Question about Cell Phones
Ck3100 . Makes chirping noise on ignition on, display doesn't show any information, can't use to make calls. Was an occasional problem, is now an almost permanent problem. No damage or misuse. unit just over 2 years old.
3 Suggested Answers
dancandoit
  • 436 Answers
SOURCE: Parrot CK3100 cutting out/Blank
try pushing the wire into the display, this commonly comes loose.
Posted on Feb 08, 2010
  • 95 Answers
SOURCE: my ck3100 display shows adifferent name from my
Do you have the message "good bye" when you switchin off the ignition key? If yes, no one relation with the install and the power supply of the kit.
You can also trying to pair the phone via the menu of the kit without synchronisation to see if it works, cause sometime the synchronization is not working like it should.
(settings-
Posted on Aug 08, 2010
My 2005 trailblazer makes a bird chirping noise. Exactly like birds. My mechanic replaced the belt but it is still making the noise.
If is a serpentine belt, take it out and check the belt tensioner. some of them have a screw that allows for tightening/loosing the belt. Sometimes it looses some bearings and it could chirp.
May 20, 2014 | 2005 Chevrolet Trailblazer Ext
Taco 1600 series in line pump makes an occasional "chirping" noise that transmits through all three stories of the facility through the plumbing, could this be a sing of a failing bearing, pump is 10 years...
Pumps can have noises from bearings, bushings, cavitation and excess wear on the impellor and the wear rings. It is time to take it out of service and inspect it.
Dec 09, 2013 | Taco 1600C3E80121151 1600 Series Cast Iron...
Thud in trunk at take off
There are many possibilities that can cause car to make noise.
There is N-number of possibilities for the car to make thud noise or any other kind of noise.
For step by step troubleshooting this problem, I suggest you to refer the help links mentioned below. Its a complete solution with proper explanation to identify the cause of problem: ------
Click the link below: -----
Vehicle making Clunk Thump Thud noise?
http://howtobyme.blogspot.in/2012/03/vehicle-making-clunk-thump-thud-noise.html
Car makes clicking noise?
http://howtobyme.blogspot.com/2011/11/car-makes-clicking-noise.html
Car makes whining noise like driving on rough pavement?
http://howtobyme.blogspot.com/2011/12/car-makes-whining-noise-like-driving-on.html
Chirping Noise From Car?
http://technoanswers.blogspot.com/2011/11/chirping-noise-from-car.html
What are the possibilities for Clicking noise in car?
http://technoanswers.blogspot.com/2011/11/what-are-possibilities-for-clicking.html
Squealing at start up on car?
http://technoanswers.blogspot.com/2012/01/squealing-at-start-up-on-car.html
Chirping sound coming from engine?
http://technoanswers.blogspot.in/2012/01/chirping-sound-coming-from-engine.html
4X4 Truck makes roaring noise in the front end?
http://schematicsdiagram.blogspot.com/2012/01/4x4-truck-makes-roaring-noise-in-front.html
Heater makes clicking noise under dash on Ford Explorer?
http://technoanswers.blogspot.in/2012/01/heater-makes-clicking-noise-under-dash.html
Clicking noise under dash and front defroster not working?
http://technoanswers.blogspot.com/2012/01/clicking-noise-under-dash-and-front.html
Car Brakes Making Noise?
http://repairhelpcenter.blogspot.com/2011/12/car-brakes-making-noise.html
Car Alternator making noise?
http://repairhelpcenter.blogspot.com/2011/11/car-alternator-making-noise.html
Car Alternator Bearing Makes Grinding noise?
http://repairhelpcenter.blogspot.com/2011/12/car-alternator-bearing-makes-grinding.html
Engine makes noise and Cooling Fan belt Breaks?
http://howtobyme.blogspot.com/2011/12/engine-makes-noise-and-cooling-fan-belt.html
Vehicle Makes Clicking Sound While Taking turns?
http://schematicsdiagram.blogspot.com/2011/12/vehicle-makes-clicking-sound-while.html
ABS light comes on and Car makes Grinding noise?
http://repairhelpcenter.blogspot.com/2012/01/abs-light-comes-on-and-car-makes.html
These will help.
Thanks.
Nov 28, 2012 | 2010 Toyota Camry
03 aprilia Mille doesn't start. Sometimes it turns
Hi, Aleksandr and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Security alarm needs a reset.
6. Starter control circuit, relay, or solenoid faulty.
7. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue, please visit the websites below. Good luck and have nice a day.
DOWNLOAD 2003 Aprilia Rsv Mille
Aug 15, 2011 | 2003 Aprilia RSV Mille
My Parrot CK3100 will not seem to switch off when the ignition is turned off and the car is locked. The display seems to remain on 24x7 and now seems to be draining the car's battery. Any idea how to...
Hi there, my Parrot CK3100 screen just says "Goodbye" how do I switch it back to the Parrot symbol, so I can pair it up to my Samsung Wave via bluetooth. My phone is connected to the device, but the divice is not connecting to my phone?
Jan 24, 2011 | Parrot SA Parrot Ck3100 Lcd Handsfree...
Jan 19, 2010 | Parrot SA Parrot Ck3100 Lcd Handsfree...
97 Golf that makes a chirping noise
have you checked the CV joints, there only good for approx. 100,000 kms.
Sep 01, 2009 | 1997 Volkswagen Golf
Cell Phones Logo
260 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
