos", "Imprimir fotograf?as", "ojos rojos" Ernesto: la pantalla debe decir "apoyo" y mostrar el rev FW (algo as? como R0616R) James Cowan : Ernesto COxxFN0723BR: Bueno Ernesto: 2. Pulse y suelte el bot?n de flecha derecha hasta que la pantalla dice "Men? de configuraci?n del sistema James Cowan: puede llamarse Ernesto: 3. Pulse y suelte el bot?n "Aceptar". James Cowan bien y que dice llamarse Ernesto estado de fallo de hardware: pantalla debe decir "error de estado de hardware: Despejado. Pulse Aceptar para borrar". Llamarse Ernesto: Pulse y suelte el bot?n "Aceptar". Mensaje se convierte en "estado de error de hardware aclarados continuar. Pulse Cancelar para":. Llamarse Ernesto Pulse y suelte el bot?n "CANCEL" tantas veces como sea necesario, de modo que, ya sea el "Welcome to Photosmart Express", aparece la pantalla, o bien, la tinta " El fracaso del sistema "aparecer?. NO TRATE DE NO ESCRIBA EN ESTA ETAPA. POR FAVOR James Cowan: puede llamarse Ernesto: Con el bot?n de encendido, apagar la unidad y desconecte el cable de alimentaci?n de la parte posterior de la salida de la impresora y la pared:. Llamarse Ernesto D?jame saber una vez que se realizan con el los pasos anteriores James Cowan: ok su desenchufado llamarse Ernesto: Espere 30 segundos para que el poder ser dado de alta ya continuaci?n, conecte el cable de alimentaci?n al enchufe de la pared primero y luego en la parte posterior de la impresora llamarse Ernesto: Encienda la unidad. La impresora puede mostrar mensaje "USO DE ENERG?A BOT?N DE PARADA DE LA IMPRESORA" seguido de "Pulse Aceptar para continuar". Pulse Aceptar. James Cowan: puede llamarse Ernesto: Quisiera saber el mensaje que muestra en la parte frontal del panel de la impresora James Cowan impresora: preparaci?n ocurriendo - no interrumpir Ernesto Bueno James Cowan: puede hacer su Earnest: Vamos a imprimir una p?gina de autoprueba de la impresora ya James Cowan: tratar bien llamarse Ernesto: 1) Carta de la carga, A4, o de plano no utilizados legales, papel blanco en la bandeja de entrada 3. 2) Aseg?rese de que la impresora est? encendida y cargada sin usar con papel blanco), papel. Pulse Configuraci?n. El men? de configuraci?n. 4) Pulse el bot?n flecha hacia abajo para seleccionar Herramientas y, a continuaci?n, pulse Aceptar. 5) Pulse la flecha hacia abajo para seleccionar Auto-prueba de informe, y pulse Aceptar. El auto-informe de prueba imprime. James Cowan se puede imprimir llamarse Ernesto: Muy bien, por favor, compruebe si todos los colores pritned perfectamente en la p?gina de prueba James Cowan: perfecto llamarse Ernesto: Gran .. Saludos James Cowan:! Muchas gracias Ernesto: James, ahora usted puede seguir utilizando la impresora de llamarse Ernesto: Le agradezco su esfuerzo y paciencia para tratar de resolver el problema.
Oct 01, 2010 | Office Equipment & Supplies
Que controlador debo descargar, o que parametros debo modificar para que la Ricoh Oficio 3245c me respete los parámetros que por defecto establezca para impimir con un aplicativo en Foxpro 6.0 ?
El programa se adapta a la configuración de la impresora en cada momento. Si, por ejemplo, se diseñó un informe para formulario tamaño A4, al momento de imprimir se debe configurar la impresora para ese tamaño de papel. Esto se hace desde Panel de Control, Impresoras, y en la predeterminada se ingresa por propiedades. Se debe establecer el tamaño de papel en A4 si, por ejemplo, está establecido por defecto en tamaño Carta. Desde un programa VFP se puede utiizar un comando para que, antes de imprimir el informe, muestre las opciones de impresión a fin de que el usuario pueda modificar, por ejemplo, el tamaño del papel: REPORT FORM MiReporte TO PRINTER PROMPT
Saludos cordiales
Sep 24, 2010 | Manuel Esteban Je joue e Kraland
Canon SELPHY CP710 Thermal Photo Printer Logo
96 people viewed this question
old marine
old marine
