Question about Avanti DER24CSS-1 Electric Kitchen Range
Oven not working
Broil and surface burners work fine but oven element does not work. I would try to chcek connection but I cannot see a way to get to the "closed" element.
Please HELP!
  • Bill Hutton Dec 02, 2007
    This is Bill again....could someone please tell me how to remove element and replace. I just opened bottom (above storage drwaer) and removed metal "sheet" viewing broken oven element. Now I must replace it
    Thank you in advance for any help
  • green_lady Apr 21, 2008
    I have the same problem. Had appliance repair out 3 times and each time they replaced it with a "modified" element since there was such a backlog for the Avanti element. I think it overheats and shorts out.
Broil and range work but bake does not
check oven burner tubes and ignitor and flame sensor
Sep 19, 2017 | Frigidaire Ovens
Oven has power but none of the burners on top or the bake or broil elements work
Go to breaker panel,turn off and wait a minute and turn on,may reset it.
Oct 28, 2012 | Kenmore Kitchen Ranges
Oven and elements not working,
the oven and burner relay that supplies power to the bake/broil/top surface units is bad or the signal to latch this relay is missing from the control panel
Jun 03, 2012 | Moffat Ovens
The lower heating element broke in half, while I was waiting for the part we used the broil but the wires that attatch to the lower heating element touched the medel and their was a popping noise and now...
you may have blowen the fuse on one side of the power line . the burner's on top may still work . so replace the element that was bad and any wring that shorted and reset both fuses. so that 220 is present . and oven and top burners should be ok hope this helped . mm
Jul 11, 2010 | Ovens
Surface burners light but oven does not.
ignitor probably ...when you are sure of the part you need check out Appliance Parts Solutions....cheep parts!
Feb 08, 2010 | GE Kitchen Ranges
This morning, I went to turn the oven on to preheat. The oven light came on, but when I passed 250 degrees, it went back off. I turned the knob around to broil, the light came on again. But the oven never...
Check the breaker pannel or fuse box. The elements work on 220 volts the lights on 120 volts. If this doesn't help repost and well try again
Hope This helps
Please leave feed back
Nov 29, 2009 | Kitchen Ranges
My frigidaire oven won't heat. The burners work
You have two elements turn on the broil and see if the top element comes on if it does replace the bottom element.
Aug 23, 2009 | Frigidaire Ovens
Sounds like a heating element. Same thing happend to my oven. You can find them around 50-60 dollars. Veryy easy to install, just remove a couple of screws and remove old element and put in new one. Make sure you shut off power to oven firstg of course.
Oct 08, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Avanti DER24CSS-1 Electric Kitchen Range Logo
Top Avanti Kitchen Ranges Experts
Craig Butler
Craig Butler
ray gallant
Are you an Avanti Kitchen Range Expert? Answer questions, earn points and help others
