Does opening the dryer door during the cycle (to take something out) wreck the machine?
  • 3,418 Answers
No it doesn't
Posted on Apr 27, 2018
zeusfaber
  • 247 Answers
SOURCE: Dryer heats but no condensing of steam
The cold water feeds for condenser cooling and for wash cycle drum fill are controlled by separate solenoid valves (manifolded together at the cold water inlet hose union). When the solenoid on my condenser coolant valve failed a couple of years back, I got symptoms like yours. A new pair of valves isn't expensive to buy and is a trivial job to fit. If this is what has been happening, suggest you also inspect the insides of your dryer fan and of the pump - neither of mine took really kindly to having been cooked for hours on end. Alastair.
Posted on Jan 31, 2007
COXY
  • 76 Answers
SOURCE: Bosch Aquasensor Detergent Dispenser door wont open during cycle
Behind the dispensor door there is a small selanoid you will need to replace this, test to see if its open circuit, alternatively you can just place the detergent in side the machine before you put it on a wash cycle is this would have the same effect. the only cycle you can not do this on is the one with the prewash, I think its number 1.
Posted on Nov 18, 2007
hotuna
  • 288 Answers
SOURCE: miele G660 premier dishwasher
There is a solenoid that opens the door to the dispenser. You can check it with a volt/ohm meter. Sometimes large dishes can block the door keeping it from opening. I personally know on some Whirlpool washers (because it was mine) that if the bottom drawer is put in backwards, it wont let the door open. When I opened the main door, then the dispenser would flop open. You need a meter to check this part if its not the other things. Without it, you are just guessing.
Posted on Mar 15, 2008
SOURCE: Inside detergent compartment door will not open during cycle
to much detergent clean it out and start over
Posted on Jan 31, 2009
WRMtech
  • 70 Answers
SOURCE: during the drying cycle, the dryer door opens
Chances are the little plastic latch keep is broken. Look at the door and locate a peice that will press into the front area where the clothes go in.
Once you see it, check the keeper and see if it is broken. The door should not just pop open.
Posted on Feb 26, 2009
How do you dry clothes in this machine please
A fairly common problem! The official instructions are
Before using your dryer, wipe the dryer drum with a damp cloth to
remove dust from storing and shipping.
1. Load clothes loosely into the dryer and close the door. Do not
pack the dryer. Allow space for clothes to tumble freely.
2. Turn the Cycle Control knob to the recommended cycle for the type of load being dried. Use the Energy Preferred Automatic Setting (,) to dry most heavyweight and medium weight loads. See "Drying, Cycle, and Temperature Tips."
3. Select a temperature setting on models with a Temp/Fabric selector. The cycle descriptions include temperature setting suggestions.
4. Push the START button.
Stopping and Restarting
You can stop your dryer any time during a cycle.
To stop your dryer
Open the dryer door or turn the Cycle Control knob to OFE
NOTE: The Cycle Control knob should point to an Off area when
the dryer is not in use.
To restart your dryer
1. Close the door.
2. Select a new cycle and temperature (if desired).
3. Press START
Extracted from
http://www.manualslib.com/manual/511763/Whirlpool-Lte5243dq.html?page=10#manual
Nov 14, 2015 | Whirlpool AWZ410 Front Load Washer/Dryer
Dryer door pops open during cycle
Good Afternoon Friend,
I understand that your Frigidaire dryer door keeps popping open during the cycle. I suggest making sure that the door has been completely closed before starting the cycle. If this is done, and the door is still popping open, there might be something going on with the door latch. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine why the door keeps opening mid-cycle. Hope this is helpful.
-Best regards-
WP
Jun 07, 2014 | Frigidaire Electric Dryer
Dryer door opens during drying cycle, had it "repaired" but still opening - worked originally well for about 2 years - but cannot get it to stay closed for the entire drying cycle.
these newer dryers are such garbage with their thin Sheet metal. see if the door is bent by the hinges. Dropping clothes on the doors bend these newer machines. then they don't seat correctly
Aug 05, 2013 | Kenmore Elite HE4 Electric Dryer
The door on my Hotpoint Aquarius Dryer CTD00 pops open during cycle is it the door catch that's worn?
If the door latches correctly at the time of wash then it is possible that there is a false trigger to release the door, if so you need to check on the lock.
check on this link for tips: Door lock
Jan 12, 2013 | Washing Machines
Whirlpool duet sport dryer getting an f26 error
DOOR SWITCH ERROR
If the door has not been opened for 3 consecutive cycles or the door switch is open while the door is locked for more than 5 seconds.
Possible Causes/Procedure
-Door not opened during 3 consecutive cycles.
1. Open and close the door.
2. Verify CCU operation by running a Diagnostic Test or any cycle.
-Door switch open while door is locked.
1. Push the door and check if it is completely closed.
Thanks for using FixYa*&^
Nov 27, 2010 | Whirlpool GEW9250 Electric Dryer
Shuts off too soon when the clothes are still wet
Make sure the door does not come open while running.
If it turns off only during the auto-drying cycle, the moisture sensor may have failed.
If it turns off during the timed cycle, the operating thermostat has most likely failed and the high limit thermostat turns the machine off when it gets too hot. After the machine cools down, it will start until it heats up and turns off again.
Apr 29, 2010 | GE DWSR483EBWW Electric Dryer
My lg door will not unlock
this kind of door lock is called PTC door lock.It is designed for protecing you from opening the dooe during the washing and spining cycles which may hurt you.So, if you want to open the dooe during cycles,pls press "stop",then ,wait 2 mins,you will be able to open it by then.the other situation is that,the power is cut off during working cycles,solution is:re-start the washer and directly open the door.Pls note that this kind of lock has to work under power
Mar 14, 2010 | LG WD-12126RD Front Load Washer / Dryer
During the drying cycle, the dryer door opens
Feb 25, 2009 | Dryers
Washing Machines Logo
747 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
paul
paul
