SOURCE: HOW TO CONNECT SUB WOOFER IN 4CH CAR AMP
sounds like you need another amp, if the amp has a speaker already connected to each channel, you have no open channel to connect a sub-woofer.
Some years ago I seen an amplifier that was designed to use 3 speakers on 2 channels. what they did was had a speaker on each channel and then they bridged the 3rd speaker across it. That amplifier was designed for this configuration, unless you have an amplifier like that you should not try it. It may result in smoke from the amp.
SOURCE: Connecting a sub-woofer to Pioneer VSX-453 surround reciever
I got the same issue. But, I go ahead hooked it up two banana plugs on teh VCR outlet. It works fine on my Cerwin Vega Sub.
SOURCE: HTS 6500/37 sub woofer
the reciever should have a "subwoofer level" setting, or a "bass level control" If you cannot find this then try to place the "sub-woofer" away from walls and elevate it from the floor. This will reduce it's loudness/ intensity at annoying frequencies...
Good Luck
SOURCE: I have a active sub woofer (akari bazooka) but the
hi,
You can't connect the pre out of your AVR to this sub woofer. Do one thing connect the frond left/ right channel speaker "B" out of harman kardon to the sub woofers left right speaker in put. you can connect the speaker out "A" to your normal left right speakers. Remember to switch Speaker "A" and "B" in ON position in your AVR. Also do one thing go to the speaker setup of AVR and switch OFF (slelect NONE) the sub woofer.This will disconnect the sub woofer pre our and the sub frequency will mix with frond left right channels.
ok
