Question about Flat Panel Televisions
Child lock my daughter lock the television with the child lock and the remote is lost. I brought a universal remote but it wont work. the television is a hitachi c21-rf80s year june, 2005.
Re: child lock
My daugter lock my sharp aquos with the child lock and i don,t know the pin
Posted on Oct 23, 2008
0 characters
3 Points
Polaroid 1507 tv locked. Got it on with universal remote but can't access menu
Check it by set it up with other codes to Poloroid. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
Mar 28, 2014 | Polaroid Flat Panel Televisions
My Palsonic LCD TFTV81PBHDT remote is broken and buttons on side panel do not seem to work. How can I switch tv on to tune to universal remote? Do the side buttons have some sort of child lock function...
you can program most universal remotes to work the tv and menu the child lock is activated on the tv and the buttons will not work only power button will work as long as it has not been set to not work when made. some are set this way. but a remote with the right code set will turn on the tv.
Sep 20, 2013 | Flat Panel Televisions
Reset child lock code on Panasonic TH-50PX80U tv without remote
You can't unlock the child lock without its remote cotnrol.
Jan 16, 2013 | Panasonic Viera TH-50PX80U Plasma TV
I haven't the right remote but have a universal remote and the tv has a child lock i cant seem to erase
I dont know if you can erase the child lock but if your universal remote has a settings button you should be able to turn the child lock off through the setting menu
May 12, 2011 | Samsung Flat Panel Televisions
I have a problem with the remote control that is not working, I have taken it local technicians but nothing . My TV is in child lock so I need a remote for the tall big telefunken TV
Hi what you can do is to buy a universal remote control for this TV to remove the child lock. You can get that online or on any electronic shops in your area. Once done here is the instructions on how to remove the child lock using remote.
Look at the "Power" indicator light on the front of the television to check if it is blinking. When blinking, the child lock is enabled. You can also check by pressing the "Power" button on the television.
Point the remote control at the television and press one of the buttons on the number keypad. The "Power" indicator light will stop blinking, indicating the child lock is turned off.
Lock the television again by pressing and holding the "Power" button on the remote control until the indicator light starts blinking. It takes approximately three seconds before the light turns on. Thanks
Feb 01, 2011 | Flat Panel Televisions
I have the child lock on and the remote control is broken. How can I turn the tv on without the remote control
The power button on the TV doesn't work because of the child lock?
I went over the copy of your manual for your TV. It must be the child lock timer problem.
I would try leaving the TV unplugged for 30 mins and see if that reset the TV and releases the lock.
If it doesn't work, the remote needs to be replaced. A universal remotes aren't really universal when you need to use special buttons. The remote made for the TV is the best.
If your TV is the model 47PFL7403D, here's the cheapest place to buy a replacement.
May 12, 2009 | Philips 47PFL7403D 47 in. LCD TV
Unlock child lock
Generally, No. You can buy a universal remote and hope it supports the command to unlock the TV; otherwise you need the specific remote for that TV since the child lock function is very specific to each product.
Aug 28, 2008 | Flat Panel Televisions
Turn off child lock
To unlock the Panel Lock, Parent Lock, or Child Lock, follow these steps:
  1. Turn on your TV.
  2. On the remote, press the Menu button. The Set-Up Menu appears.
  3. Scroll to the Key Lock function and set function to Off.
  4. Press the Exit button to exit.
Note: If you don't have a remote, you may be able to do the same thing by pressing the Menu button on the front or side panel of your TV and using the volume or channel up and down buttons on the TV to scroll to the Key Lock function and set it to Off.
Oct 02, 2007 | Flat Panel Televisions
Television "locked"
Yes only the original remote will unlock it. 10 out of 10. I have unlock it also with Ellis universal but buttons is not the same.
Sep 14, 2007 | Flat Panel Televisions
Flat Panel Televisions Logo
741 people viewed this question
Top Flat Panel Televisions Experts
Are you a Flat Panel Television Expert? Answer questions, earn points and help others
