Question about Danby DPAC10061 Air Conditioner
Air Conditioner Won't Turn On
The unit was plugged in and fully functioning in one room, I turned it off and wheeled it into another, set up the hoses again, plugged it in, and the screen just is light blue and nothing happens. If i pull the power the screen goes black.
Model is actually the DPAC10030
  • 883 Answers
SOURCE: Danby DPAC10061 portable air conditioner problem
you may have a factory defective unit that is not turning off the anti-frost heating coil (I have assumed yours contains this item based on your problem description). I would trade it in for a new unit, again assuming you have a warranty or the store offers a good in-store return policy. If this plan bombs, then open the unit and find the heating coil near the cool side of the radiator fins. then disconnect the power wires to the heater and prevent electrical short to wires with quality electrical tape.
Posted on Jul 07, 2007
  • 340 Answers
SOURCE: connecting a hose to take out condensation Danby dpac7008
you'll have to take it apart their is a switch which will have to be by passed .hook up your hose to a drain good luck . Tom
Posted on Jun 18, 2009
  • 54 Answers
SOURCE: Danby DAC5020 Air Conditioner fan works but not compressor
It could be as simple as being low on refrigerant. Depends on how expensive the unit is if its worth recharging and how big the unit is. Some small units will need to have a recharge point fitted which cost more of course.
Posted on Jul 02, 2009
SOURCE: It's 102F outside and the Danby dpac120068 air
I have heard other people do this I am not sure
Posted on Sep 05, 2009
heatman101
  • 43501 Answers
SOURCE: air conditioner isn't very cool
There can be a couple of things that could be happening...
The first and easiest thing is to check the air filter. Make sure that it is clean... clean it or replace it. Next check the air vents to make sure that they are open and giving you good air flow...
Also check to make sure that you are not icing up on the indoor coil... ice will tell you that you are low on refrigerant. You also could be low and not be icing over, but you would need to have gauges on the unit to check that.
Finally check and clean the outdoor coil...this also can give you problems if the heat is not being removed from the outdoor unit efficiently...
You may also have a unit that is sized in such a way that it hits the balance point at about 85...that means that your heat gain is equal to the capacity of the unit...I often try to size them for about that here in Northern PA. because wqhen seldom get hotter then that and the unit then is much more effective at removeing humidity at lower temperatures...
You can also check out the tips that I have wrote about Air conditioning2_bing.gif trouble shooting and maintenance...
Here is one about cleaning the condenser coil and at the bottom of that one are links to others..
Condenser Coil Cleaning Condenser Coil Cleaner
http://www.fixya.com/support/r3850183-condenser_coil_cleaning_condenser_coil
heatman101
Posted on Jul 12, 2010
Is my portable lg air conditioner suppose to be blowing hot air out of the back
YES
it works the same as any air conditioner where if you go outside and place your hand at the fan then it will be blowing hot air
In the instructions it should say place the rear near an open door or window or use the hoses to move the hot air out of the room
air conditioner units are basic heat transfer units where they take the heat out of the room and transfer it to the outside and in the process remove the moisture from the air in the room which i turn makes it more comfortable
Mar 14, 2016 | LG Heating & Cooling
Tip
Portable Air Conditioning great portable air cooling
Portable air conditioning offers you the convenience of mobility. All you have to do is roll the portable air conditioner to the room in which it's needed. Install an exhaust hose out a window or other opening (everything you need is provided) and turn it on. The installation process for these units is very simple. These portable air conditioning units are built small enough to be very mobile and are supplied with wheels for easy movement. A portable air conditioner will also work very well in apartment situations where you will often find a window unit is unacceptable.
Portable air conditioners are very unique in that they are portable and can be easily moved to different locations in your home or business. They can be a highly effective way to either help out an existing HVAC system in one room or cool a single room entirely. They are also one of the best ways to cool a room or area without having to install a window mounted unit.
These air conditioners use a compressor and Freon to cool just like normal air conditioning. They are very effective in cooling rooms and to keep the humidity low. Like normal air conditioners portable units extract hot air that must be vented. That is why they need to have the exhaust hose to the outside. These units can cool air as well as air conditioning done with window air conditioners. However they do not require installation like conventional window air conditioners this makes them very convenient for seniors or physically challenged people. Most portable air conditioners are supplied with a window kit. This kit contains exhaust hoses that will work in any window: double-hung, casement, awning or slider. Because they vent through an opening like a window they require no permanent mounting like window air conditioning.
Portable air conditioners are a very good cooling option for those who can't use the more conventional air conditioning methods. Remember though that this type of unit is not as efficient as most window units or conventional air. So while they may make your environment cooler, it won’t turn your tent into a room at the local hotel.
So as you can see these air conditioning units have some great advantages over other types of air conditioning. They are a great alternative for unique applications where central air or conventional window units are either unfeasible or too expensive. During special events, portable air conditioning can also be a great way to keep guests or equipment cool and comfortable. Always be aware though that because portable air conditioning will remove moisture from the air, they will also need to be drained occasionally similar to a dehumidifier.
Does your application warrant a permanent air conditioner of some form or should you just use a portable one? There are some interesting things to consider when making that choice. Weigh out all of the different options and make that decision based on what will best suit your needs.
on Dec 13, 2009 | Heating & Cooling
Why do red green and yellow lights flash and unit turns off
This is the unit telling you that you need to empty the water from the collection tank. As an air conditioner functions it removes water from the air. Much of it is discharged in the exhaust air but there is a collection tank that fills up as well.
Hook the hose that came with the air conditioner up to the rear of the unit, the upper discharge port (not the one on the floor), put the end of the hose in a bucket or outside, and turn the valve that surrounds the now-attached hose to "open." Press the power button on the unit twice quickly. it will power up and pump out the water. When it is done flowing turn the valve back to "closed," turn the unit off, and remove the hose. It should now function normally. This has to be done periodically.
Jul 12, 2014 | Sharp CV10NH Air Conditioner
How do i fix E1 error
  • Press the "Power" button to turn off your unit and then remove the filter from the filter panel on the side or front of your air conditioner. Refer to your manual if you are unsure where the filter on your unit is located.
  • 2 Inspect the filter. If it is dirty, brush off dirt, debris and lint. If it is really dirty, wash it with mild soap and water and allow it to dry completely. Reinsert it into its compartment. If your filter is worn out or damaged, purchase a replacement filter from an appliance or hardware store and replace the old one.Turn on the air conditioner. Move to the next step if the LCD continues to display the E1 error code.
  • 3 Check for a reset button on your air conditioner and press it to reset your unit. Some of the newer air conditioners have reset buttons to restore the default factory settings. Press the "Power" button on the front panel of your air conditioner to power down your unit if it does not have a reset button. Unplug the unit from the electrical outlet. Leave the air conditioner off for several hours to see if it will reset.
  • 4 Plug your air conditioner back into the electrical outlet and turn it on. If your air conditioner is still displaying the E1 error code, turn it off and contact a qualified technician because the room thermistor responsible for detecting room temperature may be defective.
  • Jun 10, 2014 | Amana Acd12ke-e Window Air Conditioner
    Ok So We Bought This. But We Have A Problem Does It Take Water Or Not? Thats What I Need To Know! Please Help!
    The DeLonghi PACA120E Portable Air Conditioner quickly cools rooms up to 400 square feet and comes equipped with several functions that make operation easy and low maintenance. Its 3 operating modes are supplemented with no-drip technology, an adjustable thermostat, 24-hour timer, and much more. This unit truly takes the work out of cooling medium- to large-sized spaces. Multiple Modes and Functions The DeLonghi A120E-also known as the Delonghi Pinguino PAC A120E-offers 3 operating modes and 3 additional operating functions that make this model versatile and energy efficient. Cool Mode: 12,000 BTUs of cooling power help cool large rooms, offices, or basements. Dry Mode: Reduce room humidity by removing excess moisture from the air. Fan Mode: Circulate air to keep your room comfortable without using a lot of energy. Low, medium, high, and an auto-speed are all included (auto speed selects a fan speed for you). Smart Function: Your AC uses Cool and Fan mode based on ambient room temperature. This function will also select your fan speed and keeps your room comfortable without wasting energy. Sleep Function: Using a low fan speed, the AC gradually reduces operation so your room remains comfortable but the AC runs more quietly and efficiently while you sleep. Boost Function: This function is ideal for the summer months and uses the maximum fan speed to rapidly reduce your room temperature. Useful Features Using DeLonghi's patented no-drip technology, this unit is "dripless" under normal conditions, meaning the AC will discharge all of the moisture collected from the air-so you typically won't have to worry about draining the water. When dehumidifying a lot of moisture in Dry mode, excess water may collect in the internal collection tank. Once the tank is full, the air conditioner will automatically turn off to avoid overflow damage. You can also use the included continuous drain hose as a no-fuss way to eliminate excess water as needed. An adjustable thermostat provides additional convenience by allowing you to set your room temperature. The DeLonghi portable AC will cycle on and off to eliminate over-cooling and maintain the set temperature. Additional Features Washable Air Filter: A washable air filter helps remove allergens and other particles from incoming air and saves you money on replacement filters. Quiet Operation: High efficiency compressor and components result in quiet performance. Electronic Controls: The LCD screen displays the timer and temperature settings, while intuitive indicator lights accompany each operating mode. 24-Hour Timer: This feature lets you program your AC to turn on or off up to 24 hours in advance, so it only runs when needed. Window Bracket: Double window bracket is included with purchase for flexible installation. Self-Diagnosis System: The unit includes a self-diagnostic maintenance system that identifies malfunctions should they occur. Remote Control: Use the full-featured remote control to change modes, set the timer, and select a fan speed up to 23 feet away from the receiver (on the front of the unit). Portability: Easy-roll casters and dual carrying handles make it simple to move this model from space to space.
    Aug 06, 2012 | DeLonghi PAC A120E 12000 BTU Portable Air...
    I have a portable air conditioner model LP0711WNR. My issue is when I drain the air conditioner, it only drains about one cup of water. Then, when I turn it back on it and use it, after about an hour it...
    The easiest way, is to tilt it over slightly when you drain it. But, be very careful doing this, as the unit has caster wheels and you don't want it to get away from you. If you have a helper, so much the better. Remember to always turn the unit OFF & Unplug it, before draining the water from the tank.
    I hope this helped you and thanks for choosing FixYa.
    Jul 21, 2011 | LG LP0711WNR Portable Air Conditioner
    We have a delonghi pinguino pac-t105 which just doesnt get very cold.
    Instructions Things You'll Need:
    • Clean cloth(s)
    • Garden hose (if necessary)
    1. Verify that the air conditioner is connected to a power supply if the unit is not operating. Reset the circuit breaker or fuse if necessary and ensure that the electrical cord is plugged firmly into the unit.
    2. Clean the condenser coil with water from a garden hose and wipe down the fan motor blades with a clean cloth if the air conditioner is flashing a yellow alert light or is not operating or cooling as expected. Remember to turn off and unplug the air conditioner prior to maintenance.
    3. Adjust the thermostat to a warmer setting if the air conditioner is producing air that is too cold. Adjust the thermostat to a colder setting if the air conditioner is not producing enough cold air. Allow a few hours for the colder or warmer setting to take effect.
    4. Clean away leaves, dirt, branches or other debris away from the main unit if the air conditioner is not functioning well or the motor is running excessively. Clean the grilles and vents to allow for proper air flow.
    5. Contact an authorized service professional if the above steps do not resolve the issue
    Jan 17, 2011 | DeLonghi Heating & Cooling
    My hitachi ductless split room air conditioner with heat pump is not heating my room , i have cleaned out the filters and unplugged the unit for 10 min and plugged in back in and it only blows cool air , i...
    dear sir
    please reset you air conditioner by it,s remote to heat mode and check thermostat setting maybe it has been turn off after remove air conditioner,s electric supply plug from electric source . i hope after reset it will be able to work again.
    hope answer the question
    thank you
    please vote!
    Oct 03, 2010 | Hitachi RAS-09UH Air Conditioner
    Fan blows room temp air, I can hear the AC kick in but it only runs for about 30sec to 1min before cutting out and making a sputtering sound that shakes the whole unit. Then it just goes back to blowing...
    check you condenser fan motor make sure it turns on, if ok you must clean the fins on the outside unit,with a water hose , make sure you turn power off first before taking a water hose to unit
    Aug 30, 2009 | EdgeStar AP420HS Portable Air Conditioner
    Heating & Cooling Logo
    129 people viewed this question
    Top Danby Heating & Cooling Experts
    Dan Webster
    Dan Webster
    Dennis Boxerman
    mintvl
    Level 1 Expert
    Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
