SOURCE: Disney 13' Princess tv
You've tried all the codes for your TV, but you still cannot get the remote control to operate your TV.
Hope this helps
SOURCE: need TV codes for using the comcast DTA remote
try these codes for broksonic 10236,10463,11911,11938, 10030,11935,11929
SOURCE: Comcast remote code for sylvania lc427ssx
I had the same problem, I ended up buying an RCA Universal remote, when I had no luck with the codes I tried the autoscan feature, to my surprise it worked perfectly.
SOURCE: Need TV codes for using the comcast DTA remote
I just went through this last night with combo, similar model. They tell you to use the power off test to see when you've got it - nothing worked for that. Then I tried the Panasonic codes and used the volume control as a test, which is much more important, and I found the 3rd code worked for that. I figured, close enough for me, and better than nothing.
