SOURCE: Machine sews only in reverse
Be sure you are in the correct stitch pattern...if you are on a buttonhole stitch or a stretch stitch it normal for the machine to sew backwards. Be sure your length is to the right of 0 and not in a strtch stitch model or buttonhole mode.
Bonnie
SOURCE: Bernina 1630 problem
Your feed dogs sound like they are getting stuck,chec whether they are on the down position,and also make sure that you have cleaned any lint that builds up in the bobbin area, if all fails it will have to go into the technician,
SOURCE: Janome Excel 5124 reverse lever
If you pull the bottom off the machine (half a dozen screws) there is a cam on the main drive shaft. The cam is probably jammed in the reverse position due to lack of lubrication on the shaft. You can move the cam back manually and it will operate in forward direction. It appears that the shaft needs lubrication.
SOURCE: my bernina artista 180 is stuck in reverse and
unscrew lever a bit and lower to stitch forward
Thanks. I know. Hoping I can fix it myself.
You can look inside the top and move those selector dials and watch how and where things move. Perhaps you will figure out what has slipped.
