Pg 8 of the manual:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwjAhPWt1NraAhUk3YMKHd6EBpEQFggpMAA&url=http%3A%2F%2Fkeysew.com%2FWebpages%2FDemoimages%2FJuki_LU-563_Instruction_Keyfooter.pdf&usg=AOvVaw2xqnworCuSmkeYj5JwpA50
It looks to me like the bobbin should turn clockwise on the bobbin shaft (enlarge the picture), but the instructions are not very clear.
SOURCE: top thread isnt picking up
Use a fresh needle and make sure that you place the flat side to the rear when you insert it. Use a coin to turn the needle screw. Also, get a free downloaded manual from www.singerco.com
SOURCE: does the bobbin on a
You can download a manual from here http://www.singerco.com/accessories/manuals.html, just type in the model number and click on 'search' to locate your machine's one.
As a rule of thumb, the thread usually comes off a bobbin goes through the tension then reverses direction back the other way. So as you pull the thread, the bobbin usually turns anticlockwise. But always check the manual to be sure.
SOURCE: My bobbin thread keeps bunching
try changing the needle
rethread the machine top & bobbin, using every thread guide
make sure the thread has not come off the thread take up lever
here's a link for a manual
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_LS_2125_EN_272.PDF
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_LS_2125i_EN_1628.PDF
SOURCE: Why is the thread shredding above the needlehole on my juki lu563
One time I had my machine serviced and the guy used a metal thread to widen my needle hole. Your problem happened to me too I think the thread is not the best quality. Also rethreading might help. Testimonials Ergonomic Travel Neck Pillow Microwave Hot Cold Packs
