Windows XP Start up
When i start up my computer, i get a black screen with a lot of computer details like bios installed, Raid volume and physical disk details , and also controller bus# and at the end i can see Press control+I to enter set up configuration utility..
After this screen disappears , only then i can see Loading windows screen .. and then login screen.
This started happening after i formatted my computer.. How do i bypass this black screen and go directly to loading windows screen..
  • 746 Answers
Dear! You have to go in BIOS setup and choose boot utility and then select silent boot if it will enable you have to disable or if it will disable it will have to enable. Your problem will solve.
Posted on Aug 01, 2009
My window xp is corrept what to do
Don't worry it is very easy to fix it.
Let's get started!
Step 1: Rule out hardware issues. Windows Repair will only fix software problems. Hardware issues can also cause boot problems (i.e. bad hard drive, memory, CPU, or power supply).
Step 2: Backup. It's always a good idea to backup your important data before making changes to Windows XP. Relax, if you follow these instructions your data will be perfectly safe.
Step 3: Boot from your Windows XP CD. Insert the Windows XP CD into your computer's CD-ROM or DVD-ROM drive, and then restart your computer. When the "Press any key to boot from CD" message appears on the screen, press a key to start your computer from the Windows XP CD. Can't boot from your CD? Please see the note at the bottom of this page (Configuring Your Computer to Boot from CD).
Step 4: A blue screen will appear and begin loading Windows XP Setup from the CD.
Note: RAID/SCSI/Unsupported UDMA users:
You will be prompted to "press F6 to install any third party SCSI or RAID drivers". Most users will not have to press F6, but if you are running RAID, SCSI or unsupported UDMA controllers, then you will have to have your controller drivers on a floppy disk. If you are unsure whether you have RAID/SCSI, then simply let the CD load without pressing F6.
When completed loading files, you will be presented with the following "Windows Setup" screen, and your first option. Select "To set up Windows XP now, press ENTER". DO NOT select Recovery Console.
When presented with the screen below. press the F8 key to continue.
Next, Windows Setup will find existing Windows XP installations. You will be asked to repair an existing XP installation, or install a fresh copy of Windows XP.
If no installations are found, then you will not be given the option to repair. This may happen if the data or partition on your drive is too corrupted.
Note: If you install a fresh copy, all data on that partition will be lost!
Your almost finished! Windows XP will appear to be installing itself for the first time, but it will retain all of your data and settings. Just follow the prompts, and have your CD-KEY ready if needed.
Do you have more than one system, or lost your CD-KEY? Visit the keyfinder page to retrieve your CD-KEY.
Update: Due to the proliferation of the Blaster and Welchia Worm/Virus be aware that a Repair Install will leave your system vulnerable. You can get infected within seconds. Do not go on line until you have enabled XP's firewall first.
Remember to run Windows Update! (install critical updates first)
Many computers are not configured to boot from the CDROM. If you cannot boot from the CDROM, this is probably due to the boot order of your devices being incorrect. You can change this in the BIOS.
You enter the BIOS from the first screen you see when you turn your computer on. To enter your BIOS, most users here will press the DEL key.
Most Dell, Toshiba, Gateway, Sony & HP systems will press F2.
Compaq users will usually have to press F10.
IBM typically uses F1 or F2.
Other brands may have different keys to press to enter setup, F1, F2, Del, Tab and CTRL+S. If possible see the manual for your computer or motherboard. Also, the BIOS will usually display which button to press to "enter setup" during POST (if it flashes by too fast, press the Pause key).
When you enter the BIOS setup, you need to change the boot order. The CDROM should be setup before the Hard Drive. Each BIOS is different, but here is an example:
Jun 24, 2010 | Computers & Internet
How to install windows 7 on Satellite A205-S5880
To install Windows 7 no need for RAID driver. If you face issues in installing Windows 7 disable RAID in BIOS, install Windows 7 and then install RAID driver.
How To Manually Upgrade from Vista to Windows 7 - Satellite A200/205:
http://cdgenp01.csd.toshiba.com/content/support/downloads/PSAF3U-PSAF6U-Win7UpgradeInstructions.pdf
Windows 7 Drivers page:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2060003&rpn=PSAE3U&modelFilter=A205-S5880&selCategory=3&selFamily=1073768663
Dec 31, 2009 | Toshiba Satellite A205-S5880 Notebook
Acer 1360 black screen cant get start menu
If you are getting a Blue screen repeatedly and you can't start up to windows in any custom setting ( from f8 start up menu ) one way to solve the problem is to Use the restore disc or windows installation cd or dvd to install windows into the computer or perform a repair installation if a windows already exists on the computer and the setup can find it.
how to perform a repair installation
this is for xp, but its similar on 2000 and on vista.
insert your Windows XP Setup CD, and restart your computer.
1.When the Press any key to boot from CD message is displayed on your screen, press a key to start your computer from the Windows XP CD.
if not then the computer is not set to start up from a cd, you can either enter the setup / bios to change that setting OR right when you power up the computer look at the screen it will say what button to press in order to enter boot menu or bios, it will very likely be button F12 or similar, it should say on the screen when you power on.
if it doesn't, then you need to go into the bios and change the boot order so that the computer starts from the CD first.
after that you should be able to start from the cd and install the OS (Operating system, eg.Windows)
here's some info on how to work the bios: http://www.whitecanyon.com/how-to-change-boot-order.php
Repeat step 1 when you have changed the boot order.
2.Press ENTER when you see the message To setup Windows XP now, and then press ENTER displayed on the Welcome to Setup screen.
3.Do not choose the option to press R to use the Recovery Console.
4.In the Windows XP Licensing Agreement, press F8 to agree to the license agreement.
5.Make sure that your current installation of Windows XP is selected in the box, and then press R to repair Windows XP.
6.Follow the instructions on the screen to complete Setup.
7.Ones windows is working you will need the drivers for your computer, they are at the makers website, for hp and compaq. www.hp.com for acer http://support.acer-euro.com/drivers/downloads.html for all other brands go to google and write Brand drivers. Should get you to the right place. Dell is most likely www.dell.com and so on.
May 18, 2009 | Acer Aspire 1360 Notebook
Bios Utility Setup
Tell it(The BIOS set up screen) to load default settings. Start up CD driver first. Then  Save and exit. Now install Xp disk and turn computer back on. After windows loads . Run the install disk that came with *********** board.  If I missed something or is doesn't work exactly as I stated , write back and I wil assist you farther.
Feb 16, 2009 | ASUS P5QL-E Motherboard, LGA775, Intel P43...
ACER Aspire M5620 System Serial Number: PTS860X0227410A4022700 I want to put windows XP on it but it has window Vista. So to put Xp on the computer i went into the bios and try to change the setting...
You cannot just switch from RAID to IDE!!!
This has nothing to do with the operating system!
It is a hard disk control and arrangement protocol for transmitting and storing data.
RAID: Redundant Array of Independent Disks
IDE: Integrated Drive Electronics
It is a hard disk drive interface and RAID is commonly used in servers for data redundancy and faster access. There are several versions of RAID. RAID Wikipedia
if you want to install Windows XP first of all set in the BIOS back to IDE (or simply choose default settings)
Start up your computer save any data you might want to save.
Reformat your hard disk (you will lose anything you had not backed up) and install XP presumably from a CD you have.
ultimately you can install XP and just tell her during install to reformat the hard disk.
Nov 07, 2017 | Acer Computers & Internet
1 TB HD of Samsng is not recognized
some motherboards and processors are compatiable with certain hd's only. Here is a list:
Pentium: 2GB through 5GB
Pentium 2:5GB through 20GB
Pentium 3: 20GB through 40GB
Pentium 4: 40GB through 500GB
Pentium D: 40GB through 1TB
Celeron: 2GB through 500GB
All AMD's: 300MB to whatever.
so, that's probably your problem. I suggest
Jun 05, 2008 | Asrock K7VT4A-Pro Motherboard
MS-6787
install raid drivers only if you are certain that you are on RAID and even before you install raid drivers make sure the RAID controller is set to on in BIOS. if you dont have RAID setup then please dont install the RAID drivers. the only reason i think you are computer is not going past the windows xp logo is you might have floppy drive in the boot sequence(in the BIOS screen) set to on or you must be having a USB device connected to the computer. set it to "no boot" and things should be fine.
Jul 04, 2007 | MSI P4MAM-V SND/LAN/VIDEO (6787060)...
Computers & Internet Logo
96 people viewed this question
David Payne
David Payne
