Question about Bosch Evolution 300 SHE43M05UC Stainless Steel Built-in Dishwasher
Large amonts of water does not drain from tub and spills on to the floor. I have a lg. single drain sink with an ACE model 2000 1/2 hp disposal.
    Problem Solver:
  • 14 Answers
Is the disposal working? if it isn't turning then find an alan wrench and turn it by hand there is a place to do that on the very bottom of the disposal in the center. the disposal should work after that and unclog the sink.
Posted on Aug 01, 2009
Model 81
Roto rooter the drain pipe in the wall. It's plugged. The water goes up the vent pipe to the roof that's why the water comes back in the sink when you shut off the disposer.
May 15, 2014 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Insinkerator disposer causes water to drain slowly from sink
The pipe from the disposer outlet to the sink drain Tee is partially plugged. Remove the drain pipe from the disposer to clear the obstruction.
Apr 11, 2014 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Odor coming from disposer
Hello, Tell your husband to wash his feet some place else, OK. it needs to be cleaned. Don't put you hand in it, OK. On the top in sink remove the rubber flapper and clean it with soap water and vingear. Put about four large cups of ice and tuirn on the disposer. The ice clean out any stuff that in the chopping blades. Mix up a sink of water, soda and a little clorex in the disposer sink then let the sink drain and turn on the gargage disposer then let it run while water is running into it. Do a cleaning procedure once or two a month. couple of lemons, Clorex, baking Soad, this stuff will work great. It will make you disposer smell like fresh spring day but tell you husband to keep his feet out of the kitchen sinks. GB...stewbison
Sep 24, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Ace 2000 clogged grbage disposal backs up water
Take apart the tubular drain under the sink.
Put bucket under the disposal and turn on disposal. Stuff should come flying out.
Hang some rags over the disposal to direct stuff downward.
Clean P-trap and reassemble tubular drain pipes.
Open following link for for tubular drain pipe tips:
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Jul 26, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I have a double sink with the ACE 2000 garbage disposal on the right side. The disposal will not drain. The disposal drain runs straight to the down pipe for the left sink. That pipe goes straight into...
If it is grease you could boil a pan of water and pour down the disposer but you would only move the grease further down the line to cool and possibly cause a bigger problem. Disposers are far too easy to remove to take that chance. There is a bolt or screw located on the disposer where the horizontal line hooks to it. Simply remove that bolt or screw and then spin the attachment ring directly beneath the bottom of the sink and the disposer will come right out and you can look right into it to see what is causing the restriction. Be sure to unplug the disposer from the electrical outlet before you start. If there is water in the sink where the disposer is located, dip it out and pour it down the other side before you start too, it will reduce the mess you are going to make.
Jul 12, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Here is an interesting problem. We have a Badger 5 1/2 Hp Garbage disposal hooked up on left side of double sink. The Disposer runs, spins, but will NOT drain.. at all. Left sink with the insinkerator will...
If this connects into a tee between the sinks, usually if the tee is in the middle of sinks, then often there is a divider in the tee to keep water from backing up the other drain. Remove the tee and inspect to be sure it isn't cloggged. Also put a bucket under the outlet. Try running it this way, if you get good flow you know the disposal is working
Aug 18, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Insinkerator badger 5 runs sink wont drain
Properly piped, your arrangment should look similar to this picture so that there is a separate trap for the disposal and the other sink basin.
Mar 05, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Disposal won't drain
sounds silly but try loading it with ice and turning it on if there is debris in it the shards of ice will help to clean it
Oct 07, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
GE disposal won't drain
It sounds to me like the knock out plug leading from the disposal has never been removed. Remove the drain like and you may find that there is a thin plastic wall preventing any water from leaving the disposal. Just place a small screwdriver in the opening up against the plastic barrier and tap it out with a hammer. good luck
Jan 21, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Bosch Evolution 300 SHE43M05UC Stainless Steel Built-in Dishwasher Logo
240 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
