Question about D-Link DES 3226 (DES-3226) 24x10/100 Mbps Networking Switch
My problem is under i not known as my switch ip and why i configuration to my switch
  • 53 Answers
Switch dont have any ip. this is a midetor for shairing data between more than one computer connect your computers to switch by cables and configure ip to your computers
Posted on Aug 07, 2009
Configure IP
If you are a well known person about the configuration of your modem you can reset your modem configuration yourself. But if you are not, go with any experts or technical person or user manual to do it. After resetting it check your IP address using the site Ip-Details.com .
Aug 20, 2013 | Arris Touchstone 450a (CM450) Modem
Tip
How to configure a Router?
How to determine the WAN configuration or Interntet configuration of a SOHO Router?
1. Connect the computer to the Modem via Ethernet cable. Make sure you are able to going online 2. After confirming you are online. Go to Start->Run. Type "cmd" on the Run window. 3. Type "ipconfig" on the command prompt or Black window or DOS window 4. You will be getting IP address,Subnet Mask and Default Gateway
There are 4 possibilities of IP address you can get
i)Public IP address under PPP adapter. -Router has to be configured in PPPoE mode to get a WAN IP. This will require a Username and Password from ISP ii) Public IP address under PPP adapter and Private IP address under Ethernet adapter -Router has to be configured in PPPoE mode to get a WAN IP. This will require a Username and Password from ISP iii)Public IP address under Ethernet adapter -Router has to be configured in Dynamic IP or DHCP mode to get a WAN IP -If it is still not getting a WAN IP address. * Click Mac clone on the router's WAN configuration * Power-cycle modem and Router. iv)Just a Private IP address under Ethernet adapter -Router has to be configured in Dynamic IP or DHCP mode to get a WAN IP -If it is still not getting a WAN IP address. * Power-cycle Modem and router.
After determining the WAN mode, it is time to configure the Router
1. Connect the Modem to the WAN port of the router. Connect the computer to the LAN port 2. Go to Start->Run. Type "cmd" on the Run window. 3. Type "ipconfig" on the command prompt or Black window or DOS window 4. You will be getting IP address,Subnet Mask and Default Gateway. The Default Gateway will the IP address of your router 5. Open a Web browser and type http://192.168.1.1(where this is the default IP of the router. This will be different from each manufacturer) on the address bar. 6. Go to WAN settings or Internet settings and select the options based on the above mentioned possibilities
on Aug 26, 2010 | Computers & Internet
How to configure router & switch
You shouldn't have to configure anything except the PC's should have IP and gateway set to auto.
Here is how it works:
A router connects two separate networks and manage the traffic between them.
In most home network applications the router connects your local group of computers and devices known as the LAN with the Internet, commonly called the WAN or Wide Area Network.
The router usually assigns unique Local IP addresses to all of the devices connected to it via a service known as DHCP. The addresses assigned by your router are private addresses http://en.wikipedia.org/wiki/Private_net... and are not routable across the Internet.
Dynamic Host Configuration Protocol (DHCP) is an auto configuration protocol used on IP networks. Computers that are connected to IP networks must be configured before they can communicate with other computers on the network. DHCP allows a computer to be configured automatically, eliminating the need for intervention by a network administrator. It also provides a central database for keeping track of computers that have been connected to the network. This prevents two computers from accidentally being configured with the same IP address. http://en.wikipedia.org/wiki/Dynamic_Hos...
Your cable or DSL modem will get a Public WAN IP address from your ISP's DHCP service. These public IP addresses are leased in blocks by your ISP and are Internet routeble. The modem is connected to the WAN port on your router. The router will manage the traffic between the devices on the LAN and the Internet.
If your 5 port switch is connected to one of the router's LAN ports and router's DHCP is on then it will configure the clients attached to It automatically.
Feb 04, 2013 | Computers & Internet
What is the default ip address for powerconnect 5212
You must assign an IP address to the switch to gain management access over the network. You may also need to a establish a default gateway between the switch and management stations that exist on another network segment. You can statically configure a specific IP address or direct the switch to obtain an address from a Boot Protocol (BOOTP) or Dynamic Host Configuration Protocol (DHCP) server when it is powered on. Valid IP addresses consist of four decimal numbers, 0 to 255, separated by periods. Anything outside this format is not accepted by the CLI program. notice.gif NOTICE: By default, the IP address is assigned to VLAN 1 through DHCP. If you select the bootp or dhcp option, IP is enabled but does not function until a BOOTP or DHCP reply has been received. Requests are broadcast periodically by the switch in an effort to learn its IP address. (BOOTP and DHCP values can include the IP address, default gateway, and subnet mask).
To display assigned IP settings using the CLI:
  1. From the Privileged Exec or Normal Exec level mode, type show ip interface and press <Enter>.
The assigned IP address and subnet mask displays.
  1. From the Privileged Exec mode, type show ip redirects to display the assigned gateway IP address. Press <Enter>.
The following example displays IP settings assigned by bootp or dhcp using the CLI.
Console#show ip interface
IP address and netmask: 10.1.0.1 255.255.252.0 on VLAN 1,
and address mode: User specified.
Console# show ip redirects
ip default gateway 10.1.0.254
Console#
Before you can assign a static IP address to the switch, you must obtain the following information from your network administrator:
  • IP address for the switch
  • Default gateway for the network
  • Network mask for the network
To assign a static IP address to the switch:
  1. From the Privileged Exec level global configuration mode prompt, type interface vlan 1 to access the interface-configuration mode. Press <Enter>.
  2. Type ip address ip-address netmask, where ip-address is the switch IP address and netmask is the network mask for the network.
  3. Type exit to return to the global configuration mode prompt. Press <Enter>.
  4. To set the IP address of the default gateway for the network to which the switch belongs, type ip default-gateway gateway, where gateway is the IP address of the default gateway. Press <Enter>.
  5. To save your configuration changes, type copy running-config startup-config and then press <Enter>.
notice.gif NOTICE: Only one VLAN can be assigned an IP address. If you assign an address to any other VLAN, the new address overrides the original IP address. The following example shows how to set a static IP address using the CLI.
Console(config)# interface vlan 1
Console(config-if)# ip address 192.168.1.5 255.255.255.0
Console(config-if)# exit
Console(config)# ip default-gateway 192.168.1.254
Console(config)#
To configure the switch for DHCP or BOOTP:
  2. At the next prompt, use one of the following commands:
    • To obtain IP settings through DHCP, type ip address dhcp
    • To obtain IP setting through BOOTP, type ip address bootp
  3. Press <Enter>.
  4. To save your configuration changes, type copy running-config startup-config, and then press <Enter>.
Nov 26, 2012 | Computers & Internet
Hi i have trendnet te100 s24 switch and i want to do some configurations on vlans but i do not known how to do that especial getting into the switch interface can you help on this.my regards to you
Usually all those switches are plug and play ..and do not need much configuration ..but if you want to make changes or you changed the way you connect to the main internet source ...you have to use the same computer that was used first for configuration ..(it will be seen as admin ) ..and the log to the settings will be made the same as for a router..Look on the back of the switch ..and see what IP address has from the factory ..and type the IP address into the browser and hit enter..
for example in internet explorer ..write on the address bar ..:
http://192.168.1.1
(this si just an example ..but the ip for the switch will be written on its sticker
it will take you to the log in page ..and in there if nothing was changed .. ..you have to complete the lines with the words admin ..and password..or with the ones you selected when you first configured it ..
In case you forgot all these..it should have a hidden button that will allow you to reset it ..and after that it will be to the factory defaults and will accept the IP on the sticker and the words specified in the manual for login ..to settings ..or ..will go to settings without the log on screen .
Nov 16, 2011 | Trendware TRENDnet TE100-S24 10/100...
Device some time working then disconnect.and not registred device why any solution.
If an L-series device is configured to use Dynamic IP address, a DHCP server must be present on the network where the L-series device is connected.
Please verify the following behaviors in order to isolate the problem:
1) Does clicking on the "Retry" button after 30 seconds work?
- If yes, please look at the attached document for advice.
2) If you configure the L-device to use Static IP, manually assign an IP address to it and configure it to access a server with a known IP address, can it connect successfully?
- if yes, your DHCP server is not running, not configured properly
or is not accessible from the sub-network where the L-device
is connected.
If you answered no to the above questions, please re-check all network cables and verify if the network connection status is Ok on the network switch where the device is connected to (check for a green light for the switch port where you plugged the L-device network cable).
~KenjiFox
Jan 07, 2011 | NComputing L230 Network Terminal
I am trying to configure a netgear switch (48 ports)but everytime I configure the static IP address for the switch, it keeps defaulting to a different IP address once it is powered down. I have also tried...
I'm not too familiar with Netgear switches, but if you told me you were having this issue with a Cisco switch, I'd tell you that after you change the IP address you need to save your configuration to NVRAM using the "copy run start" command. A Cisco switch will look to start using the configuration stored in NVRAM when it is booted. Changes are made to the configuration in RAM and are lost when reboot occurs unless they are first saved to NVRAM. Perhaps there is a similar command for the Netgear switch. Hope this helps
May 26, 2010 | NetGear 48-PORT 10/100/1000MBP SWITCH...
How do you change the default ip on a netgear jfs524 switch
There is a configuration utility program that comes on the disk that should have come with the switch. Install it, only good for Microsoft Systems.Run the utility, it will discover all your netgear switches. Select the switch you wish to alter its IP address. Under system/Switch Information, disable DHCP setting, and enter in the values for IP/mask/gateway that you want.
Feb 17, 2010 | NetGear ProSafe JFS524 24-Port Ethernet...
How do i find the IP Address on a HP Laserjet 2015N, i have tried pressing the go button for 5 seconds and this does not work
5 seconds may not be quite long enough.. please see extract below from HP web site for the P2015 series.
"On the printer, press and hold the green button for eight seconds, or until the LEDs above the button start to blink. The printer prints out the configuration pages. You will find the IP address on page 2."
Dec 09, 2008 | HP LaserJet P2015dn Printer
D-Link DES 3226 (DES-3226) 24x10/100 Mbps Networking Switch Logo
197 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
